TSB Bulletin - steering wheel offset
05-01-2007, 10:08 AM | #1 |
Nate
23
Rep 172
does anybody know more about this TSB 320506 Steering wheel offset.
My steering wheel is off but it doesnt feel like an alighment issue because the car is not turning when i let go of the steering wheel. when i let get of the steering wheel, my car goes straight but my steering wheel position is off to the left. Any help on 320506 Steering wheel offset
The less people speak of their greatness,
the more we think of it. |
05-01-2007, 11:03 AM | #3 | |
Rep 48
05-01-2007, 11:47 AM | #4 |
Nate
23
Rep 172
Do you have the copy TSB description ball? Also is it only for the 325i or the 325ix. becasue i have the normal 325i? does the tsb also apply for the 325i?
Thanks
05-01-2007, 11:57 AM | #5 |
1312
Rep 10,185
Its for xi models
Have you asked you dealer if they can just centre the wheel ?? SUBJECT Steering Wheel Offset MODEL E90 (3 Series) and E91 (3 Series Sports Wagon) equipped with xDrive and produced up to 2/06. SITUATION Customer may complain of a slight steering wheel offset (about 5 degrees) when driving straight ahead. CAUSE The steering gear was not properly positioned to the front axle carrier. CORRECTION In case of a customer complaint, perform a wheel alignment to center the steering wheel. The steering gear brackets have been improved in 2/06 to have a better position in relation to the front axle carrier. PROCEDURE Torque the bolts connecting the steering gear to the front axle carrier to 56 Nm. Perform a wheel alignment and center the steering wheel per Repair Instructions RA 32 00 150 (with load) or RA 32 00 155 (without load). Perform steering angle sensor adjustment/calibration per Repair Instructions RA 61 31 996.
BMW if you are reading, I need a job, Please. |
05-01-2007, 12:03 PM | #6 |
Nate
23
Rep 172
Thanks, ya have took it to the dealer e90fleet but they kept saying its an alighment issue and i know its not becasue the car isnt turning to one side. the sterring wheel is just off. they wanted to charge me 200 bucks for an alighment so i said no its okay. i really dont think its an alighment issue. i dont know what i should do.
05-01-2007, 02:06 PM | #8 | |
Rep 48
I can double check what I have at home tonight. |
05-01-2007, 02:23 PM | #9 | |
13
Rep 467
05-02-2007, 11:19 PM | #11 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Holy shiet...all this time I thought I need an alighment
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
05-02-2007, 11:45 PM | #12 | |
1705
Rep 14,829
What I was thinking is that when I get an alignment 10k down the road, can't I just ask them to straighten the wheel then? I'm pretty sure there's nothing wrong with the alignment, just the centering of the wheel. I mean, it doesn't cost extra to center the wheel, right? |
05-03-2007, 07:26 PM | #13 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
I didn't think I needed an alignment but stealership had to comp me so I asked for an alignment and glad I did because I needed one. Might want to get one if you have less than perfect city/hwy roads. Saves on gas!
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
05-03-2007, 11:53 PM | #14 |
3274
Rep 6,723
Yeah I had this on my 325i.
Told them that the steering wheel was about 5 degrees off from center. Car drove straight but because I drive with both hands on the wheel (no pimpin in my car) it felt odd that my hands were pointed to the left when the car was driving straight. First attempt - alignment. Promptly told them that was NOT the issue Second attempt - fixed |
05-04-2007, 12:29 PM | #15 | |
Rep 48
