Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > 2007 335i sedan (E90) Battery replacement
      09-30-2011, 01:54 PM   #1
m3plz
Drives: 2007 335i sedan
Okay, so wow!!
A lot of info on this topic.....learned a lot and need to learn more.
Question:
As opposed to buying an OEM battery ($200.00) with a 2 year warranty I can purchase a Rayovac battery (BatteriesPlus.com) locally for $149.99 with a 3 year warranty/5 year pro-rated.
I plan on installing it myself and then taking it to get it registered.
My only concern is the slightly different speaks on the battery.
OEM 90Ah 720CCA
Rayovac (Item# SLI94RH7M) 100Ah 760CCA
So should I be concerned??? I read some guys beemer caught on fire!!
Thanks for the help
      09-30-2011, 01:55 PM   #2
m3plz
specks...not speaks....ugh!
      09-30-2011, 02:31 PM   #3
Glim
21
Drives: 2006 330i & 2013 X5 35i
Accepted normal flooded batteries coded: 46AH, 55, 79, 90 and 110.
AGM that can be coded: 60AH, 70, 80 and 90.
It's your call if you want to put in a 100AH, it can either be coded as a 90 or 110.
      09-30-2011, 03:12 PM   #4
paplu
paplu's Avatar
Drives: 2007 E90 328i
Go to B&M NTB store. They have the battery you need.
Replaced one on my car 2007 328i W Nav for < $160.00 out the door.
Dont forget to use their online coupon for $10 off
      10-03-2011, 09:04 AM   #5
Abutler330i
Drives: 330i
Battery
I'm the one who's caught on fire Be careful in doing it yourself. There is a vent hose you don't wanna miss. Advance Auto actually can put theirs in for free, just make sure you take it somewhere to get registered or reset after they install, cause they do not do the reset for you.
      10-03-2011, 10:00 AM   #6
._.
74
Drives: BMW
if the battery Ah is different you will need the battery 'programmed' and registered. Programming will let the car know that the Ah is different, registering will reset all adaptions IRC.
      10-03-2011, 10:35 PM   #7
queensfield
21
Drives: 2006 330i E90
good advice above- programming and registration are necessary
      10-03-2011, 11:15 PM   #8
Brian_TII
Drives: 06 e90 330i 6spd
With the box that clips on the top I'd probably verify that everything still lines up / clips on / locks the battery in place with whatever you chose. Personally I just got the OEM battery... my first one made it 5 years and was <still> starting the car... just had a black "magic eye". I figured with everything the battery does / has connected and hanging off of it... that it was worth the extra few bux for the OEM one that I know will fit perfectly and has the vent line in the correct spot, etc... (and then I registered it myself :-) )
