DLS REFERENCE PS5A in e90lci
09-25-2011, 04:10 PM | #2 |
300
Rep 3,969
That speaker is going to get WET! Why did you not mount it against the door panel? Also, where is your vapor barrier?
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
09-25-2011, 06:18 PM | #4 |
300
Rep 3,969
The vapor barrier is the gray foam panel you see in the first two pictures.
By the way, where did you get the sail panel tweeter mount? Looks nice!
09-26-2011, 01:53 AM | #5 | |
Rep 72
Why do you need to be a vapor barrier?
09-26-2011, 09:59 AM | #6 | |
300
Rep 3,969
By removing the vapor barrier, you are asking for trouble. You can replace it with Dynamat, but it needs to be absolutely water tight. Over time, and with high and low temperatures, the Dynamat adhesive may come loose, and you will have water coming into your car. How do I know? - My wife's X3 had had a problem with wet floor boards on the drivers side. I took the door apart and indeed there was a tiny leak between the vapor barrier and the door, but large enough to flood the floor boards, produce mold, and make the car smell like cat urine for weeks! You don't want that, trust me!
09-26-2011, 10:53 AM | #7 | |
221
Rep 2,339
Mine was a tiny leak near the top of the barrier just under the tweeter. I peeled the barrier back a bit to install new wires into the door but when I put it back there was a portion of it left unsealed and when it rained hard, I would get water in my floor boards.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
