Having Procede and taking car to get serviced at BMW????
04-29-2007, 02:56 PM | #1 |
72
Rep 613
If I did the following, what would happen w/ the Procede installed
1. Disconnected the ground wire so it's not visible. 2. Reconnected both vacuum lines to their factory locations. Would this cause CELs or anything else? Just want to be sure that all signs of a Procede installation is completely hidden and that it doesn't cause any problems. in other words, if i hid the only 2 external pieces of evidence of the procede installation, will it cause problems if I took it to the dealership for service (i.e. oil change, tune up etc.)? |
04-29-2007, 03:02 PM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
If you disconnect the ground, the PROcede will not function and you will throw some codes. You will either have to remove the PROcede completely. Or just pop in the bypass plugs. At which point you can tuck the ground wire back into the ecu box and put the hoses back to stock.
Shiv |
