Reason(s) for Fuel Pump Failure
04-29-2007, 06:40 AM | #1 |
Rep 66
I am trying to understand why the same fuel pump, with the same potential defects, would fail in some cars and not others. For instance, not everyone with a 9/06 build date is experiencing problems, and some have gone many miles (I think that the record so far is 18,000 posted on this board). For those of you who understand the components inside this pump, what do you think is going on? I have some theories but would like to hear from people who actually know how these pumps work... In the pumps that fail, what component, exactly, has failed? I have about 6400 miles on a 9/06 build 335i and no problems so far.
04-30-2007, 06:58 AM | #2 |
19
Rep 222
Can I have your fuel pump please
E93 325 SE, Sparkling Graphite, Black Dakota, hi-gloss black trim, 230's, Folding Mirrors, C/A, Sat Nav, Sport Seats, Front Seat Heating, prof Hi-Fi |
04-30-2007, 09:29 AM | #4 |
90
Rep 2,707
1. It's a relatively new device. Regular fuel pumps don't push fuel into a 200PSI pressurized chamber
2. It could come from one or many of the bad batches of the supplier (Bosch, MANN, MAHLE etc)
zhpregistry.net - ZHP stats and free classifieds.
04-30-2007, 09:45 AM | #5 |
459
Rep 5,319
Do they use multiple suppliers? I guess it would be impossible to get the data as to which supplier is having the most failures, or if it is in fact a single supplier that is having all the failures.
04-30-2007, 09:51 AM | #6 |
Klaatu Barada Nikto
30
Rep 1,169
04-30-2007, 10:39 AM | #7 |
90
Rep 2,707
You are probably correct, I was just listing those names as suppliers in the past models.... hmmm maybe they should stick to Bosch
04-30-2007, 12:07 PM | #8 |
Moderator
618
Rep 10,855
Pretty sure this is exclusively Siemens AG's baby.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
04-30-2007, 02:06 PM | #10 |
Puro Pinche Party!
23
Rep 133
My understanding is that the fuel pump actually houses 2 seperate pumps; one sucks the fuel from the gas tank, and the second pump pushes the the fuel via high pressure to the direct injection system. I hear the latter of the 2 is what is failing.
04-30-2007, 04:06 PM | #11 |
29
Rep 633
There are 2 seperate pumps, not in the same housing at all. The low pressure pump gets the fuel to the high pressure pump at a positive back pressure. The low pressure pump is electric, the High pressure is mechanically driven by the engine.
The high pressure is created by lowering the volume on the high pressure side via three rod driven bellows. Check valves keep the flow going one way, and maintain the High pressure side pressure as the bellows do their thing. So, possible candidates for failure are: 1. the hi pressure check valve 2. the bellows or the connection/assembly to the plunger rods (x3) 3. the mechanical drive flange (less likely) Knowing that this is gasoline we are pumping, and that it's lubricating properties are near zilch, that HP check valve needs to be self lubricating, yet tight.. While there are lots of well proven Fuel control units and hi pressure injector pumps in the diesel side of the business, the advantage they have is that fuel oil also lubricates the internal parts.. Cutting the gasoline with ethanol even makes it dryer, whether that can be statistically shown to have any relevance here is another matter. here's a cross section of the pump, make your own call: Last edited by Lost Horizon; 04-30-2007 at 08:38 PM.. |
04-30-2007, 06:44 PM | #12 |
24
Rep 421
This may be a stupid question ("note to self: if it sounds stupid it probably is") but are the MT and AT fuel pumps the same? Because I've heard people say that only automatics are failing, any truth to that? My car has almost 6k miles and to this day no problems...knock on wood...
Formerly know as 330iE90
2004 330i ZHP 2006 United Grey GTI (wife's) - DSG, package 1. 1974 Chamonix 2002tii - (SOLD) |
04-30-2007, 07:13 PM | #13 |
The Jesal
391
Rep 5,859
Could it be that some owners wait till their gas light is on before filling up?
Maybe thats too much stress on the fuel pumps?
2009 E90 M3 - SOLD
04-30-2007, 07:15 PM | #14 |
17
Rep 729
Not sure, but i highly doubt it.
RIP 2007 335i Sedan
04-30-2007, 07:23 PM | #16 | |
254
Rep 8,338
and imho, if that were the case there should be a disclaimer about the pump. i'm really frustrated with all this fuel pump business, i can't enjoy my damn car.
04-30-2007, 08:13 PM | #17 | |
29
Rep 633
Are the failures geographically diverse, or is there any pattern at all to them? Last edited by Lost Horizon; 04-30-2007 at 08:42 PM.. |
04-30-2007, 09:29 PM | #18 |
Rep 81
This by no means is this supported by any specific knowledge of the HP pump-- It was suggested on this forum before that adding a tiny bit of oil with the fuel helped with BMW's diesel pumps(at even higher pressure than the current 335i). Maybe someone whos engine is showing terminal symptoms of fuel pump failure can try an experiment.
I can say that very small amounts of oil will not harm the operation of the car and any of its fuel dependent systems. It is true that modern fuel is much "dryer" and "thinner". Last edited by homerunball; 04-30-2007 at 11:09 PM.. |
