Noob Question: difference between cat back and turbo back
04-28-2007, 11:41 AM | #1 |
13
Rep 247
I know nothing about exhausts and have seen cat/back and turbo/back mentioned numerous times. Anyone mind explanining the difference?
-Mark
2007 335i Coupe |
04-28-2007, 01:16 PM | #2 |
675
Rep 4,080
In California, one might pass exhaust inspection and one will not and may get you fined $2000. Both are illegal.
Cat back = from the primary catalytic converters completely back, eliminating the second set of catalytic converters and resonator. Turbo back = from the turbo outlet completely back, eliminating both sets of catalytic converters and resonator. |
04-28-2007, 01:30 PM | #4 |
675
Rep 4,080
True, I meant in the truest sense of "turbo back"
Still, should be aware of the legalities. Replacing a cat without jumping through some major loops in California is illegal. Now, that hasn't stopped me personally-- |
04-28-2007, 01:34 PM | #5 |
675
Rep 4,080
California has a visual inspection also. If the tech has a schematic and knows what to look for you could also be screwed, even if you passed the test.
Lots of good ways to get around this though, like gutting the cat. i'm going away now... |
04-28-2007, 04:19 PM | #6 | |
335
Rep 7,719
To the OP, the catback exhaust is just that...exhaust behind the catalytic converter(s). The turboback exhaust replaces the whole exhaust line right after the exhaust manifold(s). |
04-28-2007, 07:57 PM | #8 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
To answer the original question... catback means that it goes back to the cats, which on the 335 means that it replaces back to the downpipe since the primary cats are in the downpipes. Turbo back means that it also replaces the downpipes and bolts up to the turbine side of the turbos.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
