Other access thru firewall other than the ECU box?
09-19-2011, 01:46 PM | #1 |
40
Rep 212
Is there any other access thru the firewall other than by the ecu box that might be a little easier to get to? I want to install police radar and need to run two small wires but taking all the ecu apart for those two wires seems like a lot of pointless work so I was hoping there is an easier access?
09-19-2011, 04:18 PM | #2 |
50
Rep 825
Drives: a car.
theres a pass through on the drivers side.
09-19-2011, 07:49 PM | #4 |
50
Rep 825
Drives: a car.
instead of splicing or wiretapping you can use an "add-a-circuit" found an any automotive store. it'll just plug into, the radio fuse for example, it adds a fuse and will give you a pig tail you can put a terminal connection onto in order to tap power.
this is good for a few reasons; easily and fully reversible, fused, and easy to get to
09-29-2011, 03:02 PM | #5 | |
40
Rep 212
09-29-2011, 03:55 PM | #6 |
50
Rep 825
Drives: a car.
It should def turn off when the car goes to sleep after a few minutes, people typically have the opposite problem.
I would verify your tapping into the same circuit as the accessory power socket. That turns off when the key is out.
09-29-2011, 05:06 PM | #7 | |
253
Rep 7,089
Drives: '06 AW 330xi
You can also use the homelink slot....even better if you don't have homelink (you just need 1 fuse in this case). |
09-29-2011, 05:27 PM | #8 |
50
Rep 825
Drives: a car.
op, just out of curiosity, did u custom install a radar detector? If so let us know the details.
09-29-2011, 06:44 PM | #9 |
40
Rep 212
Hmm That Has Not Been The Case For Me. Mine Def Doesn't Turn Off. Which Fuse Slot Should I Use? Ive Tried, The On/off Switch, Heated Seats, Windows, A/c, And None Of Them Worked... Is There Anyway I Can Just Hardwire It Into A Wire That Will Turn Off Once The Key Is In The Off Position?
And Yes I Did Custom Install The System. It Is Absolutely Awesome! I Got The Passport 9500ix Or Something Like That. It Has Laser Shifters And The Whole Deal. |
09-29-2011, 11:01 PM | #10 |
50
Rep 825
Drives: a car.
Please tell us about your radar install. Where is the antenna? Where did you put the LED, display and control unit? Photos!
10-02-2011, 08:50 AM | #14 | |
253
Rep 7,089
But there's no reason why the fuse tap shouldn't be working. Are you sure your looking at the diagram correctly? |
10-03-2011, 10:21 PM | #16 |
50
Rep 825
Drives: a car.
theres a power port somewhere upfront... i guarantee it...
check on the upper inside corner of the passenger footwell. look for a power port socket pointing down. if its there, and the fuse box is still causing you headaches, then do it the ugly way... drop the foot well cover (two torx screws), then put wire taps onto the power port + and -
10-03-2011, 10:56 PM | #17 |
Cuba
81
Rep 1,676
yea i fuse tapped the garage door opener when hardwiring my v1 make sure you drill a hole in the metal piece as a ground. i used the mini fuse tap and it worked great. theres a diy here somewhere
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
10-06-2011, 03:00 PM | #18 |
40
Rep 212
I used a regular size fuse tap and it doesn't work.... Could that be the problem?
Also, what is the power port? What does it look like because I do not mind hardwiring it into something as long as it turns off when the key is off... |
