Window actuator life-span
09-17-2011, 03:47 PM | #1 |
bimmer newb
15
Rep 334
So it seems that the life-span of the rear window actuators on the E90 is 5 years, given my experience. We bought our '06 325i a little over 2 1/2 years ago, and thank God we got the extended warranty, because the passengers side rear broke in January, and just 2 weeks ago the drivers side rear broke. I hope the front ones are built a little better!
09-17-2011, 03:57 PM | #2 |
124
Rep 2,554
General question here, what causes them to fail? Time or use?
09-17-2011, 07:27 PM | #6 |
17
Rep 512
I would say use is main cause of failure. They are typically just a small electric motor and the more they are used the more likely they will fail. But this thread makes me wonder if a dif motor is used for the fronts bc usually fronts are used substantial more than rears.
Please don't feel great about spending 2k plus on an extended warranty for a 100 diy lol. |
09-18-2011, 03:02 PM | #7 | |
bimmer newb
15
Rep 334
09-18-2011, 03:04 PM | #8 |
bimmer newb
15
Rep 334
09-18-2011, 09:17 PM | #9 | ||
17
Rep 512
Extended service is dif than extended warranty. Extended service is typically a break even unless you do the work yourself. I was comparing ur two window regs to the cost of ext warranty if u add the truck latch problem ur still pretty far away from ur warranty cost. I'm not trying to bash u not having to worry about potential prob is def worth something.
09-19-2011, 08:10 AM | #10 | |
18
Rep 345
Also, I bought my car used, so I can't speak for the previous owners.. but I rarely ever roll my windows down. The windows are tinted and I don't have the scratching a lot of people complain about so I would like to think the previous owners didn't roll them down much either so I really don't know if the breakage is from a lot of use or not. The way the cable end connects to the plastic piece that breaks, it has a spring that is putting constant pressure on the plastic so I'm thinking it is more a combination of age and the plastic piece getting weak over time. |
09-19-2011, 07:26 PM | #11 |
Rep 56
I wonder if tint increases the resistance to roll up/down. It definitely adds some drag/thickness. Maybe the bigger issue is most tint shops open up your doors to get the tint all the way down the glass (at least I've seen a lot that remove panels), so who knows what that does to fit and operation?
Did anyone notice them straining or moving slower over time? Mine seem great, and I have an early build '06 330i. I rarely roll down any window but driver's, so I hope I don't fall into this camp. |
09-19-2011, 07:29 PM | #12 |
369
Rep 8,693
Drives: 06 330i
i honestly think the last time i used my windows was when i got pulled over...
09-19-2011, 10:21 PM | #13 |
Take Care!
Rep 61
06 330i right rear went out a few weeks ago. I use my driver's side window everyday to get on post and it has not went out in five years.
06 330i | JB/Grey | Premium | Cold Weather | iDrive |
09-19-2011, 11:46 PM | #14 |
124
Rep 2,554
seems to me like it's happening with age...
09-19-2011, 11:51 PM | #15 | |
160
Rep 1,307
09-20-2011, 11:01 AM | #19 |
AC
95
Rep 2,387
luck. poor QC by BMW
Your Supreme Leader
09-20-2011, 11:04 AM | #20 |
35
Rep 1,691
09-20-2011, 11:14 AM | #21 |
just another bmw douche bag
195
Rep 3,640
My left rear regulator broke earlier this year (also a 2006), and it's the window I use the least.
Really, the only part that broke on the regulator was the plastic saddle that the window sits in that the cables pull up and down. why BMW makes this part out of plastic is beyond me, but once that breaks, there is a good chance that your cables will get jammed up inside the pulley mechanism. The motor itself was fine, I just popped in a new regulator assembly. Took longer to remove and reinstall the door panel than it does to actually replace the regulator! |
09-20-2011, 11:16 AM | #22 | |
253
Rep 7,089
Drives: '06 AW 330xi
