Opinions of Blade Drying...?
09-17-2011, 02:11 PM | #1 |
14
Rep 280
So I see my friends using the rubber/jelly blade thing you can buy for drying cars.
I of course am much more of a detail enthusiast. They say its safe on paint and all that but from the sounds it makes and from the process itself makes me want to cringe. So my question is, even though cutting time, is the blade actually safe to use to dry the car? Maybe as an initial step before using a microfiber drying towel??? |
09-17-2011, 02:15 PM | #2 |
33
Rep 856
No point in discussing really, it's evil, check at 2:30 in the video below. It doesn't really save any time, a good drying towel works pretty damn fast.
09-17-2011, 10:03 PM | #4 |
33
Rep 856
09-17-2011, 10:26 PM | #5 |
Rep 168
Unless you're working on it while the wind is gusting or you do a terrible job washing, it's a non-issue.
Waterblade fear is exaggerated and a little substance. Last edited by Jean-Claude; 09-17-2011 at 10:33 PM.. |
09-18-2011, 02:14 AM | #6 |
149
Rep 3,552
http://www.amazon.com/Absorber-Synth.../dp/B0000AY69V
i use the california blade only on windows. absober for the body. just patting, no sliding. |
09-18-2011, 02:10 PM | #7 |
37
Rep 1,168
Todd has a good article on safe washing, no blade used.
http://www.detailedimage.com/Ask-a-P...and-dry-a-car/ |
09-19-2011, 12:42 PM | #9 |
55
Rep 592
I used a water blade on my previous car for many months without any problems. Then one day, I was unlucky enough to have a small piece of something get on my paint between the rinsing and drying steps, and blade drying gave me a nice 6" long scratch on my hood. The water blade should be good 99% of the time, but sometimes you get unlucky. The scratch wasn't too deep though, so I probably could've polished it out.
09-19-2011, 01:45 PM | #10 | |
Long Time Admirer, First Time Owner
18016
Rep 9,378
09-19-2011, 02:30 PM | #12 |
322
Rep 17,316
Drives: E92 M3, E30 325i
In my opinion the risks are greater than the rewards with the blade so I'd rather not take the chance.
09-19-2011, 02:40 PM | #13 |
33
Rep 856
09-19-2011, 02:52 PM | #14 |
322
Rep 17,316
09-19-2011, 03:01 PM | #15 |
68
Rep 1,324
I had a California Water Blade and it hit a spot of the car that was already dry, rubbed, and left a mark. I moved it inside for windows or the shower stall and switched to Absorbers. I wasn't happy with that, or a genuine chamois, so I finally tried waffle weave towels.
I don't recommend the Cobra ones from Autopia, they started to pill and also leave fabric/lint behind. Autopia was good enough to replace it the first time, but when it happened again I didn't want to go through the hassle so I stopped using it. But I found the Detailed Image ones much better. Edit: Have you tried the sheeting method? With no nozzle on the hose, slowly pour water from top to bottom, and its natural cohesion literally sheets the water off the car sort of like how the blade does. By doing this, I am able to use a single waffle-weave towel for my entire car, and it's not soaking wet.
Was: 2008 335xi sedan 6MT Black Sapphire Metallic
Is: 2014 Tesla P85D (Blue Metallic) Wife's: 2013 Infiniti G37 S sedan 6MT, Black |
09-19-2011, 07:24 PM | #16 | |
37
Rep 1,168
09-23-2011, 01:43 PM | #18 |
135
Rep 2,517
Drives: '11 335xi e92 M-Pak
Bad idea! I used to use this with my older car and it worked well. After using it few times with my e92 it was ok until I went through a spot where it wasn't "shinny/soft" the blade didn't really glide anymore and it rubbed on the paint. Luckily it was fixable after a detail.
I am not longer using it, I bough a big micro fiber towel to dry the car and its awesome.
09-25-2011, 06:52 PM | #19 |
78
Rep 1,127
I use the sheeting method with every wash. It makes it so much easier. Then use plush microfiber towels.
Never in hell will a water blade touch my car. Friend used it on one of his side panels and had the most ridiculous scratches. Remember, washing doesn't get all the grit off the car. Even after a full clay bar and second wash... I'll never use a water blade. I also wish they did the test with a touchless automatic car wash. With all the pressure pushing the dirt into the paint, there has to be scratches and swirls when thoroughly analyzed.
09-25-2011, 08:04 PM | #20 |
863
Rep 5,448
Use the softest thing possible that has the ability to trap particles instead of rubbing them around your car - a good waffle weave, or even better, use something that won't touch your car like an air drying unit (or even a leaf blower!)
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
09-26-2011, 09:26 PM | #21 |
17
Rep 415
I used to wash cars at a Nissan dealership. We used blades on new cars and I never saw problems, probably because they were new. I also used them on my white car I drove at the time. I wouldn't use a blade, though. just not worth it. I don't believe, however, that you need towels that are better cotton than you use yourself after you shower. I have been told that you need brand new, thread count specific cotton towels. I am sorry. If it's good enough for me, its going to be for me. Anyway, I use a large surface area microfiber drying towel then use a cotton towel for the spots i missed. hope this helps
09-27-2011, 12:51 PM | #22 |
Rep 168
Water blade is like any other tool. It has its place and a proper method of use. I keep one in my arsenal for use under certain circumstances and my client's cars stay looking amazing. I have never caused any marring with one. But I spend about 1.5 hours on a wash and I don't leave crap on the paint.
