Cobb Stage 3 (Alpha) - vids
09-13-2011, 09:49 PM | #1 |
273
Rep 5,876
At an airfield event, recorded these two
Next up I'll be stacking a JB4 on top to add a tiny bit of extra boost progressively up top when meth is flowing...AFR is a perfect 11.5 all the way through and it hits that target immediately at the kick of throttle...no wild upswing/downswing that I used to experience and couldn't 100% tune out on either procede or the JB4...I don't want to run 18psi all the way to redline flashed as that leaves no room for so called meth safety.. I consider this flash/piggy (procede or jb) combo a very potent one as you have "direct" timing and fuel control which is 100% predictable and then use a piggy for progressive boost and meth safety where required...obviously that'll be "the thing" until a flash like Cobb can deal with all three As you can see, NO MORE MISFIRES UP TOP!!! Last edited by dzenno; 09-13-2011 at 10:08 PM.. |
09-13-2011, 10:03 PM | #2 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
yep
09-13-2011, 10:15 PM | #5 |
52
Rep 1,357
Drives: '08 e92 335i COBB 4.01 Stage 1
Sorry for being OT, but how did you resolve your misfires??? I remember when you running a particular tune that it always misfired. So, was it tune related or something with your hardware?
09-13-2011, 10:24 PM | #6 |
273
Rep 5,876
thanks buddy..this is running 18psi@midrange, 16psi@6k, 14psi@6.5k, 13psi@7k rpm, pump gas with a slight bit of meth flow as it was near the end of the tank...IMO, its the ideal base tune to stack more boost on top progressively when meth flow is there
Wish ATR was already available and Cobb had a way of doing progressive meth but I have no problem using a piggy such as JB4 as a mini ATR and setting up a custom map6 with a meth flow based boost additive to lift the boost curve towards redline a bit more aggressively when "sufficient" meth is flowing and even further up when both meth and race gas are in there... hitting the strip tomorrow, time to break stuff, hopefully just numbers not parts this time lol |
09-13-2011, 10:27 PM | #7 | |
273
Rep 5,876
its still up in the air what it really is but I politely asked Cobb to just turn off misfire detection for me to see if it really is an "actual" misfire (loss of power, black smoke, backfires, etc) or something diagnostic tripping a false misfire code...lo and behold, they were kind enough to provide me with that feature in this map and the car doesn't misfire at all...on many platforms misfire detection itself has to be tuned so its less sensitive or turned off as it gets in the way of high HP tuning due to it being adjusted to stock power levels... |
09-13-2011, 10:27 PM | #8 | |
83
Rep 2,291
2jZ + RB26 + 4G63 + LS9 + N54 =
09-13-2011, 10:30 PM | #9 | |
177
Rep 6,631
Then you don't need to use the JB4 to sustain boost top end. BTW, I talked to Terry earlier today, he's open to the idea of creating a custom meth failsafe to be used on a flash tune.
E90 LCI N54 6AT
09-13-2011, 10:30 PM | #10 |
273
Rep 5,876
09-13-2011, 10:32 PM | #11 | |
273
Rep 5,876
09-13-2011, 11:30 PM | #12 |
151
Rep 1,677
So you can't keep 180 load to redline while raising boost to 19-20psi with JUST Cobb?
Your top speed is just awesome, I think I saw you hit almost 160mph! |
09-13-2011, 11:38 PM | #13 | |
273
Rep 5,876
I let off at 260kph as it was getting scary! fastest I've personally EVER gone in any car |
09-14-2011, 01:09 AM | #14 |
161
Rep 7,377
great vids dzenno! any vbox times yet? you must be really glad to have finally vanquished the missfire troll!
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
09-14-2011, 01:14 AM | #15 |
151
Rep 1,677
So what would Cobb need to do in order to have what the piggys can as far as having progressive boost based on meth flow? I know I'm missing some basic stuff here so hear me out.
09-14-2011, 01:34 AM | #16 |
127
Rep 6,773
09-14-2011, 02:16 AM | #17 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
09-14-2011, 07:08 AM | #19 |
32
Rep 878
dzenno if you are going to cayuga today, i'll probably head down there also seeing as i live 30mins away, would love to see that beast run.
08 335i | Space Gray | Burl Walnut Wood Trim | Sport pkg | Premium Pkg | LOGIC7 | Navi | Comfort Access
| COBB | Injen DCI | Active Autowerke | Sonic Tuning | E92 Lighting | ER | HKS | BMS | Ground Control | Vortex Tuning | |
09-14-2011, 07:09 AM | #20 |
273
Rep 5,876
They just need time to do it and who knows if that's even the best way of doing it at this point..maybe we're just accustomed to doing it that way as we don't know any better at this point
09-14-2011, 07:17 AM | #21 |
161
Rep 7,377
would be cool though to see how that one goes with race gas
