2010 2011 BMW 5 Series Forum F10 20 inch BBS RS-GT wheels |
09-03-2011, 02:18 PM | #1 |
Rep 139
Set of 4 BBS RS-GT wheels, "Diamond Black" centers. 2-piece forged centers and rims. Absolutely perfect, never damaged, no chips or scratches. List price $5,620 from Tirerack, asking $2,800. Specs and pic below: Front 20 x 8.5 inches Offset: +15mm Backspacing: 5.41" Bolt Pattern: 5-120 Rec. Tire Size:255/35-20 for M5/M6 If you have 5 series other than M5, you need 245/30-20 Weight: 23.4lbs. Rear 20 x 10 inches Offset: 22mm Backspacing: 6.42" Bolt Pattern: 5-120 Rec. Tire Size:285/30-20 For M5/M6, If you have E60 5 series, you need 295/25-20 Weight: 25.1lbs. Last edited by mdh; 11-01-2011 at 07:07 PM.. Reason: Higher def pic of wheel |
09-11-2011, 10:34 PM | #3 |
133
Rep 1,087
Drives: F10, F13, current->F80, F15 X5
some one should pick this up!
offset is a bit aggressive, but some stretch and some drop should fit!
09-17-2011, 09:04 PM | #5 |
Rep 139
Absolutely no problem with the stock fenders. There's a flange inside the rear fender that you need to take 1/4" off with a file/sander if you lower the car.
The look is stunning, and you can tell a big difference in acceleration and responsefrom the stock wheels - more than 5 lbs/wheel. |
