Gears "click"
09-03-2011, 07:45 AM | #1 |
Rep 10
Gears "click"
Sorry, I posted this in the wrong forum, so re-posting here.
I just picked up a CPO 2009 BMW 328 IX Touring from BMW Toronto. I was extremely happy to get it with the manual 6 speed, but I do have one issue with it. It may be hard to describe, but it almost feels like it "clicks" when it goes into gear. It's not audible, but more how it feels, almost like it a really big bendie straw. It's like as you move past the center point, it sort of grabs and then clicks before it gets fully into the gate and only once per gear change, not repeated clicks. Seems a bit harder in 2nd and 4th than 1st and 3rd, 5th and 6th seem fine but it may be my imagination. I don't have another e90 to compare it to for me to say if this is typical or not. I had a 2001 e46 330CI and it didn't behave like this, nor any other manual I have owned. Before I picked it up, I made sure BMW looked at it and they said nothing was wrong. The car still has a bit of factory warranty on it, so I could push for it to be "fixed", but I'm not even sure I have a problem. The car only has 23,000 KM on it, so it's quite new. The only reason I even felt comfortable buying it was the low KM and the CPO covers the transmission up to 160K and that I absolutely love everything else about the car. Is this normal for a e91? I've seen a few other posts about it, calling it "notchy", but wanted to hear from the general community. |
09-03-2011, 07:58 AM | #2 |
1564
Rep 4,109
Drives: BMW M3
It's definitely a notchy transmission and the 1>2 shift is harder than others. I can't say mine 'clicks' though.
My advice is to go test drive a new manual transmission BMW and see if you notice the same thing. Go back to the dealer and request a test drive.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
09-03-2011, 11:02 AM | #3 |
124
Rep 5,627
The gearbox in my CPO '07 E91 feels pretty much the same as the 4 other MT BMWs I've owned, including an E46. Although all have been RWD, so perhaps the click is an xi artifact.
The only thing I notice on the newer models is a more pronounced rev drop while shifting with the A/C compressor engaged so the clutch release needs to be timed a bit more carefully. Tom |
09-03-2011, 12:18 PM | #4 |
Semper Fi
23
Rep 417
Drives: E60 ///M5
mine clicks sometimes too.. but nothing were it sounds like its going to break..
09-03-2011, 12:33 PM | #5 |
113
Rep 1,347
Drives: 2011 335d
Have you tried changing the brake-fluid/clutch-fluid yet? Could be further accentuated if the fluid is old. I've never heard of this problem but I'd give it a try to rule out some things.
09-05-2011, 10:21 PM | #6 |
Rep 10
Thanks for the input. I'm more convinced it's just a characteristic of the shifter and not a real issue. I'm getting a heavier shift knob, which I've heard helps and we'll see what happens.
