e90 328i OVERHEATING ??????
04-23-2007, 03:22 PM | #1 |
309
Rep 2,458
hi, i just got back today driving for like 30 minutes in the 85ish degree weather. I turned on the AC around 8 minutes before i got home, the fan blew as fast as it can go. So i drive into the garage and i get out for a sec, i feel like im in a wind tunnel, every fan musta been on full blast.the one next to the rear right tire working overtime....it was sooooo loud, like a 747 next to me...ok, not that loud but boy i was surprised. i turn the car off and open the hood, it was beyond steaming! This has me kinda worried, its only 85 and i didnt have the AC on the whole time and yet the fans are blowing like crazy and the engine is red hot.......Any ideas... or is this normal?
04-23-2007, 03:26 PM | #2 | |
Rep 60
Engine is red hot???? clarify .... |
04-23-2007, 03:27 PM | #3 |
4972
Rep 10,200
hmmmmm....i have yet to have a problem with mine....ran the A/C most of the weekend....
04-23-2007, 03:34 PM | #4 |
309
Rep 2,458
red hot: uh pretty hot a lot hotter than my Lexus RX300. i don't know but it doesnt seem very normal, the fans too, they seemed like they were running very very fast.
04-23-2007, 03:36 PM | #5 |
119
Rep 2,909
Did you check the coolant level after it cooled down? Radiators only work when they are completely sealed and under pressure. You may have a leak somewhere that is causing it to overheat.
Check the coolant level under the hood after it cools down. If I'm not mistaken, there is a knob that you unscrew that you can pull out a dipstick. Make sure you stay on top of this and take it to the dealer if there is a noticeable loss of coolant. If the motor sustains damage due to overheating, they can fault you for neglecting to check your fluids (between services). |
04-23-2007, 03:39 PM | #7 |
309
Rep 2,458
just clarifying my last post i did nto mean the voltron didnt help i meant my previous one.thanks voltron wheres the coolant? haha the car only has 1600 miles and i popped up the hood only 3 times.
04-23-2007, 03:43 PM | #8 |
119
Rep 2,909
If you open the hood and you are facing the engine, the coolant tank will be on your left side (rt side of car).. It's not clear like on other cars, so it has a cap that you have to unscrew.. Make sure the car is completely cool, though...
04-23-2007, 03:46 PM | #10 |
936
Rep 4,326
Drives: M340
What does your temp guage show????
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
04-23-2007, 04:00 PM | #13 |
936
Rep 4,326
Drives: M340
ok, not familiar with the 328's but there has to be something that reads the engine temp????
04-23-2007, 04:03 PM | #16 |
119
Rep 2,909
no that shouldn't matter... I was just warning you so that hot coolant wouldn't shoot all over you when you cracked it open...
I thought you had mentioned earlier that you saw steam coming from the motor? |
04-23-2007, 04:05 PM | #17 |
309
Rep 2,458
yea just a little though, hah the coolant didnt shoot but i heard all the air escaping, but i think coolant is fine. but the steam was when i 1st opened the hood right after driving but now when i went to check the coolant, it was just a little hot.
04-23-2007, 04:05 PM | #18 |
119
Rep 2,909
The 325, 328, and 330 all do not have coolant gauges... They rely on a warning message to show up on the display.
If there is no signs of leakage, I think everything is fine... If you do have an issue, you will get a warning message if you begin to overheat and the car will go into 'limp' mode to get you home safely. |
04-23-2007, 04:05 PM | #19 | |
56
Rep 1,962
Peanut Butter Chunky
04-23-2007, 04:10 PM | #22 |
309
Rep 2,458
thanks guys, i woulda called up the dealer because i was pretty nervous, 1st bimmer and well i have had a couple of problems with it already just didnt bring it in yet so i was a bit too jumpy.
