Einszett 1Z Cockpit Premium and UV protection
08-29-2011, 07:39 AM | #1 |
39
Rep 709
Drives: '07 335i (E93)
Tried a search and came up with so many hits that I didn't know where to start.
Does anybody know how much, if any, UV protection Einszett 1Z cockpit premium provides? I have been using Aerospace 303 for years, and it has done a great job, but I kind of like the more matte finish of the Einszett to the slight shine of the 303. Given that I have an E93 and have the top down at every opportunity, UV protection is critical, so I don't want to give up the protection. Anybody know if 1Z is as good as 303 in this regard?
Alpine White/Coral Red/Gray Poplar Convertible Sport/Prem/Step/Comfort/Nav/Sirius
MHD Stage 1 Flash, M-Factory Helical LSD By the way people: USE YOUR F&*#ING TURN SIGNALS! Pass the word. Last edited by droptop335; 08-29-2011 at 08:38 AM.. |
08-29-2011, 09:57 AM | #2 |
39
Rep 709
BTW, I just sent an email to Einszett Germany to ask this same question. I will post the answer (if I get one) here.
MHD Stage 1 Flash, M-Factory Helical LSD By the way people: USE YOUR F&*#ING TURN SIGNALS! Pass the word. |
08-29-2011, 10:49 AM | #3 |
27
Rep 872
It's not nearly as good as 303 Aerospace in UV protection abilities, but from everything I've heard, it does has a minimal amount of protection. I agree that the look is much nicer than 303, but also keep in mind you don't need to apply 303 at every chance you get.
Apply the 303 every other or every 3 months. Apply a very small amount of Cockpit Premium to a microfiber towel and wipe down your dash once a week (my g/f, many of my clients, and I all keep a small spritz bottle of 1Z and a microfiber in our glove boxes). Doing so - you'll get the best of all worlds. Smart move to use 303 with an E93, but sometimes its using multiple products to truly get the result you love. I know how this is as I'm also a convertible owner. |
08-29-2011, 12:12 PM | #4 | |
39
Rep 709
08-29-2011, 12:18 PM | #5 | |
27
Rep 872
Could you be removing some of 303's UV protection? You certainly could be. Let me also remind you that washing your car (even with properly diluted high quality car wash shampoo) will remove some of your wax's/sealant's protection ability. I'm sure that doesn't stop you from keeping your pretty lady clean though does it? |
08-29-2011, 12:24 PM | #6 | |
39
Rep 709
08-29-2011, 12:28 PM | #7 |
39
Rep 709
Still curious whether Einszett Germany will respond to my question...
08-29-2011, 12:30 PM | #8 |
27
Rep 872
I enjoy it when people ask great questions. This is much more enjoyable than what seem to be the two most popular postings I see: 1. "What wax do I use?" 2. "What do I put on my leather?" GL, happy detailing, and let the community and I know if you have any other questions. Never forget that when you start to get really into car car: there are fewer and fewer absolutes and more and more personal preferences. It's all about understanding how things work and going from there. |
08-29-2011, 01:03 PM | #9 | |
39
Rep 709
As I stated earlier, I have been using 303 for years, and certainly ever since I got my E93 4+ years ago. A couple of questions have always nagged me:
08-29-2011, 02:13 PM | #10 | |
27
Rep 872
When it comes to topless rides, it gets tougher because UV ray damage becomes something to actually be worried about. I'm recommend NOT using anything but quality leather care products on the leather YOU TOUCH specifically. This means stuff like Leather Master or LTT leather care products. For surfaces you don't touch, or don't touch nearly as much, you might want to consider 303 on them. In all - think of micro-sanding and wear when it comes to surfaces. Things you sit on or contact often have oils from your body, dyes from clothing, debris, etc rubbing into them. Any residue from a product could capture debris and cause additional wear. Also, the seat's surface you sit on is covered while you're driving from your body: it's not getting hit with any UV rays. Your muscles sit under your skin. If you don't "condition" your skin, do your muscles dry out? This is the same with your urethane coating. If anything, a wipe down with water is all that seems to be needed when it comes to "hydration" as water molecules are small enough to potentially penetrate surface micro-cracks in the coating. Aside from that, you're not going to get into leather hydration on your seat material. If you had a different type of leather surface, you could start looking into the fat-liquor process used to treat aniline leather surfaces... but that's just not the case and is completely irrelevant in this scenario. When it comes to other hard surfaces, it helps (IMO) to understand how the products are made and composed. Plastics certainly could use 303 to help keep them looking proper over time. Unlike paint, plastics are much more likely to be a complete homogeneous layer of material. The surface likely doesn't have any additional protective abilities than say 3-50 microns underneath. Wood trim however is something different. Most trim used now is clear-coated for additional depth, gloss, and (mainly) durability. The clear-coat used should have UV ray blockers / inhibitors just as it does in your vehicle's clear-coat over the paint. After talking to Dr. David Ghodoussi of Optimum Car Care, I'm now well aware that UV blockers can migrate into substrates, but I hardly think it'd be a major factor for an interior trim piece, even in a topless car. In short, use clear-coat protective products on clear-coat and plastic protective products on plastic |
08-29-2011, 02:40 PM | #11 | |
39
Rep 709
With respect to the hard surfaces, based on what you stated I will probably continue to use the 303 on the hard homogeneous (black plastic) surfaces (maybe in conjunction with the 1Z) and will move to using Klasse on the clear-coated parts. I would imagine that one Klasse treatment per year or two would suffice for interior trim. Thanks again for the discourse my friend!
08-29-2011, 02:48 PM | #12 | |
39
Rep 709
Comfort you can't see but can definitely feel: SunReflective Technology keeps the leather of your BMW's seats and steering wheel cooler - even in direct sunlight - so you can always feel comfortable when you get behind the wheel. SunReflective Technology is based on a special pigment during the treatment of the leather, which reflects direct sunlight in the invisible waveband. As a result, the surfaces do not become as hot as usual and maintain a pleasantly low temperature. Compared to conventional leather, SunReflective Technology keeps your steering wheel and seats up to 25 °C cooler. Just an FYI...
08-29-2011, 02:53 PM | #13 |
27
Rep 872
Keep up the good work!
Using the wrong products on leather leads to additional wear. Perfect example - here's part of a seat from an '83 Ferrari I worked on. Despite less than 20k miles, the leather had A LOT of build up from too much "conditioner" and didn't look or feel right. Once properly cleaned, the leather felt and looked amazing. Leather shouldn't be shiny looking. It should be sheen and beautiful. You're better off keeping your leather clean and free of ANY product than using the wrong stuff. |
08-29-2011, 02:59 PM | #14 | |
27
Rep 872
Interesting and helpful to use in a car that might be left top down in the sun. Here's an even better pic of the same Ferrari. Mind you - less than 20k miles and the leather already had some hardcore wear and "cracking" spots (these areas were where there is even more build up, which causes more wear and build up, which causes more wear and build up, etc). Especially look past the driver's seat and look at the passanger seat bottom area. I don't have a true "after" on the driver's seat but know it was much improved. Here's an after of the passanger seat which wasn't as bad, but was still quite bad for her miles, that was turned around to like-new condition: EDIT: Here's a "near after" of the driver's seat as I was still applying an intermediate step: Last edited by MuttGrunt; 08-29-2011 at 03:07 PM.. |
08-30-2011, 04:12 AM | #15 | |
11
Rep 770
Quality UV protection products contain ultra violet stabilizers There are a couple things that should be realized; auto paint or chemical companies don't state the amount of ultra violet protection is in their clear coat, nor do they tell you what the specific ultra violet stabilizing chemical is in most cases. UV stabilizers are a group of chemical agents with the ability to counteract or neutralize the harmful effects of UV-B light radiation. Competitive absorbers provide protection by converting UV light to heat so it can dissipate harmlessly All UV stabilizers are consumed as they do their job. In a way, they serve as sacrificial molecules, taking the abuse from the UV light instead of the material they are protecting. Ultra violet light (UV-B) radiation and environmental contaminant exposure leads to photo degradation of materials and surface staining. But before UV light can cause harm, it must first be absorbed. If it is not turned into heat or transferred to a nearby stabilizer molecule called a quencher, it breaks weak chemical bonds. This is the beginning of UV damage. Some materials absorb UV light more readily than other materials. Be cognizant that ultra violet heat (UV-A) radiation can also affect the structural integrity of materials by drying out and therefore removing their elasticity and causing structural damage (cracking). IMO the best UV protection product is 303 Space Protectant |
08-30-2011, 07:45 AM | #16 | |
39
Rep 709
UV and IR (Infra-red = heat) waves are completely different wavelengths and actually are on either side of the visible wavelengths: UV wavelengths = 90 - 400 nanometers (nm) There is no heat generated in the UV range Visible wavelengths = 400-700nm IR wavelengths = 700 - 5000nm, with most of the heat being generated at the 5000nm end of the range It is true that UV is split into subranges, usually UVA (320-400nm) and UVB (290-320nm), with UVC being blocked by the ozone layer. Most automotive glass (except specially treated UV bolcking glass as in most windshields) is transparent to UVA, which causes the fading we are trying to avoid. Heat (IR) is a different source of damage in that it pulls moisture out of the materials that get heated by it, a very commonly understood phenomenon (why a sidewalk in the sun dries faster than a sidewalk in the shade).
08-30-2011, 09:04 PM | #17 |
37
Rep 187
This was great. I really wish that rather than having a bunch of forums for detailing we make a site wide one that has a knowledge base of all BMW owners as opposed to how it is now.
08-31-2011, 03:46 AM | #18 | |
11
Rep 770
08-31-2011, 06:44 AM | #19 | |
39
Rep 709
"Ultra violet (UV) radiation is made up of two parts; UV-A infrared (Heat) and UV-B ultra violet light, which is responsible for photosynthesis (fading)" Infrared heat does not come from UV rays, it comes from a very different (IR) portion of the spectrum. No heat is generated by UV rays, at least not the kind that would dry out materials. And by the way, photosynthesis has nothing to do with fading. It's a photochemical reaction with chlorophyl in plants. Perhaps you meant to say "photodegradation"?
08-31-2011, 08:36 PM | #20 | |
Rep 182
I e-mailed Einszett that exact question a while back and also how it compares to their exterior protectant Vinyl-Rubber Care 'Tiefenpfleger'. This is the reply I got.
2011 e90 328i | Montego Blue | Black Dakota | Premium | Value Pkg. | STEPTRONIC | Nav | Harman Kardon | Xenon |
2000 Trans Am WS6 | Black | Black lthr. | Hurst 6MT | T-tops | Eibach pro kit | Koni SA | Borla | |
09-02-2011, 07:09 AM | #21 | |
39
Rep 709
OK, so here is the reponse I received from Einszett USA, which had been forwarded the email I sent to the HQ in Germany:
The trouble with all spray protectants is that when you are trying to apply them to very specific areas (rubber windshield trim for instance), it is very difficult to prevent the spray from hitting other surfaces. I know you can spray it directly on a cloth first, but then alot of the product seems to get lost on the cloth and never make it to the surface to be treated. It would be nice to find a small applicator bottle that has a fairly stiff sponge tip that could be use to squeeze just the right amount of product out and spread it using the tip...anybody know if those applicator bottles exist? By the way, he makes a statement that most UV is filtered by automotive glass. As I understand it, this is wrong, except for specially treated glass (windshields). Normal glass is almost transparent to UV rays...Indeed I had a car that sat outside in the same position for almost 6 months, and the interior of the south facing side was noticeably more faded than the side facing north. The windows were never down!
09-03-2011, 05:51 AM | #22 |
11
Rep 770
Ultra violet penetration of auto glass; UV radiation is present in the sun’s rays throughout the year in varying amounts. Automobile window tinting reduces the visible light transmission (VLT) through car windows. Tinted UV filtered auto window glass filters out about 37% of infrared (IR) radiation and 97% of UVB (light) radiation that is responsible for photo degradation (colour fading)
