BMW X3 Forum
BMW X3 Forum
      04-22-2007, 05:27 PM   #1
SanFranDan
SanFranDan
Drives: 2007 X3 in Highland Green
Question Pairing Bluetooth phones
I have tmobile and paired my Razr with my 2007 X3 and all was fine. I recently purchased a Razr VT and Krazr phone and when I try to pair them, it states I have an invalid passkey. Has anyone tried this and succeeded ? Will I ever be able to upgrade my phone to something besides what is listed as compatible by BMW?
      11-05-2007, 03:36 PM   #2
fijigabe0
fijigabe0's Avatar
20
Drives: 2013 F30 335i M Sport
there was a passkey that came with the documentation to your car. that's the passkey that you need to input into the phone to get it to work. look through the docs and you'll find it.
Gabe
'13 335i M-Sport
Past - '06 330xi, '07 X3 3.0si, '09 328i, '12 X3 XDrive 35i
      03-24-2008, 11:31 AM   #3
Driver8
Drives: 2007 328iC
If you can't find the passkey info in your Owner's Manual packet, look in the LH rear covered compartment for a "black box" that has labels on it. You'll find the passkey code on one of these labels with a "PH" prefix. I removed one of the labels and stuck it inside my owners manual for future reference. Hope this helps.
      04-12-2008, 03:49 PM   #4
RyanLouisville
CA
Drives: 325i Sport
That is the right spot, but it is marked with a "PK" code. It is a silver looking box with to labels on it that say Continental. Make sure that you have your key in position 1 while programming the phone, too.
Ryan
      07-16-2008, 04:21 PM   #5
bmwguy58
bmwguy58's Avatar
Drives: 2010 650i
You Know were you can look also for a Passkey for bluetooth, in the trunk. Have you ever noticed on both sides of the trunk there are two compartments that open with the little push button. Open the left one and you will discover the bluetooth hardware with the passkey on it. See if that works!--only on BMW X3
      08-31-2010, 03:31 PM   #6
ParisSF
ParisSF's Avatar
12
Drives: 2008 335i Sedan
Thanks for the tip! the PK in the trunk is actually the correct key. I bought the car as a CPO and apparently they mismatched the paperwork with somebody else as the PK I have in the user guide is incorrect!
      12-04-2010, 10:48 PM   #7
Montagoblue328i
Drives: 2007 328i
Originally Posted by Driver8 View Post
...look in the LH rear covered compartment for a "black box" ...
Where is the LH rear covered compartment for a "black box"? Thank you in advance?
      02-25-2012, 12:20 PM   #8
gopcpa
Drives: '07 X3
Pairing.....
Thanks for the advice....pairing my darned iPhone with the X3 was vexing me....however, your advice worked like a champ....who would have thought to look in the trunk, remove the side compartment door and find a the passcode there.......hmmmm, was not in the owner's manual - which I must say is completely worthless! Thanks again!
      10-07-2012, 01:11 PM   #9
Johnny the D
Drives: 2007 X3
This worked for me! Thanks!
(I picked up my 2007 X3 yesterday and the dealer told me I didn't have Bluetoooth.... but I do. Woohoo!
      12-09-2012, 02:48 PM   #10
mrsouthg
Drives: X3 E83
I can see a number of people above have paired iPhones to their X3 - Has anyone managed to pair an iPhone5?
      02-09-2013, 12:09 PM   #11
xthrunner
Drives: 2009 x3
Wow thanks for helping i had a fair share of trouble pairing my iphone with 2009 x3.
      02-26-2013, 10:09 AM   #12
Nickyboy50
Nickyboy50's Avatar
Germany
Drives: BMW X3 10/2008 E83 2.0D
Thumbs up Bluetooth Pairing
Did this today with iphone 4 instructions from Main Dealer worked first time
Ignition at ‘0’ (off)
Then push the button you see above the snap-in adapter in armrest for 3 sec
Then the ignition at position ‘1’ (push the button all the time!)
After 3 sec you can release the button
Then you have to activate your Bluetooth
The phone should find the BT and ask you to enter Code
In your manual is the code called PK with 4 numbers
Mit freundlichen Grüßen,
      03-10-2013, 12:37 PM   #13
Tryvann
Norway
Drives: 08 X3 M-sport 2.0dA
Does anyone of you know if it is possible to pair two phones to the car, and that they work both at the same time? I understand that only one phone at the time would be the able to make/recieve a call.
xbimmers
