08-27-2011, 03:21 PM | #1 |
16
Rep 68
Booming sound when shifting up in SPORT mode?
I found out that NORMAL and SPORT mode definitely have different exhaust sound when accelerating.
But annoying thing is, when in SPORT mode and accelerating hard, there is this 'booming' or 'humming' sound (that fills up the ears like low bass sound) for ~0.5 seconds while the gear automatically shifts up. NORMAL and COMFORT mode does not produce this booming sound even at high rpm shifting. Also, if you are in SPORT mode and not in high rpm, it also does not produce such sounds. Do you also have similar experience or is my car a little weird? Am I suppose to enjoy this sound since it's a V8? |
08-27-2011, 08:43 PM | #2 |
142
Rep 762
Drives: '23 BMW i7 xdrive60
You must be flooring the car a lot. I haven't heard the booming sound you're talking about.
08-27-2011, 10:28 PM | #3 | |
16
Rep 68
In fact I'm not going past 4500 rpm but I get the booming when I reach around 3000 with gear shifting up. Since its only audiable during the short moment when shifting up, my guess and others is that its got to do with the new transmission |
08-29-2011, 07:01 AM | #4 |
142
Rep 762
I haven't heard that at all unless it's barely audible. Maybe you can post a recording of the sound.
08-29-2011, 06:40 PM | #5 |
Rep 253
I have driven the new convertible less than 250 miles, so I do not suggest that I know what is going on, but I do know that these sophisticated new transmissions are controlled by chips that do a rev-match blip of the throttle on some shifts...any chance that's what you're hearing...?
Enjoyed some fun cars over the years: 1966 Corvette Convertible, 240Z, E24 L6, 300CE-24, 2004 645 Ci, 550SL, A6s, 535xi, E300/Bluetec/420, Grand Cherokee Overland, 2012 650i Coupe, 12 CL550, 13 SL550, 15 650i Coupe
08-30-2011, 12:14 PM | #6 |
16
Rep 68
Ok so here's an update:
I took the car to the BMW services and they agree there is definite booming sound when automatically upshifting in SPORTS mode, however they aren't quite sure why it's causing it, but they don't think it's something wrong cause it's doesn't sound like something's breaking or out of place, instead one could possibly enjoy the sound. well, maybe.. they will report the case to BMW headquaters. I enquired my odd sound to a very experienced mechanic who has been dealing with BMW and other german cars for a long time, and well reputated in a internet BMW community in Korea, and at once he says it's got to be something to do with that dual flap on the exhaust. It is known that the exhaust flap opens only at certain rpm's and when you accerelerate and rpm goes up, the flap opens. At this time, there is no booming sound. However when you constantly accerelerate, the car shifts into higher gear, and the rpm suddenly drops. The flap that was opened closese, and it creates a stoppage of air or whatever aerodynamics involved, and that's when you hear the booming sound. It's not suppose to be any harm to the car. However I wonder if this happens to all the 650i Converts and Coups with dual speed variable flaps or just to some? and would this sound be intended? I did try to get it on video, but with my iPhone 4, the bass sound was not recorded well and could just barely hear it. In real life, it is quite noticeble. |
08-30-2011, 11:51 PM | #8 | |
16
Rep 68
It does make the car more sportier and fun, letting me know its changing gears at a fast pace but I really got to find out if it's really intended to really stary enjoying it |
09-01-2011, 10:50 PM | #9 |
309
Rep 572
Sad your service guys don't know about this.
A throttle blip with gear changes is fairly common on many newer performance cars, not just the 6. The altered sound isn't covered in the manual but neither is the fact that switching to sport mode makes the transmission use fewer gears or that it holds gears longer. Don't worry about it, your car is OK |
09-12-2011, 03:21 PM | #10 |
123
Rep 1,781
Something BMW has been doing to all turbo engine exhausts is a raw popping/bubbling/gurgling at liftoff or when shifting. It happens on my X3 35i, my 535i loaners, the 335i, the new Z4 28i, and the x5 50i. Do not worry. When driving past people, it is a very impressive noise.
09-12-2011, 06:19 PM | #11 | |
1066
Rep 1,927
I hope BMW comes up with a fix to it. I bet the software will be updated... and problem solved... |
09-12-2011, 06:24 PM | #12 |
309
Rep 572
Definitely a different sound. I came out of an e93 335, and it didn't make this sound.
jk3355 - You're right in the description of the sound, just like a boom box in the next lane. But why are we waiting for a fix? It's a great sound, and it's not by accident. If you don't like it, keep the tranny out of sport mode and you won't have to hear it. You can set sport mode so that the chassis goes firm but the transmission stays in standard mode. |
09-13-2011, 08:30 AM | #13 | |
123
Rep 1,781
Listen to the occasional booming/popping in this video. It's very apparent. If it's not the same, then I don't know. http://e89.zpost.com/forums/showthread.php?t=575302 |
09-13-2011, 11:31 AM | #14 |
16
Rep 68
xraymd, jk3355 - definitely the same sound I'm talking about; boombox in my ear when shifting.
I tried the video juddholland mentioned on the new 4 cylinder Z4; I don't think it's the same sound. And also it's kinda hard to hear a bubbling sound on a 650i, contrary to what some others have mentioned.. Maybe I haven't revved high enough, just getting over 5000rpm as I gradually go over the break-in limits. I came across the exact same sound that I was talking about. The video's not on a 650i, rather it's on a X6M with a 6 geared M steptronic, and I dunno if it's coming from the same mechanism or not. But it's definitely the same sound at the perfect timing as I hear it, check it out: Also on a 650i, I managed to catch a glimpse of that sound. Play from 1:00 to 1:08. So I hear the same sound on an M, I am happy..? Last edited by coolhandshin; 09-13-2011 at 12:44 PM.. |
09-16-2011, 01:28 PM | #16 |
Swollen Member
23
Rep 163
I got to drive a new 650i convertible about a month ago and noticed the "bass hit" sound when shifting in sport mode only. Seems like it was only under moderate to hard acceleration. I figured it had to do with the flapper valve or possibly from turbo blow-off dumping into the exhaust tract during the shift. It was definitely distracting. My salesman didn't have much experience with the car as it was the first new 6er they'd received. He was a little startled by it too since he'd never noticed it either. Definitely strange and not something I'd like to hear all the time.
Finally delivered!!...2012 135i/AW over Coral Red/MSport/Nav/HK/Toasty Seats/6MT |
