Is anyone unsure whether Procede is putting out full power?
04-22-2007, 01:39 PM | #1 |
Rep 36
Have not had time to get to dyno, but it just doesn't "feel" like 50whp & 80-100rwtq increase. I had no error codes and installation went well. There is a definate increase in power, but I need to get to a dyno soon!!
04-22-2007, 01:51 PM | #2 |
335
Rep 7,719
I think a valid question would be do you know what 50whp gain 'feels' like? I am sure that once you get it dyno'd, it will be magically faster since your mind will see the numbers and make yourself think it's 'faster'.
04-22-2007, 02:10 PM | #3 | |
148
Rep 5,389
FWIW, when Shiv installed the XEDE in my car back in Dec., '06, my car dyno'd +57WHP and +92 lb.-ft. RWTQ (322WHP and 378 lb.-ft. RWTQ). Then, I did some timed runs using my Beltronics Vector FX1 timer and got 4.58 sec. 0-60mph and 13.12 sec. @ 106.4mph 1/4 mi. with the XEDE. After converting over to the PROcede, my best timed run thus far (and I know I can do even better ) is 4.50 sec. 0-60mph and 13.0 sec. @ 108.3 mph, timed during a 1/4 mi. run. My best 0-60mph timed run is 4.45 sec. So, without a true dyno with the PROcede, my "butt dyno" and my timed runs tell me that my PROcede-equipped 335i definitely has as much if not more HP/TQ than when I had the XEDE; or at the very least, it's faster!
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | Last edited by sflgator; 04-22-2007 at 03:17 PM.. |
04-22-2007, 02:26 PM | #4 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
I have personaly installed and dyno tested well over 100 myself and have yet to see a car that didn't pick up at least 45whp and 80hp. And many have picked up as much as 60whp and 100lbft. We always recommend dyno verification and even supply the bypass plugs to make the before and after test easy to conduct.
shiv |
04-22-2007, 02:41 PM | #8 | |
1737
Rep 17,960
Drives: A Lot
shiv |
04-22-2007, 05:32 PM | #10 |
Shadow Warrior
139
Rep 2,095
Just remove the connectors from the PROcede and put those plugs in place and you'd essentially be back to stock. Then when you want to get back to PROcede, just remove the plugs and hook the connectors back up to the PROcede for "light speed."
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods: PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar Installing soon: Rear Power Outlets (Happy Robot mod!) |
04-22-2007, 05:33 PM | #11 |
1737
Rep 17,960
Drives: A Lot
to revert back to stock quickly (without actually removing the procede harness) just unplug the procede and plug in the bypass plugs in its place. A 5 second job. You can even leave the vaccum lines coupled when u dyno.
shiv |
04-22-2007, 08:59 PM | #12 |
50
Rep 390
You could also load the stock map back in... I did this a couple of weeks ago just see what it used to be like. After re-loading the 1.4 map, there was no doubt the proceed was doing what it was supposed to.
04-23-2007, 08:57 AM | #13 |
38
Rep 1,626
That is your problem, go to shell V-power, after three tank fulls----get back to us and I bet things get to where you want them My car is stock (got no money for Proceed now) and when I went to Shell V-power, teh car seemed to get smoother, quicker and got slightly better gas mileage after about 3 tanks of it. Makes a difference!
04-23-2007, 11:11 AM | #14 |
56
Rep 1,239
ericash, i had that same exact feeling when i put my procede in. I thought I would be able to feel the power alot more. But the way the power comes on, its designed to feel like the power delivery of the car when its stock, its very linear. I also thought something might be wrong. Just to make sure, I bought myself an Escort Gt1 to confirm what times im running. That should put my concern to rest. Worse case scenario, I will get the car dynoed. I also have been using Mobil, and will be switching to Shell on my next fill up. People swear by the 93 octane from Shell.
04-23-2007, 02:13 PM | #15 |
39
Rep 1,349
There should be no confusion. The power difference is massive. I have the v1.4 software and Shell V-power 93 octane. The difference from stock is staggering. I will say this, you should let your car completely warm up so the oil temp is around 200F before your doing a lot of WOT testing. I can tell a difference between a cold and warmed up car.
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves. ~Albert Einstein
04-24-2007, 12:34 AM | #17 | |
539
Rep 18,123
04-24-2007, 01:21 AM | #18 | |
35
Rep 1,084
04-24-2007, 01:22 AM | #19 |
1737
Rep 17,960
Drives: A Lot
04-24-2007, 09:30 AM | #20 |
56
Rep 1,239
Difference should be like going from a 328 to 335? I dont know about that but mine doesnt feel that powerful, unless my car is just running like crap with the crappy Mobil gas. I still have not switched to Shell V Power, hopefully that clears it up for me. Also my car only has 400 miles, so with time hopefully it will get stronger as well. GT1 should be here by thursday, I will know then what my 0-60 and quarter mile times are running.
