Camber Kit?
08-22-2011, 02:41 PM | #1 |
Rep 61
Camber Kit?
I've got a slightly dropped e92 335i. Just installed a new set of Vredesteins on Alufelgen SF-71s (staggered; 35mm offset; 265s in the rear). Run flats were dead due to negative camber.
BTW, this is my first BMW, so thank you Parkview for not mentioning that the car was dropped and the negative camber / improper alignment would eat tires... Having learned an expensive (and potentially dangerous) lesson, I have an appointment booked with Altech for an alignment on Wednesday. So here is my question, should I consider a rear camber kit to save tires? It's an issue as I have a long commute from Richmond Hill to Oakville. For those in the know, is a rear camber kit a wise option or overkill if Altech gets it right? |
08-22-2011, 03:52 PM | #3 | |
AC
95
Rep 2,387
negative camber actually improves handling of your vehicle. however, this is done at the cost of sacrificing tire wear.
if you prefer to have longer tire life vs. improve handling, you need to remove the negative camber from the front and revert them back to stock settings. Quote:
Your Supreme Leader
08-22-2011, 04:01 PM | #4 | |
278
Rep 5,062
Drives: Black e92 335i
Negative camber up front on our McPherson struts actually makes little difference on tire wear. As for the rear, after doing my research this is the logical explanation I have come up with. Your inside doesn't wear EXTRA it wears like normal, just the outside of your tire wears LESS due to less contact.... however when you remove the tire you automatically assume that the outside is how much your tire should have worn and the inside is excessively worn. Its the Toe that causes excess wear on your cars. Set your toe in to 0 in the rear (not recommended) and give it all the negative camber you want and I don't think you'll see too much excess wear.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
