Mobile 1 5w-30 ?
08-19-2011, 12:25 PM | #1 |
battlehawk1025
44
Rep 883
Mobile 1 5w-30 ?
I dont know how big of a deal it is. I took my car in for an Oil chance. (I usually do it myself but haven't had time) anyway when my Indy shop does it. They usually used a BMW Approved oil LL (something like that). But today the tech and I made the mistake of not reading the back to make sure its a the right rating. he put in Mobile 1 5w-30. From what I have search people on the Forum are saying it's too thin of an oil. Should I be worried and and the oil?
car has 716xx miles on it. Change the Oil every 5000 miles or so |
08-19-2011, 01:38 PM | #2 |
124
Rep 5,627
Prior to BMW's switch to synthetic oil, I used 5w30 Mobil 1 in my Z3 for a few changes until BMW 5w30 syn became available. Although I wouldn't use it now except in an emergency, there were no problems.
But since you change your oil every 5k, it should be OK for normal driving conditions. Tom |
08-19-2011, 02:35 PM | #3 |
Rep 125
Oil
The issue is not that it is too thin (5W-30 is what BMW's oil is), it's that the chemical composition is different. Mobil 0-40 or BMW's Euro Castrol is what is recommended. I believe it has a higher zinc content for high pressure wear.
I would have it changed to the correct oil, for peace of mind if nothing else.
___________________
Robert |
08-19-2011, 03:36 PM | #4 | |
74
Rep 1,543
08-19-2011, 06:47 PM | #6 | |
21
Rep 780
My opinion: That would keep me up at night, it's cheap insurance, I would change non LL-01 out at the low end of 5000-7,500 miles. I change LL-01 at around 7,500-10,000. |
08-20-2011, 12:21 AM | #7 |
106
Rep 935
Those turbos are running really hot and the oil temp on the N54/N55 runs high . The Mobil1 5W-30 has much less of HTHS rating than the 0W-40. I would change it at 1000 miles or less if i were you.
08-20-2011, 03:35 AM | #8 | |
46
Rep 320
I believe one of the requirements for LL01 is a HTHS of 3.5 or greater. From what I've read, Mobil1 5W-30 has a HTHS of 3.1. The Mitsubish Evolution X is a turbo and specifies 5W-30 oil. http://www.mitsubishimotors.com/medi...al%20Specs.pdf The problem is that I'm having a hard time finding an apples to apples comparison because most cars' temperature guages measure coolant temperature. Your 335 measures oil temperature. I was trying to find another turbo with comparable oil temperatures as the 335. |
08-20-2011, 09:16 AM | #9 | |
Enthusiast
84
Rep 229
untrue
OP, if your "Indy" isn't anal enough to know before hand what he is putting in your car...I might question their overall trustworthiness. 1 run of M1 5w-30 will not hurt...but you could drain it yourself and fill it quickly enough. These cars are easy to change the oil. I wouldn't change the filter. That is what I would do if you are like me...it will stick in your mind if you don't.
_______________________________________
2016 M235i XDrive Estoril Blue/Black |
08-21-2011, 02:43 PM | #11 |
486
Rep 1,614
Why not offer to buy the correct oil and have them cover the labor to replace the Mobil currently in the car? That's a reasonable offer, and one they should be willing to accept. After all, it's their mistake, so you could be a DB about it and force them to redo the oil change.
