2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Loss of turbo boost on my 550.
      08-15-2011, 04:02 PM   #1
cidair
cidair
cidair's Avatar
Sweden
83
Drives: BMW 435d xDrive
My 550 started to act strange this weekend. No, or very little, boost pressure = very low power and torque! Engine runs smooth, revs all the way to redlineand otherwise acts normal. Check Control says " DRIVETRAIN " not full power available, drive careful, contact BMW Service partner.
Ok, so I contacted my BMW service partner and they found some fault messages in the car memory; loss of boost pressure, boost pressure sensor failure#2, possible defect on wastegate#2, vacuum hose for wastegate faulty.......... there was also a comment on checking that there was a yellow vacuum hose. Yellow? Is this someting that should have been changed on my car?
My first thought was the Hartge ECU, but I recieved a new one that I changed.
No diffrence.
Anyone else had this problem?
2016 435d xDrive
Previous:2019 M340i, 2014 335dx,2012 M5,2011 550ix,2008 M3,2007 330xd,2005 M5,2004 545iA,2000M5.
      08-15-2011, 07:11 PM   #2
marcielago
marcielago's Avatar
United Arab Emirates
12
Drives: SG F10 550i MSport, CB E39 M5
Very sad to hear this. I don't remember hearing any other cases. Been driving my 550i since February, 10K KM, no problems as of yet.
Just asking for our reference. What's your mileage?
F10 550i M-sport: Space Grey/Oyster Black
E39 M5 : Carbon Black/Caramel
E39 520i : Titanium Silver/Beige (Sold)
      08-15-2011, 08:18 PM   #3
Edman951
Edman951's Avatar
50
Drives: 2014 i3, Capparis White
Maybe a boost signal line poped off, so the ecu cut the power.
Current, i3 Capparis White, Lodge interior
Ex- F10 550i Xdrive M sport, white
Ex- trade-in 2008 E90 M3
      08-19-2011, 03:51 PM   #4
tp550i
tp550i's Avatar
19
Drives: 2011 550i Sport
any update on repairs and cause?
F10 550i Space Gray | Dinan Stage 5 | Eisenmann Race | ACS springs | 20" Ferric Grey 312 - Michelin PSS
      09-17-2011, 11:37 PM   #5
0700700
0700700's Avatar
Bulgaria
81
Drives: 745li / cls 55
any update Cidair?
2007 CLS55 AMG / 2003 BMW 745Li
      09-18-2011, 11:49 AM   #6
cidair
cidair
cidair's Avatar
Sweden
83
I left my car at Hartge this monday. They checked the ECU and wiring harness ( nothing wrong visually ), and then installed new parts. Same problem! They then removed all tuning parts, including my Supersprint exhaust - still the same problem with the car OEM!
Now the car has been at the BMW workshop for a couple of days, but they still havenīt found whatīs causing the loss of boost at low rpm / low speed!?
Different ideas from the diagnosis talks about boost pressure sensor, wastegate, vacuum hose etc etc.
So all credit to Hartge for doing a great job.
I really hope BMW will find the cause soon?
2016 435d xDrive
      09-18-2011, 11:52 AM   #7
cidair
cidair
cidair's Avatar
Sweden
83
BTW - my car has 32.000km of which 30.000km without a problem.
26.000km has been with the Hartge ECU.
2016 435d xDrive
      09-19-2011, 05:38 AM   #8
0700700
0700700's Avatar
Bulgaria
81
Wastegate is a common problem with turbo bmws... i do hope they sort it out soon enough. the 4.4TT engine isnt all that new so they should have some idea of what to do
On a side note, 30000km without a problem isnt really that good, god i miss the days of the old mercedes w124 which would go 300000km without a problem
      09-29-2011, 07:51 AM   #9
cidair
cidair
cidair's Avatar
Sweden
83
Problem solved - but it took 1 week of work. The vacuum hoses from the exhaust mufflers was not properly closed, on my Supersprint exhaust. The installation instruction didnīt even say to close the hoses!
Dust and particles was sucked in ( over a period of 20.000km ) and slowly destroyed a valve ( in the trunk ) on the way forward to the engine!!!!
This fooled the ECU to think that there was a problem with the boost pressure and therefore reducing the boost below 4000 rpm ( where the vacuum controlled valve in the OEM exhaust normally openes ). The inconsistance of the problem was caused by the valve sometimes was stuck and sometimes not, due to dust and particles blocking the valve mechanism.
2016 435d xDrive
      09-29-2011, 08:30 AM   #10
tp550i
tp550i's Avatar
19
Glad you found and solved the problem
Everyone with aftermarket exhaust - take note
      09-29-2011, 09:33 AM   #11
cidair
cidair
cidair's Avatar
Sweden
83
Really strange that Supersprint sells an exhaust without these vacuum controlled flaps, or donīt mention the importance of closing the loose hoses!
2016 435d xDrive
      09-29-2011, 04:53 PM   #12
luigimaster24
luigimaster24's Avatar
Mexico
157
Drives: 2020 X7 M50i & 2021 X6M Comp
So will this problem keep happening as long as you run the Superspint exhaust on your 550?
      09-29-2011, 05:47 PM   #13
tp550i
tp550i's Avatar
19
If I understand his description correctly - the problem occured because the factory vacuum hose that controls the stock muffler flap was left un-plugged or "open" after the Supersprint install.
This could occur with any aftermarket muffler that does not make use of the vacuum lines, I don't see that its unique to Supersprint.
This took some time to develop, but anyone running aftermarket mufflers without vacuum operated "flaps" may want to double check that the un-used vacuum lines are appropriately secured (plugged).
      09-29-2011, 07:40 PM   #14
cidair
cidair
cidair's Avatar
Sweden
83
Not if you plug the vacuum hoses properly.
2016 435d xDrive
5post
