Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > IDrive & Tire Pressure
      04-18-2007, 11:21 PM   #1
hl0m4n
hl0m4n's Avatar
2159
Drives: BMW
for people with idrive, if there is not enough tire pressure, does the idrive give you a notice?
      04-18-2007, 11:31 PM   #2
kevkaz
kevkaz's Avatar
Drives: Alpinweiss 2009 E92 M3
yes. it has happened to me once already. i put a pressure gauge on the tire that was reported to be low, it was down about 1 or 2 psi relative to the others. I was surprised that this would trigger a signal.
i'm sure the fact that the temp was well below 0 F had something to do with it. i put a little air in, reset the TPM and all was good. no problems since.
2009 E92 M3 - 7/3/09 ED, 8/17/09 redelivery
1997 E36 M3 - Track Rat
2014 Jeep Grand Cherokee Overland
      04-20-2007, 03:42 PM   #3
hl0m4n
hl0m4n's Avatar
2159
Drives: BMW
so a mesage just came up on ur i drive letting u know?
      04-20-2007, 07:30 PM   #4
vase330
vase330's Avatar
102
Drives: 19 E63S; 15.5 RangeRover ATB
Exclamation Even a Buick Lacrosse does one better!
Men this is n othing to write home about. I have a Buick Lacrosse rental from enterprise and it shows you the exact tire pressure in each tire. Cross checked it with a gauge and it was spot on! Not only that, its got real (normal) tires not run-flats. If anything BMW is behind on that one. The Buick is an absolute boat though is all I gotta say.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
      04-20-2007, 09:51 PM   #5
BK
Smiling politely
165
Drives: 330i
2006 330i  [9.00]
On the sedan, it uses the other tire pressure sensor system (FTM). All warnings show up on iDrive with a narrative explanation -- this is nice, so you don't have to figure out what the little icon means. So a warning based on the FTM also would be shown on iDrive.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
      04-23-2007, 08:30 AM   #6
hl0m4n
hl0m4n's Avatar
2159
Drives: BMW
so the pressure system is really sensative?
      04-24-2007, 04:47 PM   #7
hl0m4n
hl0m4n's Avatar
2159
Drives: BMW
is it true changing tires can void warranty as well?
      04-24-2007, 04:54 PM   #8
Brunotheboxer
Brunotheboxer's Avatar
371
Drives: 2014 Shelby GT500.
your warranty will not be voided if you change your tires provided you use german approved compressed air.
"...I maybe drunk, but you're ugly, and I can sober up..."
      04-24-2007, 05:23 PM   #9
Weaselboy
Weaselboy's Avatar
76
Drives: 2024 M340i
      04-25-2007, 12:22 AM   #10
AryoBarzan
AryoBarzan's Avatar
Drives: 2007 328i Coupe
Yes, tire pressure notification system definitely works. Both of my front tires have had low tire pressure already. It gives you a notice that tells you which tire the system has detected has low pressure and doesn't go away until you pump air. It also cautions you not to drive over 60 mph. Hope that helps
      04-25-2007, 02:51 PM   #11
hl0m4n
hl0m4n's Avatar
2159
Drives: BMW
i heard if i went with ps2s, and brought back to dealer it will void my warranty lol. does tires make that big of a difference from run flats?
      04-25-2007, 02:51 PM   #12
hl0m4n
hl0m4n's Avatar
2159
Drives: BMW
and what is that recall about bridgestone and contis btw?
      05-08-2007, 09:13 PM   #13
hl0m4n
hl0m4n's Avatar
2159
Drives: BMW
bump
