PA (philly area) + GAS dilemma
04-15-2007, 10:04 AM | #1 |
IG: krapm3
58
Rep 933
Hey guys, I already did a few searches and it seems like everyone prefers Shell over every brand. But the only gas stations available around my area does not include Shell. I did a search and they are pretty far away from me. So what gas do you guys put in your E9X?? The ones close to me are Sunoco, LukOil, BP, and WaWa brand.
2007 E90 AW 335i -ZSP/6MT- Delivered: 4/2007 SOLD: 3/2012 ETS IC - Stett CAI - AE Exhaust - UUC SS - Morr VS8 - Mtech kit IG: krapm3 2010 E90 SSII M3 -ZPP/ZTT/6MT-Found: 5/2012 Turner Testpipes/Stage 2 - Corsa Exhaust - Bilstein B16 - BBS LM - BBK - AutoSolutions SSK |
04-16-2007, 07:05 AM | #3 |
31
Rep 574
I get the highest octane in the area when I need to fill up. I am not loyal to one brand or another. Right wrong or indifferent, that is what I do.
04-16-2007, 08:18 AM | #4 |
STEVIL Empire
216
Rep 6,297
Go Sunoco...at least you can buy 91 there...
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
04-16-2007, 10:41 AM | #5 |
Recovering BMW Addict
151
Rep 1,914
Drives: <OO (|||)(|||) OO>
I primarily use Wawa 93 Octane and no issues at all.
Sign up for their credit card and get 10% back for the first 90 days. |
04-16-2007, 11:26 AM | #6 |
Rep 243
I only filled my tank once .Did at the SUNOCO with 91 octane .I am having no problems .Dont know if 93 octance make any difference to the ride but it definetly expenxive .
Awating Sexy blue 328 xi sedan black on alum , Fully looooaaaded
Ordered 2/1/07, Reordered 2/22/07, Production started 2/28/07, Production complete 3/7/07 . At port 3/9/07, On board MAERSK TEAL :rocks: 3/12/07, Reaches NY 3/23/07 and thought she will be in my arms on 4/2/07:But finally on 4/4/2007 |
04-16-2007, 12:34 PM | #7 |
1013
Rep 1,268
I use both Sunoco & Shell, and I try staying away from what is called off the rack gas or no name like Luke and Wawa. Car with Fuel injectors you should use gas with good detergent and additives, however using off the rack is ok once in a while but if you use them all the time you run the risk of gunking up your injectors. With off the rack gases you have no idea what you are getting.
But Sunoco tends to be pricy compared to others, Shell tends to be in the middle with wawa being at the bottom. |
04-19-2007, 08:26 AM | #8 |
Proficient
Rep 135
Drives: '06 325xi,step,prem,nav,cw,159
I've been using Wawa because it is on the way home. I would use shell, texaco, or bp if there were any nearby. I used to use exxon or mobil but i can't bring myself to go to Lukoil
'06 325xi - Titanium Silver, steptronic slush box, premium, cold weather, iDrive/Nav. Rubber all-weather mats, blacklines, 159s w/Conti DWS, Josh49 jack block, 40% / 30% tint.
04-19-2007, 02:09 PM | #9 |
16
Rep 791
I've seen a gas truck stop at a no name gas station and then 30 minutes later i've seen the same truck at a name brand gas station. Was at a shell filling the tanks and then was at a "Sun energy" filling up there tanks. Go figure!
04-19-2007, 02:37 PM | #10 | |
1013
Rep 1,268
Also. all fuels are the same when they come out the pipelines, the detergents and additives are mixes in at the time the tanker is filled up. This is how unbranded gas becomes branded. |
04-19-2007, 02:46 PM | #11 |
16
Rep 791
base gas is bought and swapped by many companies. It is the additives that make it BRAND specific. At one refinery you can see 6 different company name trucks lined up for base gas (Pre-Additive). Its a commodity and Oil company's swap base gas to save on shipping all the time.
So it is the additive that makes it the Brand. But Additives can build up so it is suggested that every few thousand miles you switch your brand of gas so if you go to Shell for the first 5000 miles you should then go to Exxon for the next 5000 miles. Different additives remove additive build up of other brands.......LOL! So basically Base gas is pot luck! Its the additives that you are loyally buying. |
04-19-2007, 02:48 PM | #12 | |
16
Rep 791
I go to name Brand Stations. I am paranoid! |
