Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > will suspension help with rubbing?
      04-14-2007, 07:06 PM   #1
wuufer001
wuufer001's Avatar
Taiwan
375
Drives: 2006 E90 M/T
2006 325i  [9.34]
does lowering with springs give a negative camber and will it reduce the rubbing?
      04-14-2007, 09:09 PM   #2
wj4
335
Drives: E90 manual 335i
You're rubbing with stock suspension?? If so I assume the specs of your wheels are really off.
To answer the question, if anything, it will be worst. Camber has nothing to do with lowering spring..it's just a common rule that when you lower a car, the camber/toe/cast is going to be off.
You can go in and ask for an aggressive alignment on a stock car, if you wish. That will make your camber more negative, resulting in more grip on the road and also faster tire wear.
      04-15-2007, 03:29 AM   #3
wuufer001
wuufer001's Avatar
Taiwan
375
2006 325i  [9.34]
it's because i have stock sport suspension, and i fitted with hamann HM2's with 8.5 width on the rims and i don't actually know the offset. the rears are running with 255/40/18 and they are rubbing, and i don't know how to stop them from rubbing.
