The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 335D got dynoed today
      04-13-2007, 12:05 PM   #1
peppernick
49
Drives: M4 vert
With the pending re-map, I thought I'll get before and after dyno readings for comparison.
Charlie at Surrey Rolling Road did a few runs with my car today.
The readings were pretty consistent. Because the car is an auto, only rear wheel BHP can be measured.
I would have thought the difference between crank and rear wheel BHP is around 25%. So with those figures, we are looking at 278BHP at the crank, whcih is 8BHP down from the manufacturer's quote of 286BHP.
Torque is at 335ft/lb. Again given the 25% difference, we are looking at 420ft/lb, 19ft/lb down from the manufacturer's quote of 439ft/lb.
However, the engine has only done 2500 miles.
This is the power curve printed on the brochure.
It'll be interesting to see what the new readings are next weekend at the dyno meet (at www.surreyrollingroad.co.uk) after the re-map on Monday.
Here is a video of the run. As you can see, the 335D is so silent that the engine and exhaust noise is completely overidden by the cooling fan noise.
      04-13-2007, 02:59 PM   #2
2GPP
26
Drives: E91 335i M Sport
Just wanted to say I saw the previous pics of your car also and it looks awesome...you have dome some good work there!
But is the 335d really that much better than the outgoing M3??
E91 335i M Sport
      04-13-2007, 03:54 PM   #3
peppernick
49
Drives: M4 vert
One is no better than the other. They are very different. Desirability depends on what you want from the car. Still, both very good cars.
      04-13-2007, 05:23 PM   #4
Art Man
England
Drives: 320D SE
You would expect 15% to 25% loss between the crank and the rear wheel. That said, 25% loss would be 296BHP (222.3BHP/75%) and 447ft/lb (335ft/lb/75%) at the crank and not 278 BHP and 420ft/lb.
If we assume your car is actually achieving 282BHP at the crank (although BMW quote 286BHP, that’s actually 286PS), then the driveline is “adsorbing” 23%; not to bad for an automatic, although I would have hoped BMW’s drivetrain would be more efficient, say 20% to 21% loss, which means you’re about 2% down on BHP etc, something I would put down to your low mileage.
      04-13-2007, 05:57 PM   #5
ZiM
ZiM's Avatar
22
Drives: E90 330d
I'm always reading that BMW figures are generally quite modest, a bit disapointing to hear yours isn't quite on target
when are you getting remapped? mine is next week
      04-13-2007, 07:49 PM   #6
peppernick
49
Drives: M4 vert
Next Monday 12.30pm :rocks:
I'm more interested to see the difference in 1/4 mile times and terminal speed at that. So it's Santa Pod time once again
      04-14-2007, 03:32 AM   #7
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
944
Drives: 997.2 GT3
thought the bmw figure was at the flywheel not the crank or the two figures identical????
25% sounds a bit much for a 2wd car would have thought much less 4wd usually loses that much
peppernick~: do you think you could have got into the 13's with the car in stock trim considering you were so close?
thanks
carl
      04-14-2007, 05:02 AM   #8
peppernick
49
Drives: M4 vert
AFAIK crank HP = flywheel HP
Maybe 13.8 with more practice. Honestly, the 14 was what I thought a pretty good run. With a remap, low 13s any time I would guess.
      04-14-2007, 07:45 AM   #9
dxb335d
dxb335d's Avatar
England
944
Drives: 997.2 GT3
well i might be going to the pod this weekend coming, undecided as of yet.
i managed to get a 16.6 out of a 318is before so i would say im quite a good 'launcher' so you think i might if im lucky and its a cool day get a high 13??
what was the air temp when you had your run nick??
now ive said this ill prob struggle to get into the 14's
carl
      04-14-2007, 07:55 AM   #10
Art Man
England
Drives: 320D SE
In this case crank = flywheel.
15% to 25% loss is for two-wheel drive. I would expect manuals to be nearer the 15% and automatics nearer to 25%. Can’t really comment on 4x4, not having any experience with them.
      04-14-2007, 11:13 AM   #11
dxb335d
dxb335d's Avatar
England
944
Drives: 997.2 GT3
Why are autos a higher % loss?
      04-14-2007, 02:44 PM   #12
boggysv
Drives: A4, but riding the bus for now
the torque converter sucks the life out of it (even in full lock-up) mode
      04-14-2007, 03:34 PM   #13
Art Man
England
Drives: 320D SE
Couldn't put it better myself
      04-16-2007, 03:37 PM   #14
Insider
Insider's Avatar
14
Drives: 2007 335i
The 335i has consistently put out 270-280HP to the rear wheels with auto trans. Your numbers sounds really low for a car that is suppose to make 286hp.
http://www.insiderpicks.com - The world's best stock picks.
      04-16-2007, 03:57 PM   #15
ChrisMWard
14
Drives: E93 320d M Sport, E81 116d SE
2006 120d SE  [0.00]
2007 335d A M Sport  [0.00]
1998 M3 Evo  [0.00]
2002 330d Sport  [0.00]
2004 330d Sport  [0.00]
I've had race cars of mine on different dynos in the past and they've never made the same power.
You really need a 335i on that same dyno (and ideally the same atmosheric conditions) to make a fair comparison.
Regards
Chris
Previously: 2007 335D MSport E90 Le Mans Blue, 2004 330D A Sport Silver Grey, 2002 330D A Sport Saphire Black, 2001 320D SE Touring Titanium Silver, 1998 M3 Evo Techno Violet, 1996 328i Sport Montreal Blue, 1994 325i Coupe Red, 1989 325i Sport 2 door Dolphin Grey,1986 325i SE 4 door Lachs
      04-16-2007, 05:23 PM   #16
ZiM
ZiM's Avatar
22
Drives: E90 330d
peppernicks e92 got remapped today (i know cuz i speak to simon at e-maps who's gonna do mine...) - he said the car went to somewhere between 350 and 360BHP and about 720Nm of torquey goodness
can't wait to get mine done, those are some almighty figures
i'm sure the man of the moment will be on here soon enough to tell us all how good it is
      04-16-2007, 05:46 PM   #17
mjh93sa
mjh93sa's Avatar
145
Drives: 530d
peppernicks e92 got remapped today ....
Nip over to EvoTechnik and you'll see he seems pleased
Gone: Fiesta - Focus - E46 320dSE - E91 330dMSport - E82 135iMSport - R55 JCW Clubman - M135i
Now: 530d
      04-17-2007, 02:55 AM   #18
peppernick
49
Drives: M4 vert
All done! The best mod so far for my 335D. She's a different car altogether!
:rocks: :rocks: http://www.e90post.com/forums/showthread.php?t=56727 :rocks: :rocks:
      04-17-2007, 03:57 AM   #19
silverbmwz3
48
Drives: X5 g05
Can't DMS do it without all the guinea pig and freezer bit ?
Current: E90 335d (May 2007) | Black/Black | Prof Hifi | Prof Nav | 6FL | Fully Electric Seats | Xenons | Folding Mirrors | PDC
Previous: 325ci Conv. Black/Black with lots of ACS
Previous: z3 3.0 Silver with Black&Red Leather
      04-17-2007, 02:47 PM   #20
squeezebm
40
Drives: Audi
Search this Thread:
Advanced Search
