Do you run a Cetane booster?
07-19-2011, 12:39 PM | #1 |
grand poobah
254
Rep 2,253
I've been reading that these cars are designed to run best with 50 cetane fuel. Unfortunately I can't find anything even remotely close to that here. Nothing even has the cetane rating on the pump and there are no "premium" diesel pumps. Based off what I've read that means they are closer to the minimum rating of 40.
After filling up at my local Shell station I believe it too as the car seemed noticeably louder after just a few miles. I bought some redline cetane booster and dumped in about 6oz. They claim this can raise the rating by 7 points. It must have done something because it seemed to quiet the car down considerably in a short amount of time. So what if anything are you guys adding to your fuel? |
07-19-2011, 01:03 PM | #2 |
3566
Rep 10,346
That sounds right. Higher cetane fuel will ignite sooner which leads to more complete burn which means less smoke and a tad more power and efficiency. You could also try powerservice since it's available in larger quantities which lowers you cost per dose. Also the relationship between dosage and increase in cetane isn't linear. The cetane level of the fuel prior to dosing also plays a part with how much of an increase you'll get.
07-19-2011, 01:18 PM | #3 | |
grand poobah
254
Rep 2,253
07-19-2011, 01:37 PM | #4 | |
3566
Rep 10,346
07-19-2011, 03:30 PM | #5 |
486
Rep 1,614
I alternate between OptiLube XPD and Powerservice. I haven't seen a significant difference between the 2 in terms of performance, but that might be me not paying enough attention.
07-23-2011, 02:15 PM | #6 |
32
Rep 480
if you're using powerservice it is a HUGE disservice to your engine. Have any of you ever tried burning the additive alone like on a glass plate or something before putting it in your engine? The shit is nasty and the naphta or aromatics they use to "boost" cetane artificially are going to gum up and tarnish your engine.
Natural cetane and artifical cetane do not work the same way. |
07-23-2011, 02:20 PM | #7 | |
grand poobah
254
Rep 2,253
07-23-2011, 03:17 PM | #8 | |
3566
Rep 10,346
07-24-2011, 02:19 PM | #9 |
32
Rep 480
power service cetane booster is a petroleum based product with aromatics and nitrates. These products are known carcinogens and simply increase temperatures without really increasing power.
Like socom says ethanol is an oxygenate added to our fuel to reduce CO and increase fuel mileage in the winter months and now more and more often. Unfortunately ethanol has no heat of combustion and produces no energy for propulsion therefore your fuel mileage decreases...similar to using power service. It depends what your looking for. If you want added power, you need to boost more or take in more oxygen basically with an air intake or an oxygenating fuel additve. You need to look for a detergent fuel additive that will keep your fuel system clean also. |
07-28-2011, 10:08 PM | #10 |
156
Rep 1,046
So where does this leave us? stay with a cetane rating of 40?
How else would you propose to boost it if not with PowerService?
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport |
07-29-2011, 06:46 AM | #11 | |
3566
Rep 10,346
Now I know of a guy who reconditions diesel injectors and he said that h has seen a couple which were run on powerservice and they still popped very close to factory specs after a couple of hundred thousand miles. Last edited by F32Fleet; 07-29-2011 at 06:51 AM.. |
07-29-2011, 11:51 AM | #12 |
grand poobah
254
Rep 2,253
My position at this point is I will run whatever comes out of the pump for the following reasons:
08-03-2011, 08:11 AM | #13 |
208
Rep 3,175
Below is a page taken from an independent test conducted on diesel fuel additives by Arlen Spicer. This test is not so much focued on increasing the cetane rating of diesel fuel as it is and more importantly improving the lubricity of ULSD fuel. Interesting and informative...
SPICER Diesel Specialist Join Date: Dec 2003 Location: Milwaukee, WI Posts: 829 View Photos By: SPICER iTrader Score: 0 reviews Lubricity Additive Study Results -------------------------------------------------------------------------------- The following are the preliminary results of a research study on diesel fuel Lubricity Additives. There is likely to be further commentary and explanation added at a future time. PURPOSE: The purpose of this research was to determine the ability of multiple diesel fuel additives to replace the vital lubricity component in ULSD (Ultra Low Sulfer Diesel) fuel. HISTORY: ULSD fuel is the fuel currently mandated for use in all on road diesel engines. This fuel burns cleaner and is less polluting than it’s predecessor, called Low Sulfer Diesel Fuel. Low sulfer fuel contained less than 500 ppm of sulfer. ULSD contains 15 ppm or less. As diesel fuel is further refined to remove the polluting sulfer, it is inadvertently stripped of its lubricating properties. This vital lubrication is a necessary component of the diesel fuel as it prevents wear in the fuel delivery system. Specifically, it lubricates pumps, high pressure pumps and injectors. Traditional Low sulfer diesel fuel typically contained enough lubricating ability to suffice the needs of these vital components. ULSD fuel, on the other hand, is considered to be very “dry” and incapable of lubricating vital fuel delivery components. As a result, these components are at risk of premature and even catastrophic failure when ULSD fuel is introduced to the system. As a result, all oil companies producing ULSD fuel must replace the lost lubricity with additives. All ULSD fuel purchased at retail fuel stations SHOULD be adequately treated with additives to replace this lost lubricity. The potential result of using inadequately treated fuel, as indicated above, can be catastrophic. There have been many documented cases of randomly tested samples of diesel fuel. These tests prove that often times the fuel we purchase is not adequately treated and may therefore contribute to accelerated wear of our fuel delivery systems. For this reason it may be prudent to use an after market diesel fuel additive to ENSURE adequate lubrication of the fuel delivery system. Additionally, many additives can offer added benefits such as cetane improver, and water separators or emulsifiers. CONTENT: In this study we will test multiple diesel fuel additives designed to replace lost lubricity. The primary component of this study is a side-by-side laboratory analysis of each additive’s ability to replace this vital lubricity. Additionally, claims of improving cetane, water separation or emulsification, bio-diesel compatibility and alcohol content will be noted. These notes were derived from information that was readily available to consumers (via the label and internet information) and none of this information has been evaluated for validity and/or performance. Cetane information has only been noted if the word “cetane” was used in the advertising information. The words “improves power” has not been translated to mean “improves cetane” in this evaluation. Information on alcohol content is provided by indicating “contains no alcohol”. Omission of the words “contains no alcohol” does not imply that it does contain alcohol. This information was simply missing in the information available to a consumer. However, the possibility of a form of alcohol in these products is possible. Additionally, information on dosages and cost per tankful are included for comparison purposes. How Diesel Fuel Is Evaluated For Lubricating Ability: Diesel fuel and other fluids are tested for lubricating ability using a device called a “High Frequency Reciprocating Rig” or HFRR. The HFRR is currently the Internationally accepted, standardized method to evaluate fluids for lubricating ability. It uses a ball bearing that reciprocates or moves back and forth on a metal surface at a very high frequency for a duration of 90 minutes. The machine does this while the ball bearing and metal surface are immersed in the test fluid (in this case, treated diesel fuel). At the end of the test the ball bearing is examined under a microscope and the “wear scar” on the ball bearing is measured in microns. The larger the wear scar, the poorer the lubricating ability of the fluid. Southwest Research runs every sample twice and averages the size of the wear scar. The U.S. standard for diesel fuel says a commercially available diesel fuel should produce a wear scar of no greater than 520 microns. The Engine Manufacturers Association had requested a standard of a wear scar no greater than 460 microns, typical of the pre-ULSD fuels. Most experts agree that a 520 micron standard is adequate, but also that the lower the wear scar the better. METHOD: An independent research firm in Texas was hired to do the laboratory work. The cost of the research was paid for voluntarily by the participating additive manufacturers. Declining to participate and pay for the research were the following companies: Amsoil and Power Service. Because these are popular products it was determined that they needed to be included in the study. These products were tested using funds collected by diesel enthusiasts at “diesel**********”. Additionally, unconventional additives such as 2-cycle oil and used motor oil were tested for their abilities to aid in diesel fuel lubricity. These were also paid for by members of “diesel**********”. The study was conducted in the following manner: -The Research firm obtained a quantity of “untreated” ULSD fuel from a supplier. This fuel was basic ULSD fuel intended for use in diesel engines. However, this sample was acquired PRIOR to any attempt to additize the fuel for the purpose of replacing lost lubricity. In other words, it was a “worst case scenario, very dry diesel fuel” that would likely cause damage to any fuel delivery system. This fuel was tested using the HFRR at the Southwest Research Laboratory. This fuel was determined to have a very high HFRR score of 636 microns, typical of an untreated ULSD fuel. It was determined that this batch of fuel would be utilized as the baseline fuel for testing all of the additives. The baseline fuel HFRR score of 636 would be used as the control sample. All additives tested would be evaluated on their ability to replace lost lubricity to the fuel by comparing their scores to the control sample. Any score under 636 shows improvement to the fuels ability to lubricate the fuel delivery system of a diesel engine. BLIND STUDY: In order to ensure a completely unbiased approach to the study, the following steps were taken: Each additive tested was obtained independently via internet or over the counter purchases. The only exceptions were Opti-Lube XPD and the bio-diesel sample. The reason for this is because Opti-Lube XPD additive was considered “experimental” at the time of test enrollment and was not yet on the market. It was sent directly from Opti-Lube company. The bio-diesel sample was sponsored by Renewable Energy Group. One of their suppliers, E.H. Wolf and Sons in Slinger, Wisconsin supplied us with a sample of 100% soybean based bio-diesel. This sample was used to blend with the baseline fuel to create a 2% bio-diesel for testing. Each additive was bottled separately in identical glass containers. The bottles were labeled only with a number. This number corresponded to the additive contained in the bottle. The order of numbering was done randomly by drawing names out of a hat. Only Spicer Research held the key to the additives in each bottle. The additive samples were then sent in a box to An independent research firm. The only information given them was the ratio of fuel to be added to each additive sample. For example, bottle “A” needs to be mixed at a ratio of “480-1”. The ratio used for each additive was the “prescribed dosage” found on the bottle label for that product. Used motor oil and 2-cycle oil were tested at a rationally chosen ratio of 200:1. The Research Laboratory mixed the proper ratio of each “bottled fluid” into a separate container containing the baseline fuel. The data, therefore, is meaningful because every additive is tested in the same way using the same fuel. A side-by-side comparison of the effectiveness of each additive is now obtainable. THE RESULTS: These results are listed in the order of performance in the HFRR test. The baseline fuel used in every test started at an HFRR score of 636. The score shown is the tested HFRR score of the baseline fuel/additive blend. Also included is the wear scar improvement provided by the additive as well as other claimed benefits of the additive. Each additive is also categorized as a Multi-purpose additive, Multi-purpose + anti-gel, Lubricity only, non-conventional, or as an additive capable of treating both gasoline and diesel fuel. As a convenience to the reader there is also information on price per treated tank of diesel fuel (using a 26 gallon tank), and dosage per 26 gallon tank provided as “ounces of additive per 26 gallon tank”. In Order Of Performance: 1) 2% REG SoyPower biodiesel HFRR 221, 415 micron improvement. 50:1 ratio of baseline fuel to 100% biodiesel 66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel Price: market value 2)Opti-Lube XPD Multi-purpose + anti-gel cetane improver, demulsifier HFRR 317, 319 micron improvement. 256:1 ratio 13 oz/tank $4.35/tank 3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment Gas and Diesel cetane improver, emulsifier HFRR 439, 197 micron improvement 640:1 ratio 5.2 oz/tank $2.60/tank 4)Opti-Lube Summer Blend Multi-purpose demulsifier HFRR 447, 189 micron improvement 3000:1 ratio 1.11 oz/tank $0.68/tank 5)Opti-Lube Winter Blend Muti-purpose + anti-gel cetane improver HFRR 461, 175 micron improvement 512:1 ratio 6.5 oz/tank $3.65/tank 6)Schaeffer Diesel Treat 2000 Multi-purpose + anti-gel cetane improver, emulsifier, bio-diesel compatible HFRR 470, 166 micron improvement 1000:1 ratio 3.32 oz/tank $1.87/tank 7)Super Tech Outboard 2-cycle TC-W3 engine oil Unconventional (Not ULSD compliant, may damage 2007 or newer systems) HFRR 474, 162 micron improvement 200:1 ratio 16.64 oz/tank $1.09/tank 8)Stanadyne Lubricity Formula Lubricity Only demulsifier, 5% bio-diesel compatible, alcohol free HFRR 479, 157 micron improvement 1000:1 ratio 3.32 oz/tank $1.00/tank 9)Amsoil Diesel Concentrate Multi-purpose demulsifier, bio-diesel compatible, alcohol free HFRR 488, 148 micron improvement 640:1 ratio 5.2 oz/tank $2.16/tank 10)Power Service Diesel Kleen + Cetane Boost Multi-purpose Cetane improver, bio-diesel compatible, alcohol free HFRR 575, 61 micron improvement 400:1 ratio 8.32 oz/tank $1.58/tank 11)Howe’s Meaner Power Kleaner Multi-purpose Alcohol free HFRR 586, 50 micron improvement 1000:1 ratio 3.32 oz/tank $1.36/tank 12)Stanadyne Performance Formula Multi-purpose + anti-gel cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free HFRR 603, 33 micron improvement 480:1 ratio 6.9 oz/tank $4.35/tank 13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used. Unconventional (Not ULSD compliant, may damage systems) HFRR 634, 2 micron improvement 200:1 ratio 16.64 oz/tank price: market value 14)Lucas Upper Cylinder Lubricant Gas or diesel HFRR 641, 5 microns worse than baseline (statistically insignificant change) 427:1 ratio 7.8 oz/tank $2.65/tank 15)B1000 Diesel Fuel Conditioner by Milligan Biotech Multi-purpose, canola oil based additive HFRR 644, 8 microns worse than baseline (statistically insignificant change) 1000:1 ratio 3.32 oz/tank $2.67/tank 16)FPPF Lubricity Plus Fuel Power Multi-purpose + anti-gel Emulsifier, alcohol free HFRR 675, 39 microns worse than baseline fuel 1000:1 ratio 3.32 oz/tank $1.12/tank 17)Marvel Mystery Oil Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems) HFRR 678, 42 microns worse than baseline fuel. 320:1 ratio 10.4 oz/tank $3.22/tank 18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive Multi-purpose Cetane improver, emulsifier, alcohol free HFRR 696, 60 microns worse than baseline fuel 1000:1 ratio 3.32 oz/tank $2.38/tank 19)Primrose Power Blend 2003 Multi-purpose Cetane boost, bio-diesel compatible, emulsifier HFRR 711, 75 microns worse than baseline 1066:1 ratio 3.12 oz/tank $1.39/tank CONCLUSIONS: Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association. Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel. Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated. Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant. CREDITS: This study would not have been possible without the participation of all companies involved and diesel**********. A special Thank You to all of the diesel********** members who generously donated toward this study and waited longer than they should have for the results. You folks are the best. Arlen Spicer, organizer. __________________ "03 2500 HD, Kennedy Mega Filter, STOCK PAPER AIR FILTER, Oilguard Bypass, Primrose, Baldwin Oil Filter, ARE Camper Shell, Line X Liner, Westin Nerf Bars. |
DougNBodie27.00 |
08-03-2011, 08:30 AM | #14 |
208
Rep 3,175
If anyone is REALLY interested in finding out what effect if any a commonly used cetane improver (2-Ethylhexyl Nitrate), found in such products as PowerService, has on engine durability/longevity when combined with ULSD, you can buy SAE International's test paper on the subject.
Test Summary: A 1000-hour test was conducted to determine the durability effects of 2-ethylhexyl nitrate (2-EHN) cetane improver on heavy duty diesel engines. Two identical 1993 DDC Series 60 engines were run side-by-side on a severe duty cycle. Both were fueled with a commercial low sulfur fuel. The fuel in one engine was treated with 7500 ppm of 2-EHN cetane improver. At the end of the test, engine wear and deposit comparisons were made to determine the effect of high cetane improver treat rates on engine durability. Link: http://papers.sae.org/981364/ |
DougNBodie27.00 |
08-03-2011, 09:45 AM | #16 | |
208
Rep 3,175
Certainly an argument can be made that ULSD with a lubricity additive may react differently when combined with any one of the tested fuel additives. However, I am of the belief that the addition of a quality fuel additive will enhance the lubricity of retail ULSD. The more important take-away as I see it is best summarized by Spicer below: "The potential result of using inadequately treated fuel, as indicated above, can be catastrophic. There have been many documented cases of randomly tested samples of diesel fuel. These tests prove that often times the fuel we purchase is not adequately treated and may therefore contribute to accelerated wear of our fuel delivery systems." |
11-22-2011, 05:18 PM | #17 |
73
Rep 1,770
So at the end of the day, should we or should we not run a Cetane booster?
I only see Cetane of 40-45 and its recomended 50. I'm intersted in trying out the Amsoil product. Glad a diesel can run on almost anything and are not very finicky. |
DougNBodie27.00 |
11-22-2011, 05:34 PM | #18 |
76
Rep 1,147
Drives: 02 E46M3 15 F80 M3 16 X5 35d
I spoke with Chevron while a go and according to them their diesel is rated 49 or 50 Cetane's.Can anyone verify this?
11-22-2011, 06:11 PM | #19 |
76
Rep 1,147
Centine rating by company
BP (Amoco branded), 51; Countrymark fuels Diesel-R, 50 Chevron, 49; or 51 with Techron D labels in select markets ConocoPhillips through the 76 stations (California) 47-53 PetroCanada, 47-51 BP (Powerblend 47, otherwise 40-42) Shell, 46; Sinclair, 46; Sunoco Gold, 45 (often +1-5) Sunoco regular is usually 40. Exxon/Mobile, 43-46 Holiday Stations, 40-43 HESS, 40-42, can be up to 45. Husky, 40 + diesel Max additives raise another 1-3 from there (41-45 max) Love's: 40 Pilot: 40 Valero: 40 Sheetz: 40 Flying J, 40 __________________ |
DougNBodie27.00 |
11-22-2011, 06:18 PM | #20 |
208
Rep 3,175
11-23-2011, 12:34 PM | #21 | |
grand poobah
254
Rep 2,253
In my state minimum cetane is 40 and it is not required that the actual rating be posted on pump. I'm sure some are considerably higher than others but, there is no good way of knowing. |
11-23-2011, 12:45 PM | #22 |
76
Rep 1,147
I think # are anywhere between 45 and 50
