No sounds at all in car!?
07-15-2011, 10:58 PM | #1 |
89
Rep 2,229
Drives: e92 M3 6MT/Audi A4 Prestige
I have an 06 330i e90 and recently had the car repaired due to hail damage. They did a full repaint so im sure they had to pull some of the interior out and this could be the source of the problem, but thought id check here first. When i turn on the car there is no chime sounds even when seatbelt is left off for awhile. The idrive screen is on and i can switch menus but there is no sound at all even with volume all the way up. The push to speak button also has no noise. just curious if anyone else has had a similar issue, its getting very annoying not being able to listen to music. Any help would be appreciated, thanks!
Also the car is out of warranty so id like to try other options before the dealer.
SSII E92 M3 6MT/Audi A4 Prestige/2016 Tundra Limited Crewmax
Previous: 07 BMW x5 4.8i|06 BMW 330i Sport|2015 Jeep Wrangler Sahara Ultd|2012 Mercedes C250 Sport |
07-15-2011, 11:04 PM | #2 |
1917
Rep 13,109
amplifier is in rear left trunk area
amplifier is in rear left trunk area did it get worked on
did they remove the interior to straighten dents. If you have logic 7 there is a fiberoptic connection to the amp. go to stereo sub board http://www.e90post.com/forums/forumdisplay.php?f=27 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/attach...1&d=1209780865 Last edited by ctuna; 07-15-2011 at 11:09 PM.. |
07-16-2011, 08:54 AM | #6 |
89
Rep 2,229
not sure is this something i can see without taking the dash panel apart? i will have to check it and see. Thanks
07-16-2011, 08:55 AM | #7 | |
89
Rep 2,229
thanks guys for the replies!
07-17-2011, 10:37 PM | #8 |
1917
Rep 13,109
why look in the dash panel
weren't they working on the exterior of the car mostly and the sides.
amdpifier is on the driver side trunk rear fender area. |
