Vishnu PWM Meth Kit updates
07-12-2011, 11:11 AM | #1 |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Hi guys,
We made some very small revisions on the PWM meth kit. Most of you guys probably wouldn't notice but it's worth mentioning: 1) Finally got our custom made 45 deg silicone reducer elbows. Since they are made specifically for us, we lengthened the length of the 3.25" ID leg by 2.5cm. This will give you a bit more slack when pushing in and clamping down on the charge pipe. 2) The new flow valve/flow tube assembly is shorter thanks to the boys at Aquamist. This was accomplished by integrating the coupler to the end of the flow tube. Previous design on left. New design on right. Just a little cleaner looking with 1 less joint to tighten 3) As you can see in the pic above, we are now using allen head bolts instead of pan head bolts to secure the valve assembly and pump to the mount. Just makes things a bit easier to tighten. Still using nylon locking nuts on the other side so you will still never have to worry about retightening it yourself. 4) We are putting a dab of clear silicone sealant on the valve's electrical connector. It's unlikely that there will ever be water entering that hole. But if you decide to go river crossing, at least this connector will be water tight (the mating surface already had a rubber gasket and a locking screw!). And yes, the next production batch is being built right now.... Shiv |
07-12-2011, 11:38 AM | #2 |
Rep 177
What's the expected wait time for a new order?
2008 E90 335i | PROcede Rev 2.5 | PWM Meth | CP-E FMIC + OC | AR catless ceramic DP | BMS DCI | Wavetrac LSD | MORR MonoForged VS8.2 | Michelin PSS
07-12-2011, 11:43 AM | #3 |
1743
Rep 17,960
Drives: A Lot
07-12-2011, 11:52 AM | #4 |
Rep 83
"Also unique is that this is the first available methanol injection system that is actually controlled by the tuning computer (Procede). This means that it regular injection strategies based upon a wide variety of engine controls data (intake temp, fuel consumption, throttle angle, boost pressure, road speed, etc,.) and NOT just boost like other systems."
Will this integrate (or will it ever be able to integrate) to 3rd party tuning devices? |
07-12-2011, 12:02 PM | #5 | |
1743
Rep 17,960
Drives: A Lot
shiv |
07-12-2011, 12:40 PM | #7 |
184
Rep 2,841
I think it's time for me to jump the fence and buy one of these kits!
Looks like high quality parts and full tune integration, plus it's all under the hood too. Just need to get my post-shift timing issue resolved first, otherwise there is no point in running methanol with just 3 degrees of ignition advance.....lol Shiv: can I send you a datalog on this issue? |
07-12-2011, 01:37 PM | #8 | |
1743
Rep 17,960
Drives: A Lot
07-12-2011, 02:23 PM | #9 |
112
Rep 4,771
So from what I see, it looks like the pump and flow valve can both come off the bracket.
That's good news for those running a CAI. I know I'm gonna try to come up with a mounting solution to work with my intake. |
07-12-2011, 02:27 PM | #11 |
1743
Rep 17,960
Drives: A Lot
07-12-2011, 02:46 PM | #12 | ||
73
Rep 978
I haven't done any logs yet of it, but it was really obvious and repeatable. Last week I emailed you, as you requested, but I haven't heard back yet. I resent it today to be safe. Can you please review and let me know? I've got a 2008 6MT that's stock other than the Procede, but I've done the CDV delete mod. I use 91 octane gas. |
07-12-2011, 02:46 PM | #13 |
798
Rep 4,784
No worries, summers are slow for me. Meth will be here in time for winter :woot:
ERnie
2016 BSM/f80/ZCP |
07-12-2011, 03:57 PM | #14 |
102
Rep 2,760
I have Dinan CAI and you implying this wont fit right?
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
07-12-2011, 05:29 PM | #15 | |
184
Rep 2,841
In fact, if it wasn't for the datalogs, I would barely notice the drop in timing |
07-12-2011, 05:46 PM | #17 |
112
Rep 4,771
I don't want to clutter Shiv's thread with pictures, but these two pictures show the problem:
http://www.southernbm.com.au/gallery...1/IMG_3061.jpg http://www.procedetuning.com/BMW/n54...26-unknown.jpg I would think that you could mount the pump and flow valve where the intake tract usually goes if you have a CAI, except the Dinan still uses that part too |
07-13-2011, 08:46 AM | #19 | |
Rep 476
Good work there Shiv....If that's the second batch from the pre-orders, I think I see part of my kit lying on the table lol. |
07-13-2011, 12:14 PM | #20 |
69
Rep 1,137
hate to sound like a broken record, but we need a RETRO FIT KIT for all of us loyal customers that have your original kit and can not get Labonte to fix our fail safes because they will not answer the phone or any emails!
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
07-13-2011, 02:46 PM | #22 |
29
Rep 703
did the 2nd batch orders start going out this week. i know when i talked to robert he said we would be receiving tracking numbers via email on monday but i have not received anything yet. has anyone else?
