The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > LCI Tail light retrofit coding
      07-05-2011, 12:25 PM   #1
E90PAT
SOFLO CODING
Slovenia
199
Drives: Z4M
Originally Posted by giovane View Post
For pre 2009 cars:
These are the values to change: it's different depending if the car has FRM or NFRM module.
Module: FRM
Warm test Brake
WARMUEBERWACHUNG_BL_MI -> nicht_aktiv
Cold Test Brake
KALTUEBERWACHUNG_BL_MI -> nicht_aktiv
Warm test turn
WARMUEBERWACHUNG_BLK_HI -> nicht_aktiv
Cold test turn
KALTUEBERWACHUNG_BLK_HI -> nicht_aktiv
cold rear turn signal...
KALTUEBERWACHUNG_BLK_H -> nicht_aktiv
cold brake light.....
KALTUEBERWACHUNG_BL -> nicht_aktiv
warm rear turn signal...
WARMUEBERWACHUNG_BLK_H -> nicht_aktiv
warm brake light..
WARMUEBERWACHUNG_BL -> nicht_aktiv
Brake force display
CC_MELD_BFD_BL -> nicht_aktiv
FEHLERMELDUNG_CC_BFD_L -> nicht_aktiv
FEHLERMELDUNG_CC_BFD_R -> nicht_aktiv
NFRM
[[Cold Test Brake Light]]
[[Warm Test Blinker Rear]]
[[Warm Test Brake Light]]
[[Cold Test Brake Force Display]]
KALTUEBERWACHUNG_BFD <--Cold BFD test
[[Warm Test Brake Force Display]]
WARMUEBERWACHUNG_BFD <--Warm BFD test
Here you guys go
      07-05-2011, 03:47 PM   #2
giovane
Drives: 2007 e92 335i, 2008 e70 3.0si
The FRM needs to know about the LED, otherwise they will flash really fast.
Don't remember exactly the code, but I'm sure I saw it somewhere.
      07-29-2011, 04:25 AM   #3
mihail-7007
Drives: BMW E90
Can someone link us to the coding info pls!
      07-29-2011, 07:44 AM   #4
alpina527
60
Drives: 2008 E92 M3 DCT JZB/FR
For 2009-2010 models with FRM3 module, add +MUH2 to your Vo and code the FRM
      07-29-2011, 03:13 PM   #5
mihail-7007
Drives: BMW E90
Ok , thank you very much !
      07-29-2011, 03:40 PM   #6
Elliott@DetailAddict
300
Drives: E90
E90PAT, you can do it with modified VO too.
      07-29-2011, 04:06 PM   #7
alpina527
60
Let me know how it goes. It took ages to find out how to do it
      07-30-2011, 01:04 AM   #8
mihail-7007
Drives: BMW E90
Ok , i hope it will be redy in several days
      07-30-2011, 02:24 AM   #9
alpina527
60
I noticed in another thread that you have a 2007 model. The Vo code for that year is +MUEB
      07-30-2011, 05:18 AM   #10
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
In case you need it. Here is the instruction on how to change the VO.
      10-04-2011, 12:32 PM   #11
TigerJK37
TigerJK37's Avatar
Drives: Alpine white e90
Sorry for noob Q's but why do you have to change the VO? I also have a 07
e90 with lci retrofit tail light. However I got all the error codes out but the turn signal leds dont all light up. Am I missing something such as coding to different voltage or something? Thanks
      10-04-2011, 11:42 PM   #12
E90PAT
SOFLO CODING
Slovenia
199
Drives: Z4M
Excellent! Never ended up using this but i hope someone out there, in this vast world, desperate for the answer currently googling, will come across this very thread, and make their day that much better.
(Pukes)
lol
      10-05-2011, 11:01 AM   #13
giovane
For pre 2009 cars:
Module: FRM
Warm test Brake
Cold Test Brake
Warm test turn
Cold test turn
warm brake light..
Brake force display
NFRM
      10-05-2011, 04:05 PM   #14
300
Drives: E90
^Shouldn't need to manually update if you do it the correct way.
      10-07-2011, 01:41 AM   #15
jasonn
JDM Slut
jasonn's Avatar
143
Drives: 07 e90 335i
Even with FRMFA?
      10-17-2011, 02:05 PM   #16
TigerJK37
TigerJK37's Avatar
Originally Posted by jasonn View Post
Even with FRMFA?
+1
      10-17-2011, 02:46 PM   #17
jasonn
JDM Slut
jasonn's Avatar
143
Drives: 07 e90 335i
Originally Posted by TigerJK37 View Post
+1
The answer is no. I just wanted to see Grant's response since he writes with such confidence.
I've already tested it, flashed with WinKFP using v42 files. For FRMFA just disable bulb checks.
You have FRMFA if your vehicle is pre 03/2007 build. Post 03/2007 is FRM2/NFRM.
We need a newer FRM module.
From the EAS controversy it's pretty clear we need FRM3 for +MUEB since that's what BMW requires for the official retrofit. So it's bulb check for even FRM2 let alone FRMFA.
      10-18-2011, 10:37 PM   #18
TigerJK37
TigerJK37's Avatar
OK thanks. That's what I thought too. I have another Q's. My turn signal has some LEDs that does not turn on. This is also happening to my buddies. I have code so no error come up. Am I missing something here? oh yeah mine is 07 E90 late 06 build. FRM of course.
I'm guessing its the voltage. My buddy has same year and similar build date and his does the same thing. only difference is mine is coded for bulb check and his is not.
      10-27-2011, 12:57 PM   #19
charles.soori
23
Drives: 2016 F85 x5m
I just installed my lci lights and my turn signal lights up all of them just blinks fast I haven't played around with codding yet will try that today.
      10-27-2011, 05:15 PM   #20
charles.soori
23
Just did the codding.. All you have to do is nicht_aktiv cold and warm for rear blinker
      10-27-2011, 07:17 PM   #21
300
Drives: E90
Haven't had a retrofit on an FRM module.
But I have had it on an FRM2 in an E92.
VO worked hence my "confidence" since I only speak to experience.
Sorry that seems to have rubbed you the wrong way.
Not sure why a few of your posts have singled me out since I try my best to help with DIY, regardless of my vendor status.
If you would like you can PM or email me to talk.
      10-31-2011, 09:44 PM   #22
charles.soori
23
I added +MUEH but it doesn't seem to work. i'm trying to do the factory way instead of disabling cold and warm check. Did any get this to work proper or maybe changing the voltage on it.
