Code Reader in the Triad
07-02-2011, 12:41 PM | #1 |
Rep 107
Drives: 2007 BMW 335i Sport Package
Limp mode is driving me crazy! Anytime i WOT, i get limp mode. I suspect a Vanos Solenoid problem, but i don't have a code reader to verify this. Of course the auto parts stores can't pull the codes. Is there anybody in the Greensboro, Winston Salem area with a code reader that would like to help a fellow bimmer guy out? I've removed the Vanos Solenoids and cleaned them but no change. If anyone can help me out i'd appreciate it. If you know a shop that will pull the codes for the low, that would work as well.
07-02-2011, 01:08 PM | #2 |
Rep 44
Call Tom Carr at Carr Industries. I think he has a code reader. He has done some work for me. Quality guys!! PM if you need any other help.
07-02-2011, 01:10 PM | #3 |
Rep 44
Carr Industries is located near the airport in Greensboro.
07-02-2011, 01:13 PM | #4 |
Rep 44
Quick question. When the car goes into limp mode, what is the oil temps?
07-02-2011, 02:08 PM | #5 |
Rep 107
Oil temp is normal. It'll happen as soon as i pull out of the garage in the morning and jump on the highway. If i push past 4k rpm it'll go limp.
07-02-2011, 02:18 PM | #6 |
Rep 44
Send me a pm if you need Tom's phone number.
07-02-2011, 02:32 PM | #8 |
Rep 44
They are opened on Saturday's some as well.
07-05-2011, 07:15 PM | #9 |
41
Rep 487
Not sure why Advance or Auto Zone can't pull them for you, even if it's a generic P-code. I used to go there often for mine. That will at least give you a starting point and they don't charge. I had limp mode issues at 2500+ rpms when gunning it - ended up needing all injectors replaced.
07-05-2011, 07:41 PM | #10 | |
Rep 107
I'm not sure what the problem is with their scanners. Niether were able to get anything. They just kept saying there weren't any codes. Maybe they just didn't know what they were doing? *shrug*
07-05-2011, 07:52 PM | #11 |
///M Fan
366
Rep 2,159
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
There is a different between Fault Codes and Error Codes. Fault Codes are the ones that usually start with a P and then a number like P140. Error codes are hard codes in any of the car's modules. Only BMW or a Bavarian Technic cable and a laptop can read those. That is why you can not get the code for the Limp Mode with a regular scanner, you won't period. If you were near me, I would read it for you as I have the cable and I will do it for free. But you might have to call the dealer for this. Don't know if they will charge you to read and reset the error code.
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
07-05-2011, 07:53 PM | #12 |
41
Rep 487
Are you getting any lights - SES or engine malfunction? I've heard of having codes w/o lights, but maybe your problem just isn't throwing any to be pulled. May be leading up to a code, but not enough of a problem to throw one. (?)
Side note: I purchased a reader/scanner on ebay (Innova 3130) and it reads every time. Although it only reads the generic P-codes, at least it gives me something to work with. It was $100, lightly used. You could spend $300 for a BT cable and get specific codes, but what I have is pretty useful. Lately, I've been throwing DMTL, post-cat fuel trim codes (no symptoms from car). It clears the codes as well.
07-05-2011, 07:59 PM | #13 | |
///M Fan
366
Rep 2,159
07-07-2011, 08:29 PM | #14 |
Rep 107
I was going into limp mode a few times a day. But i have good news! I went to Carr Industries today. They read my codes for me for $47. I had 2 codes, 2f6c and 30ff. They told me 2f6c was likely caused by low fuel causing the fuel pump to overheat. 30ff was a vacuum line leak. He wanted me to come back when i could leave the car to cool so they could find the leak. He gave me my reciept along with a print out of a forum post from this very forum that described a vacuum line leak placed right behind the oil filter. After coming home and ripping off everything i could i wasn't able to find the leak. I pulled the vacuum lines from the vacuum canisters and forced a few low pressure burst through them from my compressor. I heard the leak and eventually found it in the very spot described in the forum post. 2 hours and $.52 cents worth of vacuum hose later, no fault codes and a whole lot of tire smoke!! Also my wastegates have gone SILENT! A HUGE thank you to ncrzrbk for the shop recommendation!
post: http://www.e90post.com/forums/showth...ht=vacuum+line My Leak: Notice the tape the previous owner used to try and fix it.
07-07-2011, 09:19 PM | #15 |
Rep 44
Glad those guys were able to get you on the right path!!!
07-07-2011, 09:34 PM | #16 |
Rep 107
Thanks for your help man! Funny story. After getting everything back together, i went out for a test drive. As i'm jamming on the brakes at a stop sign, i realize i'm behind a 05ish Mustang GT and a riced out g35. How perfect of a situation to test out my repairs? LOL! Of course the g35 turned off, but the mustang wanted to show off. After he finished smoking his tires, he realized i was going around him! lol! I'm glad to be running full power again.
07-08-2011, 06:39 AM | #17 |
///M Fan
366
Rep 2,159
Congrats, I'm glad that you got her fixed....
07-08-2011, 11:07 AM | #18 |
Rep 44
Glad your back to full power!! Our cars are amazing when they function as they are suppose to. I am amazed at the torque when on the throttle.
08-01-2011, 11:55 AM | #19 | |
41
Rep 487
