limp mode
06-24-2011, 01:26 PM | #1 |
48
Rep 799
Drives: 08 335 silverback
limp mode
hit limp mode at 130 at around 5500 rpms on map 5 of jb4, first time i really got on it since i switched to map 5, usually run 2 it only took 45 seconds and went off, will the fuel(foul) pump act like this? i am on my third one and usually would stay on until the car was off and restarted, what other things cause half engine/limp mode
FBO...METH...BIG TWINS
06-24-2011, 02:13 PM | #2 |
161
Rep 7,377
You need to check the codes .
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
