Cobb out...Procede in...
06-23-2011, 09:50 PM | #1 |
General of the Armies
156
Rep 656
So for testing purposes I removed my Cobb, and put in a Procede v5 tonight. Tomorrow I will be heading to the track to see what the change did to my performance. On the Cobb I ran four 12.44's all at 111mph (across a temperature spread of 15deg). Since it was so consistent I will know that any change to that time I see tomorrow night will be directly related to the Procede.
If the Procede yields better 1/4mi times, I will follow up with a trip to Cobb's dyno. I put down 334hp/394tq on the Cobb... You have 24hr's to place your bets on what will happen |
06-23-2011, 10:05 PM | #7 | |
156
Rep 656
I'm not getting rid of the Cobb...I'll keep it till they release ATR and I'll have them pro-tune my car then sell the Procede (if Cobb's professional tune makes more power than the Procede). |
06-23-2011, 10:09 PM | #8 |
Secret Asian Man
80
Rep 1,723
you should plug the procede into your computer and either upgrade the maps or change the boost numbers a little higher, that's where you'll really see a difference.
out of the box, i think the enthusiast only has map 1 with boost set to around 13.5 psi, which doesn't take advantage of all the boltons on your car. you'd definitely be ok bumping it up |
06-23-2011, 10:29 PM | #10 | |
130
Rep 2,291
Its going to be close to 100 in Dallas tomorrow, again. Depending on your boost, the Procede might lower your boost slightly (because of the heat) while the Cobb might raise it (because of it). This might turn into a debate of the merits of safety vs consistency. |
06-23-2011, 10:32 PM | #11 | |
156
Rep 656
06-23-2011, 10:51 PM | #12 |
273
Rep 5,876
Turn boost up to 20psi and run ms109...with a good launch you should be in 11s if you're 6AT..more boost, more power, higher trap speed...don't run autotune at the track unless you'll run pump gas...on race gas you have full freedom to go up to 20psi, all out, you have downpipes and the FMIC, you'll be just fine
06-23-2011, 11:42 PM | #13 |
Secret Asian Man
80
Rep 1,723
The factory settings for max boost on map one are pretty low. just wanted to give you a heads up, you'll have more fun either buying the procede cable or buying a beer for someone local who has it.
06-23-2011, 11:46 PM | #14 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
Learning runs or timing drop ceilings. 113 at 12.2
06-24-2011, 01:48 AM | #15 | |
112
Rep 4,771
I'm gonna guess 12.6 @ 111 |
06-24-2011, 02:55 AM | #16 |
184
Rep 2,320
so 19 psi max with stock turbos and fbo no meth is okay? or 18 psi safest
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
06-24-2011, 04:00 AM | #17 |
79
Rep 1,617
19psi is for use with race gas!! With pump fuel 93 oct (Euro 98) and no meth you better stay within 16psi max...
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
06-24-2011, 04:21 AM | #18 |
184
Rep 2,320
noob question>>>100 octane Shell if i am going to use what psi i can use max 19 psi ?
06-24-2011, 04:37 AM | #19 | |
79
Rep 1,617
100 oct shell in europe = 94 oct in the US. Don't go beyond 16psi without meth.
06-24-2011, 05:49 AM | #20 |
184
Rep 2,320
dont want to blow engine so far my max boost was 15 psi with v5+bms dci, now installed ic so rise to 16 psi ut 40 and ic 50
06-24-2011, 06:46 AM | #21 |
65
Rep 1,705
I think that unless you can verify same peak boost level, your test will not prove anything at all. I have seen a few logs that show Cobb pushing very high boost levels. As someone already mentioned, I believe Cobb targets load, not boost, and proceed trims boost when IAT are high. On a hod day, Cobb may actually increase boost while proceed lowers it. THis could matter a lot from a safety perspective, so be ready to put your flame suit on when you post your results if you don't have datalogs and a record of boost levels from your two runs.
06-24-2011, 08:06 AM | #22 |
177
Rep 6,631
My god so many idiots.
OP, assuming the Procede is run in the same conditions as the AP stage 1, all things equal, you will run far worse with the Procede on default map settings. I suspect about 2-3 mph slower. Same goes for the jb4, but surprisingly not the jb3. There is a reason behind why people claim the jb3 feels faster and it's not placebo.
E90 LCI N54 6AT
