Burning oil help
06-23-2011, 10:53 AM | #1 |
Rep 137
Burning oil help
I have jb4 and Ar dp and uuc exhaust and noticed I am burning oil (had to add some because I got a low oil warning) and the exhaust smokes and smells like burning oil. I noticed my bov has some oil coming out of the front of it. Do I need a occ or is the turbo leaking internally?
06-23-2011, 10:59 AM | #2 | |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
06-23-2011, 11:07 AM | #3 |
51
Rep 923
The oil coming out of the BOV is from blow-by, and is somewhat normal on these cars. If you only change your oil when the service notification comes on to take it to the dealer (around 12000-14000 mile interval), you will likely have to add at least a quart between changes (at least I know I do). I would just add the quart and monitor your the cars oil usage. An OCC may or may not help with the blow-by. There is a continuing discussion as to their effectiveness on the N54. Just keep an eye on things and if you don't have to add another quart in the next 5-7000 miles I would guess you are fine.
06-23-2011, 11:50 AM | #5 |
56
Rep 1,311
If it really throws oil from the exhaust it is something major. But some people have a tendency to over-react and the vague description in OP could also apply for normal condensation and someone being sniffing in the tail pipe. If you can see a massive cloud of smoke in the mirror when accelerating this is a good signal the engine has gone south.
06-23-2011, 11:54 AM | #6 |
161
Rep 7,377
put your fingers in the tailpipes with engine on. if you got burned oil on them is major.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
06-23-2011, 11:59 AM | #7 |
56
Rep 1,311
06-23-2011, 12:21 PM | #8 |
161
Rep 7,377
06-23-2011, 12:22 PM | #9 |
Rep 137
Not a huge cloud of smoke kinda like when it is cold out and you press the gas. It does not always smoke but you can smell the burnt oil. If I take it to the dealer can I clear the codes and put the jb4 on 0 (factory setting) or should I remove the entire jb4 unit?
06-23-2011, 12:33 PM | #11 | |
Rep 137
06-23-2011, 12:49 PM | #13 |
161
Rep 7,377
what map where you using on jb4 and octane?
06-23-2011, 12:56 PM | #14 |
Rep 137
[QUOTE=enrita;9879938]what map where you using on jb4 and octane?[/QUOTE
Using jb4 I used maps 2 and 5 w 93 gas. Dci, dp, bov and jb4. Seems like maps 2 and 5 should be ok. |
06-23-2011, 12:59 PM | #16 |
This is it!!
15
Rep 672
Did you check to see if there is any leak? I had a leak near the oil filter and i replaced it several months ago.
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang. |
06-23-2011, 01:02 PM | #17 |
Rep 137
I just noticed the smoke the other day and the smell as well. Since smoke comes out of the exhaust my first thought was it is not a leak. I plan on looking for leaks after work today.
06-23-2011, 01:09 PM | #18 |
48
Rep 799
Drives: 08 335 silverback
i get a little puff of smoke every once in a while if my car is on map 2 or 5 and has been sitting at idle for a few minutes, a bmw master tech told me it was because at idle the tune causes it to run a bit rich and once you start to take off it burns the fuel and then its back to normal, it has never happened to me unless it has been idling for a few minutes
FBO...METH...BIG TWINS
06-23-2011, 01:23 PM | #19 | |
Rep 137
06-23-2011, 04:37 PM | #21 | |
153
Rep 3,730
I'm having this problem too. Usually occurs when car is warmed up and sitting idle for a few minutes (like at a red light). I will also get some smoke out from under the hood too. After installing an OCC it has caused the issue to almost stop, havn't seen it in a month or so. I'll be taking the OCC off once I install my new turbos.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
06-23-2011, 05:20 PM | #22 | ||
Rep 137
