those who have 12-17
06-23-2011, 10:12 AM | #1 |
184
Rep 2,320
hey
those that have 12-17 can you check do you have this version as here thanks
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
06-23-2011, 10:18 AM | #2 |
153
Rep 3,730
Yes, thats correct. Did you also load the proper maps?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
06-23-2011, 10:35 AM | #3 |
184
Rep 2,320
i think i had them all the time (it was shipped with 12-17 on 2011 January 9th) only now i saw that if u say its the same firmw and here u can see what i had all the time i thought what maps i have 11-25 or 12-17 looks like i have 12-17
only question is how you should know if you have 11-25 maps or 12-17 maps, watching firmw version (example in my first post?)
06-23-2011, 10:37 AM | #4 |
153
Rep 3,730
Everything looks good for 12-17, I just recently went back to those maps and have been loving them all over again!.
06-23-2011, 10:39 AM | #5 | |
184
Rep 2,320
Max boost Start Boost u can set start boost 40 or 45% as deafault is 34% Ign corr
06-23-2011, 10:43 AM | #6 | |
153
Rep 3,730
Start Boost - default, I like the power onset with 12-17 maps Ign corr - I put it at 0 when running race gas/meth, otherwise leave it default
06-23-2011, 10:45 AM | #7 |
184
Rep 2,320
will try enritas option as i dont use meth
06-23-2011, 11:56 AM | #9 |
161
Rep 7,377
i just pmed him to put UT40 IC50 max boost 16... doesnt matter with autotune that much anyway. Those UT/IC values will change for the best anyway after some WOTs runs
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
