Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > E90 Sedan Interior Door Grab Handle
      06-21-2011, 10:02 PM   #1
LT5PLA
17
Drives: BMW E90
hI,
Im from australia and i have a 06 e90 sedan. The drivers side interior door grab handle is flaking..
Is the door handle replacable? Can i buy the part and replace myself or is it kinda one peice with the door skin?
      06-27-2011, 02:46 PM   #2
rjive
weekend > work
Drives: 2008 BMW 335i
I looked on realoem at this. Looks like you can replace just the door handle. Now, keep in mind I used a North America model for this diagram, but it should be about the same
link:
http://www.realoem.com/bmw/showparts...35&hg=51&fg=50
Hope this helps
      06-27-2011, 03:24 PM   #3
Dracon
555
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
link:
Hope this helps
Well, it kinda is replaceable and kinda not.
You can buy the handles from RealOEM and you'll get just the handle, the problem is they are compression/heat moulded into the door itself. So you would need to cut the old handle off and use a heat tool to put the new one in place.
I tried this myself by just ordering the handle and found all this out the hard way.
Here's a link for reference on how it's constructed to the door.
http://www.bmw-sg.com/forums/interio...tml#post504199
      06-27-2011, 03:29 PM   #4
rjive
weekend > work
oh it looks like it just snaps in. Good info man! I'm sure this will help out the OP.
      07-26-2013, 02:00 PM   #5
executioner
Bimmer Noob
Panama
Drives: E71 2013 35i & E83 2010 2.5si
Hi , sorry to revive and old thread, anyone have a more detailed idea how to solve the problem of replacing the inside of that grab handle on the passenger side.
This is the grab handle:
Behind the door trim this is the top:
This is the bottom one:
Really appreciate your comments.
      07-26-2013, 02:23 PM   #6
RemovedUser
Guest
n/a
Drives:
Yep its a stupid design you have to melt the old on off then new one back one, I have the handle, but I'm not going to hack up a 600 dollar door panel.
      07-26-2013, 04:10 PM   #7
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
Part n*4 is very easy to replace though and gets 90% of the ugliness away usually.
      09-02-2013, 08:34 PM   #8
glachhman
41
Drives: '07 335i e90
Sorry to bump an old thread but its really easy to replace. Just use a drill to drill out the old one's 4 mounting points. Put it into place then melt down the tabs with a heated bolt or something similar.
      10-27-2013, 11:26 PM   #9
Augster
Master Gunner
77
Drives: 2008 335i Sport
I used a propane torch and an old, long bolt that had a special smooth, round head so there would be no raised lettering or ridges that could catch on the gooey plastic when mushrooming them into place. Even wearing welder's gloves I could feel the hot bolt and had to switch fingers holding it to prevent pain building up in any one finger.
It was time consuming: heating the bolt head for 5 seconds, then slowly mashing plastic mounting pin just a few seconds at a time while rotating the bolt head, then repeating steps, slowly flattening the plastic roughly 1/16" at a time, until eventually a mushroomed head seats against the door panel. Once seated, go to the next mounting pin.
I did both the passenger's pull handle and the driver's entire armrest/pull cup.
A temperature-controllable soldering iron with a wide, flat tip (preferably 1/2" or wider) would have been much easier, if I had one, as it probably could mushroom the pin in one long step, instead of the back-and-forth action using a propane torch and bolt head.
      10-28-2013, 07:26 AM   #10
glachhman
41
Or just heat the bolt until its glowing red and melt down the 4 points....
      10-28-2013, 09:20 AM   #11
Augster
Master Gunner
77
I did that with the first pin but it was too hot and the plastic stuck to the bolt head leaving nothing left to form a mushroom to anchor the pin. I let the bolt head cool, scraped the hardened plastic off the bolt head and placed it on what was left of the pin that was still protruding through the panel, then carefully torched the bolt head to re-melt the plastic just enough to bond back to the pin head. Luckily, this pin was on the screw side of the handle so I wasn't too worried of its strength.
Lesson learned: You can't use too much heat with plastic or you will suffer the consequences that I did.
      11-06-2013, 06:42 AM   #12
fl335i
fl335i's Avatar
146
Drives: 335i
^i'm here now guys. I'm thinking about a rivet or screw with washer.
'07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, Macht Schnell Downpipes, 18" Staggered 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Dinan Oil Cooler, Dinan Intercooler, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Blend V1 mount, Llumar ATR Tint.
      11-06-2013, 08:28 AM   #13
Augster
Master Gunner
77
A rivet might be better over a screw, especially for the top of the handle.
Because the mountings pins are hollow with thin walls and a large hole, screws will have to be very "fat," such as a #12 (7/32" holes) or #14 (1/4" holes). Again, for the top of the handle, the screws will have to be a short length because it cannot not penetrate into the other side as it may interfere with proper seating of the hand grip cover.
If riveting the top of the handle, it would be best to insert the rivet from the inboard side (facing the interior) to provide the flushest head to prevent interference with the cover.
In either case, you need to cut off the pin flush to the door panel.
2008 335i Alpine White Sport Sedan AT | Avant Garde M364 Staggered 19"
      11-06-2013, 09:22 AM   #14
fl335i
fl335i's Avatar
146
Drives: 335i
^ Agree. I'll trim the stubs down flush with back of the panel. Use a proper sized small rivet & rivet gun. done. Move the heck on kids. Just can't believe it's such a PITA. My handle looks terrible.
      11-07-2013, 10:26 AM   #15
RemovedUser
Guest
n/a
Drives:
Lol I have had this handle for over 3 years in my garage, I've been to scared to start hacking away at my door panel.
Maybe I should give it a shot.
      11-07-2013, 10:37 AM   #16
fl335i
fl335i's Avatar
146
Drives: 335i
^it's not that bad. Watch the Youtube video for panel removal. The rest is just some time and creativity. The top really doesn't even need rivets. It's really the bottom two that are structural when pulling.
      11-07-2013, 10:55 AM   #17
Augster
Master Gunner
77
Hmmm.... I dunno about taking such a short-cut. As I mentioned previously, one of my pins (aft one) on the top of the handle wasn't fully "mushroomed" because the plastic "head" broke off when it stuck to the heated bolt. Even though I was able to melt it back on to the remaining pin, I didn't mushroom it fully down tightly to the panel back. Now the grip handle ever so slightly rocks and squeaks (just faintly) whenever it's pulled to close the door. I may eventually go back and finish fully seating that pin, even though I'm sure no one else would notice this anomaly.
So my take away is that you should secure those pins against the panel back in some way; BMW put them there for a reason, even though there is a screw used as the primary mechanical strength, as they appear to serve a purpose to prevent rotation of the grip handle since the door panel is really just a heavy duty composite fibrous (paper-like) material and that single screw alone is insufficient to completely prevent movement in all planes and axises.
      11-07-2013, 11:35 AM   #18
fl335i
fl335i's Avatar
146
Drives: 335i
^ Agree. I'm goign to try the rivet route first.
      06-19-2014, 07:28 AM   #19
GB-335xiCoupe
Libertarian
GB-335xiCoupe's Avatar
132
Drives: 29k mi per year.
Wouldn't a strong CA or epoxy resin glue work?
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi
Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k
Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k
      06-19-2014, 07:38 AM   #20
Augster
Master Gunner
77
By itself with no other mechanical means of securing the pull strap at the relatively small contact points, I doubt it would be strong enough to endure the potentially large amount of pulling force exerted in closing the door constantly, especially on inclines downward towards the passenger side.
      07-30-2014, 01:30 PM   #21
xTaSkx
Drives: 328i
Where did you guys get the replacement part? Cant find it online.
      07-30-2014, 08:46 PM   #22
executioner
Bimmer Noob
Panama
In my pictures above you can see this part number
51419150340
It is the right handle one
http://parts.bmwofsouthatlanta.com/p...419150340.html
The stealership installed mine.
