BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Uninstalling Cobb AP
      06-21-2011, 07:48 PM   #1
hp jnkey
24
Drives: 2008 535i M-Tech
I have to take my 535 in for service and I'm wondering if it's as easy to uninstall the Cobb tune as is was to install?
I haven't had any codes or issues since I originally installed the tune.
Any secrets or special instructions?
      06-21-2011, 08:02 PM   #2
Tuner1984
1 Stock M
Tuner1984's Avatar
76
Drives: Something Slow
2003 E46 M3  [0.00]
Nope takes about 10-15 minutes to uninstall. Just plug your cobb into the OBD port and click uninstall. Just as easy to install and uninstall.
Veteran USMC/Iraqi Freedom
Current: E46 M3
Retired: 2009 E90 AW M3
Retired: 2007 E90 AW 335i.
      06-21-2011, 08:20 PM   #3
O HELLA BMW
I <3 My E93
O HELLA BMW's Avatar
180
Drives: 12” 335is vert
make when you uninstall the cobb, that you clear all your codes/shadow codes.
Bagged and Wrapped E93 335i
      06-21-2011, 08:48 PM   #4
hp jnkey
24
So you mean that installing the Cobb will automatically throw some codes that have to be removed?
Can I clear the codes with the Cobb AP?
      06-21-2011, 08:55 PM   #5
O HELLA BMW
I <3 My E93
180
well i uninstalled my cobb ap, but just to make sure i had a fellow e90 member use is OBD(or whatever its called) to check if i had any shadow codes and i did.
i had a code thats tune related so he erased it. if i were you id get the OBD cable and just check to see if theres any codes
better safe then sry
      06-21-2011, 09:00 PM   #6
EDM92
EDM92's Avatar
158
Drives: Low&Slow
That doesn't sound right. COBB claims that absolutely all codes are gone when you uninstall. Someone care to clear this up?
Montego Blue 2007 E92 335i - ZSP / ZPP / Steptronic / Logic7
Broadway Static - CCW - Megan - Orion
Instagram: bmwforlife
      06-21-2011, 09:08 PM   #7
mithiral67
That guy
mithiral67's Avatar
117
Drives: 2015 Cayman GTS
It autoclears codes after each flash, whether putting it on, changing maps, or uninstalling.
I also took my car in after having my hpfp throw a limp mode, got a new pump, no problems.
      06-21-2011, 09:28 PM   #8
EDM92
EDM92's Avatar
158
Drives: Low&Slow
Yeah I didn't think it left anything. Thanks for clearing that up.
      06-21-2011, 09:41 PM   #9
mithiral67
That guy
mithiral67's Avatar
117
yea, there are random reports that folks have seen codes after uninstalling it but those are no very common. There might be certain codes that are missed or persist as they are issues unrelated to the tune. Cobb claims they have had folks with high level equipment note that no trace has been left. But everycar, install, scan isnt the same, so who knows.
Heck, who says the BT tool is perfect? You play, you pay.
      06-22-2011, 12:25 AM   #10
hp jnkey
24
Sounds like I'm good to go.
      06-22-2011, 12:42 AM   #11
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
This ^
      06-22-2011, 01:10 AM   #12
krypt0
Your Text Here
krypt0's Avatar
Drives: E90 335i, B9S4
I've personally seen multiple codes (both fault and shadow) still visible after a complete COBB uninstall.
COBB AP "Troubleshoot" menu shows "no codes" but BT scanner shows codes (both fault and shadow)
Don't remember the exact codes off hand, but have them saved on my netbook if anyone is curious.
IIRC, they were related to COBB re-flashing the stability control/transmission module.
I would never own a BMW without a BT Scanner. Hopefully if you own a 335, you can afford to buy the cable.
      06-22-2011, 06:49 AM   #13
TLO03
16
Drives: E
Deffinately This ^ I BT scan after Cobb it dosen't get them all.
      06-22-2011, 07:10 AM   #14
mithiral67
That guy
mithiral67's Avatar
117
When did you see that last. I thought Cobb addressed the issue with the intermodule stuff?
      06-22-2011, 07:22 AM   #15
bkrM3
bkrM3's Avatar
73
Drives: E90 M3
2009 BMW M3  [9.50]
^^ +1 can anyone else confirm what happens with a BT scan after uninstall? I have to go in next week and need to figure out (soon) whether to get my car scanned based on the above.
Surely someone else has tried this.
E90 M3 Space/Fox/6MT
E92 335i BSM/Saddle/6MT - Sold
      06-22-2011, 11:33 AM   #16
krypt0
Your Text Here
krypt0's Avatar
Exclamation
Here were the Current Fault Codes found with BT Scanner immediately after a COBB AP Uninstall about a month ago. The COBB AP showed "No Codes"
D357:
DSC: No message (gearbox 186)
Error will not cause a warning light
Error is not currently present
Test conditions have been completed
Timeout
5E19:
DSC: Engine management: interface
Error will cause a warning light
Error is not current present
D356:
DSC: No message (engine 170)
Timeout
D355:
DSC: No message (engine 169)
Timeout
D354:
DSC: No message (engine 168)
Timeout
I also usually see the CF33 Transmission Fault Code after the COBB AP flashed the car back to stock (AP uninstalled)
After control module replacement, complete vehicle reprogramming, or after clearing adaptations on the engine control module, the transmission may enter failsafe mode with fault code CF33 with the description of "No message from engine management stored in the EGS module" stored. This fault code cannot be cleared. This problem is documented in BMW service bulletin SI B24 10 07.
http://wiki.bavariantechnic.com/inde...ault_Code_CF33
      06-22-2011, 12:01 PM   #17
mithiral67
That guy
mithiral67's Avatar
117
Yea, reflshed this morning an it say it's only clearing drive train codes. So I guess the update to clear all codes hasn't been put through.
      06-22-2011, 12:03 PM   #18
bkrM3
bkrM3's Avatar
73
Drives: E90 M3
2009 BMW M3  [9.50]
Mother eff. Ok, BT scan tomorrow I suppose.
      06-22-2011, 12:08 PM   #19
mithiral67
That guy
mithiral67's Avatar
117
meh, i like living on the edge
      06-22-2011, 12:11 PM   #20
bkrM3
bkrM3's Avatar
73
Drives: E90 M3
2009 BMW M3  [9.50]
but you scanned yours!
      06-22-2011, 04:36 PM   #21
hp jnkey
24
D357:
Timeout
5E19:
D356:
Timeout
D355:
Timeout
D354:
Timeout
I bought a used BT Scan tool with 2 empty Vin's , but I need to figure out how to use it.
Any tips?
      06-22-2011, 04:44 PM   #22
Litos
220
Drives: 2012 Challenger RT Junk
when i got my CEL this is what i did:
1) i checked the codes
2) i deleted the codes
3) uninstalled AP (took less time to uninstall that it did to install)
4) drove around again until the CEL came back on
5) drove to dealer
6) got car fixed
7) drove home and re-installed AP
8) wide open throttled LIKE A BOSS just to make sure everything was working fine
