New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      06-20-2011, 03:31 AM   #1
al1
Drives: z4 35i
BMS DCI
I installed the dual cone intake and drove the car about an hour or so to see how it is. Overall it is very beneficiary. It sort of minimized turbo lag between shifts and added up some power that you can actually feel. In addition, there is this really nice sound on high raves due to extra air induction.
My only concern is about the engine temperature. Before the installation, it used to sit right below 100 C but now it is up to 120 and at wot it goes maybe little bit above that. I dont know if that is going to have any negative impact, I am going to observe for a while .. but man I loved the sound it ...
      06-20-2011, 05:18 AM   #2
Constant.S
Resistance is futile...
Constant.S's Avatar
54
Drives: BMW Z4 E89(N54)
In the long run you lose power due to heat soak. It has been logged and proven in the E90/N54 section of the forums but if you like the sound the car makes and dont mind minimal power losses then stick with them
An ounce of performance is worth pounds of promises.
      06-20-2011, 05:36 AM   #3
al1
Drives: z4 35i
hmmm definitely i would mind any power loss.. but now it feels more powerful than before :S i might be wrong as well, i guess gotta see after driving it for a while
      07-05-2011, 02:53 PM   #4
sDrive35i
Drives: 2011 Z4 sDrive35i
How much power loss?
2011 BMW Z4 sDrive35i
2010 Nissan Maxima
      07-05-2011, 05:55 PM   #5
ridin135
131
Drives: Depends on the day
If you are running low boost in city driving there is a slight power loss. But you gain a good amount in high boost applications. If you run methanol you should be running the dci because the stock intake is a bottle neck.
      07-06-2011, 04:59 AM   #6
al1
Drives: z4 35i
after driving it couple weeks, i havent noticed any power loss. i drive mostly in the city for short distances and my car is bone stock except the dci...
but i gotta admit the sound of the intake is nice. it is not too loud but at high rpms it is sweet..
      07-10-2011, 07:25 PM   #7
persian54
persian54's Avatar
922
Drives: M760/G83M4
why not get a tune?
      08-21-2011, 06:46 PM   #8
335iJWC
24
Drives: JB 335i-M3
2008 BMW 335i  [9.00]
Tune it! and youll definetly make use off the DCI.
      09-01-2011, 09:57 PM   #9
z4z4z4
z4z4z4's Avatar
45
Drives: 2002 M3
Doesn't hurt to provide some additional fresh air to the DCIs.
http://performanceunlimited.com/cobr...n/ductfan.html
The smallest fan ( I have not purchased yet) will help with a delivery of 140 cfm. Again, it doesn't hurt to provide more fresh air, whether you "pump" it to the filters or allow ram-effect at speed. Increase of air mass is the power provider and the FMIC is in place to handle the real heat load.
Sold 2011 Z4, kept 2002 M3
PM for various e89 parts 4sale.
      09-02-2011, 08:52 AM   #10
ZheHbKa
ZheHbKa's Avatar
78
Drives: the Wind
2014 BMW 335 Xi  [10.00]
cool setup, how stable is the hose by the intake side?
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      09-02-2011, 10:58 AM   #11
z4z4z4
z4z4z4's Avatar
45
Drives: 2002 M3
Thanks for naming it "cool set-up". The 8" collector at the inlet has a bracket attached to the 10mm bolt for one of the horns and there is foam around top, bottom and outboard sides of collector. Stable. I set a fan on the ground in front of the inlet and was encouraged with the 2 1/2" hose flow.
zpost
