CDV / bms clutch valve
06-19-2011, 10:54 PM | #1 |
28
Rep 95
Thoughts on the clutch delay valve (CDV).. As well as the BMS Modified Clutch Valve.??? Purchased the BMS modified clutch valve, waiting for it to be shipped...was cheap so may aswell get it..
06-19-2011, 10:59 PM | #2 |
127
Rep 6,773
CDV is a great mod..get rid of the 1-2 shift jerkiness...i did w a short shift kit and it transformed the shifting..
06-19-2011, 11:00 PM | #3 |
28
Rep 95
06-19-2011, 11:47 PM | #6 |
68
Rep 1,943
Just delete it. No need to put one in place.
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
06-20-2011, 12:16 AM | #7 |
127
Rep 6,773
06-20-2011, 12:54 AM | #8 |
115
Rep 1,544
Drives: '22 i4 M50
My modified one still gets jerky 1-2 shifts occasionally. I probably just suck at driving haha. Any specific differences between different CDV brands? I got mine from BavX but don't know what they gave me actually.
2022 i4 M50, Dravit Grey. fully loaded minus the carbon fiber bits and 20" wheel package
2007 E92 335i, 6MT, Sparking Graphite, ZPP, ZSP, Nav, Logic7 (Sold) |
06-20-2011, 03:25 PM | #9 |
127
Rep 6,773
Yea its not a complete cure all but i could def feel reduced jerkiness on the 1-2 w/ the modified CDV..Its the nature of the gear box and clutch engagement on this car..dont be afraid to man handle it..lol
06-20-2011, 08:40 PM | #10 |
11
Rep 529
You can also buy an OEM CDV and just pop out the orifice with an allen wrench. That is what the majority of vendors are doing and then marking up the price.
Part #13 ($8.27): http://www.realoem.com/bmw/showparts...08&hg=21&fg=10 |
06-21-2011, 01:42 PM | #11 | |
127
Rep 6,773
http://www.zeckhausen.com/CDV.htm The solution is to replace* the CDV with a modified valve which has had the interior parts carefully removed. We do not drill these valves. Drilling will damage the taper at both ends of the valve. The male tapered end seals against the female taper of the clutch slave cylinder. And the male hydraulic fitting seals against the CDV's tapered seat at the female end. It does not seal via the threads. Drilling a CDV will cause it to leak and may also leave bits of metal behind, potentially damaging the delicate rubber seals in the clutch hydraulics. We have developed a technique for removing the interior valve and spring without damaging the tapered seat at the female end and without touching the taper on the male end. . |
06-21-2011, 02:11 PM | #13 | |
290
Rep 28,154
they are referring to the e46 style that needs to be drilled, the e9x ones are plastic, and the restriction plate is just held in place by spring force from 4 fingers on it, so it just pops out, blow it out with some air just for safe measure and its ready to go |
06-21-2011, 02:22 PM | #14 | |
65
Rep 1,708
06-21-2011, 04:42 PM | #15 | |
11
Rep 529
By the way for others that haven't done this, one gentle tap with a hammer on the end of an allen wrench is all it takes. |
06-21-2011, 10:36 PM | #17 | |
"J" BONE
24
Rep 578
procede v5 rev3, afe dual cone intake, full catless exhaust with muffler delete, hm style carbon fibre lip, 235/35/19,275/30/19 satin black linea corse818, H&R sport springs, Vishnu charge pipe with forged diverter valves, matte black kidneys, mtec superwhite angel eyes and fogs, bms cdv ER fmic, VRSF coated DP. Vishnu pwm meth kit
