lag on shift - 6mt
06-19-2011, 07:50 AM | #1 |
Rep 25
lag on shift - 6mt
hi all,
tried search but it didn't bring any positive results. i have 2007 335 6mt, jb4 installed. when I'm running on stock or 5 map (doesn't matter) and shift from 1to2, or any other gears, I'm having lag. is there any fix for this issue because it really annoys me, I like when rear wheels are getting drifted on shifting with full throttle. |
06-19-2011, 08:02 AM | #2 | |
57
Rep 1,054
...and I manage to get rid of it when I changed to PROcede. |
06-19-2011, 08:31 AM | #3 |
141
Rep 2,604
Drives: G80 Comp XDrive
I have shift bog with Cobb as well, only solution I have found is not shifting as fast.
06-19-2011, 09:35 AM | #5 |
This is it!!
15
Rep 672
Try to shift slower or change to Procede or Cobb....
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang. |
06-19-2011, 09:39 AM | #6 |
57
Rep 1,054
06-19-2011, 12:21 PM | #8 |
177
Rep 6,631
To be fair, I bogged on both a JB3 and Procede. It's one of those things you can't do much about at this time until ATR comes out.
E90 LCI N54 6AT
06-19-2011, 12:23 PM | #9 |
台灣 台北市
88
Rep 1,267
Drives: 2009 GT-R Premium
what is ATR?
06-19-2011, 01:51 PM | #11 |
141
Rep 2,604
I deleted mine so you can rule that out.
06-19-2011, 03:17 PM | #12 |
Rep 332
Drives: F30 340i Xdrive
Mine is the opposite, I use to have that lag on stock shifting from 1 to 2.
Now with the JB4 and the new FW that is gone. Same config as you with CDV delete. Last edited by gsmurf; 06-19-2011 at 03:26 PM.. |
06-19-2011, 03:57 PM | #13 |
84
Rep 1,575
Guys...have you ever thought that this issue is not tune-related ?
I'm under the impression that this is a clutch issue. I personaly noticed that this is only happens when the clutch is overheated (due to traffic or intensive driving). I also experience minor clutch slipping. All the 6MT i know , has the same issue
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
06-19-2011, 04:05 PM | #14 |
127
Rep 6,773
GIAC no lags here..i have the modified CDV..and it helped alot with the 1-2 shift jerkiness on stock CDV...this does nothing for the lag the OP describes.
06-20-2011, 01:03 AM | #16 |
112
Rep 4,771
All 335i manuals bog a little. Take it from someone who has driven a lot of good manuals. you can definitely improve it but you won't ever get it perfect. At least IMO
06-20-2011, 01:52 AM | #17 |
65
Rep 1,708
the bog, most often, is timing retard. it happens stock also when the weather is hot, especially with 91oct. You have to dial down boost to reduce it.
06-20-2011, 03:15 AM | #18 |
242
Rep 2,781
Drives: E90 335i Racecar
I don't know how hard you are shifting, but getting a perfect 1-2 shift is extremely hard and even more difficult when you are putting down more power. I have never experienced this "bog," but your description is slightly ambiguous. Do you feel a lag in the clutch engagement or releasing of the clutch or the differential? There are soooo many variables. Care to elaborate?
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ | NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>> |
06-20-2011, 06:33 AM | #19 | |
196
Rep 2,669
You guys saying you have to switch to PROceed is incorrect.
I was in a 08' 335 with a V5 last sat. night and it bogged once too.. Quote:
06-20-2011, 06:38 AM | #20 |
177
Rep 6,631
To be fair, both the JB3 and Procede bogged on my car on high boost. It just wasn't as bad on the Procede.
Both didn't bog at boost levels up to 15-16 psi and was worst on the 2-3 and 3-4 shifts.
E90 LCI N54 6AT
06-20-2011, 08:22 AM | #22 | |
AC
95
Rep 2,387
Try Dinan. just had it installed last week and the shift (especially 1-2) had improved (no CDV delete).
I believe it's the way they changed the ECU throttle mapping. Besides removing the "drive-by-wire" throttle lag, they also continue to give the engine a little more gas when you life-off the throttle, this is very subtle but it actually prevents the fly-wheel from slowing too much until you get it into the next gear. The drivability of Dinan is better than BMW stock and I believe the amount of testing and re-calibration is what makes them more expensive than other tuners. Quote:
Your Supreme Leader
