Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > HPF 135i/335i Oil Catch tank
      06-17-2011, 06:57 PM   #1
HPF David
HPF David's Avatar
Drives: TBA
Thumbs up HPF 135i/335i Oil Catch tank
HPF 135i and 335i Oil Catch Tank
There is very little room in the BMW engine compartment to fit an oil catch tank and we've dialed in the perfect spot whether you have a supercharger, turbocharger or are normally aspirated. A unique feature of the HPF oil catch tank for the 135/335 applications is the easy snap on installation of the hose fittings. There is no cutting or modification required to any factory hose to achieve perfect fitment.
The HorsepowerFreaks oil catch tank "kit" is a great way to keep oil blow-by from lowering the octane rating of your fuel. The crank case pressure on boosted and even non-boosted motors will often exceed ambient air pressure outside the engine. This causes the oil vapors to leave the engine and enter the combustion chamber. These oil vapors can lower octane ratings by as much as 2 points.
The plug-n-play oil catch tank by HorsepowerFreaks uses large 10AN fittings along with high temp oil resistant hoses to allow this pressure to quickly and easily flow out of the engine without restriction. The oil vapor hits the densely packed coil area inside the catch tank where the oil is separated from the air allowing the air to be burned safely by the engine and allowing the oil to accumulate so that it can be easily re-used. This oil catch tank is located in a safe place away from heat using the mounting bracket provided. The main oil catch tank simply twists off by hand just like an oil filter and allows you to safely pour the oil back into the engine.
Kit Includes:
  • Billet Aluminum CNC adapter fittings
  • Catch Can with CNC Bolt on bracket
  • Crank case over-pressurization evacuation lines
  • All Necessary Hardware for installation
Easy Snap-in Installation
  • Direct Snap-in fitment without modification to factory crank case ventilation system
  • Simply detach the factory crank case hose from the intake manifold and snap the included adapters into the factory hose fittings.
MSRP: $499.99
      06-17-2011, 07:02 PM   #2
///M3THOD
///M3THOD's Avatar
117
Drives: 991.2 GTS
As always, your product looks well engineered and fabricated.
BUT.. 500 dollars for an oil catch can?!?
2014 Individual /// M5 Competition AW/AB
|| Vorsteiner FF-103 || BMS JB4 || Meisterschaft GTC || RPI || IND || Challenge ||
      06-17-2011, 07:04 PM   #3
onesuperboi
onesuperboi's Avatar
52
Drives: '08 e92 335i COBB 4.01 Stage 1
Does this actually work?
It seems to me that the past complaints about the oil catch cans is that they are too close to the hot parts of the engine, and therefore the blow-by does not get cooled and condense in the catch can. Your placement is right next to the hottest part of the engine bay; near the turbos.
      06-17-2011, 07:07 PM   #4
Rotorocious
Rotorocious's Avatar
103
Drives: 335xi
Wow
      06-17-2011, 07:09 PM   #5
mke135i
mke135i's Avatar
19
Drives: 2008 BMW 135i Cabrio
2008 135i  [0.00]
That's some expensive oil lines and fittings!!!
      06-17-2011, 07:20 PM   #6
Tuner1984
1 Stock M
Tuner1984's Avatar
76
Drives: Something Slow
2003 E46 M3  [0.00]
Wow 500 for the same thing a bsh or riss racing occ does. I love the hpf e46 m3 but I think ur price is to high. Are u charging everybody 200 plus extra for the lines and hardware?
Veteran USMC/Iraqi Freedom
Current: E46 M3
Retired: 2009 E90 AW M3
Retired: 2007 E90 AW 335i.
      06-17-2011, 07:23 PM   #7
mithiral67
That guy
mithiral67's Avatar
117
Drives: 2015 Cayman GTS
HA
2015 - Cayman GTS - Stock
2011 - 335is e92 - Cobb PTF E40/Rob - Beck/AR/Helix (458 rwtq and 479 rwhp) - Retired
2007 - 911 Turbo - EP1/AMS (617 awtq and 500 awhp) - Retired
2008 - 335i e92 - Cobb/AR/Helix/OSS (384 rwtq and 356 rwhp) - Retired
      06-17-2011, 07:24 PM   #8
Slops
Slops's Avatar
South Africa
188
Drives: 2005 C55 AMG
Umm very nice piece but I'll swallow really hard if I have to buy one of these!
      06-17-2011, 07:25 PM   #9
acdHQK713K
acdHQK713K's Avatar
231
Drives: Car
$500.
Does it come with lube?
      06-17-2011, 07:52 PM   #10
dlbrooks18
dlbrooks18's Avatar
161
Drives: e90 335i
Nice!
2008 E90 335
      06-17-2011, 08:29 PM   #11
cn555ic
cn555ic's Avatar
441
Drives: 335i
I would buy this in a heart beat...Just need to go back and adjust the price which I think about 300 would be just right and I would pull the trigger.
      06-17-2011, 09:14 PM   #12
ridin135
131
Drives: Depends on the day
Damn and I think 200 is way overpriced.
      06-17-2011, 09:15 PM   #13
lamia2super
lamia2super's Avatar
142
Drives: 335i
2007 335i  [10.00]
+1 $200 would be my max
      06-17-2011, 09:28 PM   #14
mycoupe
55
Drives: 07 335i coupe 6spd
Did you guys even try to test this thing?!?! We've already concluded through dzenno's test data that 5/8" lines do cause a restriction and increase crankcase pressure, not relieve it! Also, you guys are idiots for the placement. It's already a small occ and you went and put it in the hottest part of the engine bay. I bet it doesn't catch an oz. of oil. With the 17 page thread specifically about crankcase pressures and the effect of OCC's on them, you guys are morons for making this product and not providing mounds of test data to show it works and isn't harmful.
      06-17-2011, 10:19 PM   #15
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
+1. Ridiculous! So instead of HPF delivering a charge pipe and a turbo kit like they've promised April of LAST YEAR, they sat around and fucked with a stupid OCC with asking price of $500.00
Wow! Just wow!
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      06-17-2011, 10:24 PM   #16
dzenno
273
Drives:
Another total BS catch can...please stop marketing these to the n54 community without ANY crankcase pressure data...and look at the PCV thread and data on crankcase pressures on high boost n54 engines...
I wouldn't mind paying a premium for an OCC provided you have adequate data and can show thar you've actually done flow testing before/after with this can with DATA...
If you don't have any data then maybe you could use some blowby pics off VW/Audi engines like some other vendors :mad:
I respect HPF for their e46 work but man these OCCs I'm really sensitive about, little too sensitive LOL
      06-17-2011, 10:33 PM   #17
mycoupe
55
Not to mention it's small as hell and has no way to visually check the oil level inside! Must be because they know it won't actually catch any!
      06-17-2011, 10:33 PM   #18
Forcefed3
No_Country
127
Drives: 2008 335i
2008 335i  [1.00]
Pics?
      06-17-2011, 10:37 PM   #19
AhmEd_B_Stylin
AhmEd_B_Stylin's Avatar
Drives: BMW 335i
Looks very well made , Penn will buy it
      06-17-2011, 10:40 PM   #20
Forcefed3
No_Country
127
Drives: 2008 335i
2008 335i  [1.00]
I would sell my BSH OCC and pick this one up if it was a little cheaper.
      06-17-2011, 10:49 PM   #21
vasillalov
vasillalov's Avatar
1121
2023 BMW M3  [0.00]
Originally Posted by Forcefed3 View Post
Pics?
Dude, what is it with your computer? Almost every other thread you are asking where are the pictures? Fix your damn computer! LOL There are 4 pictures in this thread from HPF.
      06-17-2011, 10:50 PM   #22
cstmx_ryder
cstmx_ryder's Avatar
164
Drives: A metal box with a roundel
I think they're just throwing shit at a brick wall.....eventually some will stick.
'08 AW E90 335i
PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10
