Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Misfire at Idle?
      06-17-2011, 12:56 PM   #1
Streetluger06
11
Drives: 2007 335i coupe
2007 BMW 335i  [0.00]
Misfire at Idle?
My car has been misfiring lately at idle and I am looking for suggestions on how to alleviate it. I recently put downpipes on and changed my turbos for better condition stockers. I don't recall having this issue before I tore into my car. When I run it through the rpms it doesn't seem to have any issues.
I replaced my plugs less than 2,000 miles ago with new factory ones. I just finished running 2 treatments of techtron through my injectors. Two weeks ago I had my HPFP replaced under the recall and that cleared up a 6th cylinder misfire I had.
When idling I hear a poping/pinging sound coming from the downpipe/turbo area that seems to happen randomly. There are roughly 10 misfires a minute. I do not have any check engine lights coming on but it still is bugging me that its not running properly. My car is a 2007 335i and has 67,000 miles on it and to my knowledge has never had the valves cleaned or the injectors replaced. I am running amsoil synthetic with less than 2,000 miles on it.
Could my misfire be caused by carbon build up on my intake valves?
Is this normal and I am just not used to it since these downpipes are new to me and the stock cats would typically absorb the sound?
      06-17-2011, 02:16 PM   #2
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Spark plugs, Injectors, Coils, HPFP?
Mike
      06-17-2011, 02:19 PM   #3
s2k_335i
This is it!!
s2k_335i's Avatar
No_Country
15
Drives: FBO 335i without meth
Do you have procede? If so try a different map. Also try to change your spark plug. I had misfire last year and the spark plugs took care of the issue.
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang.
      06-17-2011, 02:34 PM   #4
gsmurf
Drives: F30 340i Xdrive
Check your spark plugs again.
      06-17-2011, 03:25 PM   #5
jdbretz
jdbretz's Avatar
51
Drives: '18 X5d, '12 M3 ZCP, '12 F30
Are your misfires all on the same cylinder? Is it storing a misfire code, or are you just saying it sounds/feels like a misfire?
      06-17-2011, 03:42 PM   #6
Streetluger06
11
I have tried three different map releases including 12-17 with the same issue and same frequency.
I will check my spark plugs again to see their current condition and post my findings.
I do not know which cylinder the misfire is on but I can clearly hear poping coming from the turbo/downpipe which I have corrolated to being unburnt gas igniting from the downpipe and turbo temp, does this sound right? I do not have any codes on the procede to help guide me.
Also it seems to be more prominent when the engine is warmed up.
I will also try swapping coils around to see its effect and report back.
HPFP should be good since it was just replaced but that's not always the case. No codes are making me think its the injectors but maby, no real way to check that.
      06-17-2011, 04:47 PM   #7
tibra1
No_Country
127
Drives: 2011 ZCP M3 - 2007 335i crashd
Curious how u have all those misfires and no misfire codes or limp mode..does your piggy suppress the codes?? are you sure they are misfires..n not something else going on
I had one misfire then codes and limp immediately thrown..swapped the coil packs from bank 1 to bank 2..cleared the codes n the problem didnt reoccur..
      06-17-2011, 05:14 PM   #8
Brey335i
112
Drives: e46 ///M3
Did you plug your o2 sensors back in? I knew a guy who forgot and the small open hole in each downpipe made the car sound like a boat at idle and those noises could easily have been mistaken for misfires.
Just a thought...
      06-17-2011, 05:19 PM   #9
Streetluger06
11
Ya I have all 4 sensors in my downpipes. They made it a pain to get the downpipes in!
I'm pretty sure its a misfire, I can feel it when I'm in the car also.
Its like the engine is stumbling, it shakes a little each time it happens then returns to normal idle. I'll check to see if the procede is covering a code up but I don't think it would erase that kind of a code.
What else could it be?
      06-17-2011, 07:09 PM   #10
Brey335i
112
Drives: e46 ///M3
This is strange... the Procede wouldn't delete a misfire code. But it does sound a lot like a misfire
      06-17-2011, 07:23 PM   #11
acdHQK713K
acdHQK713K's Avatar
231
Drives: Car
I have the exact same problem. As the car starts to warm up and the idle RPM begins to drop it stumbles and shakes the car. All of this while in park in my driveway. Once it settles at around 600 RPM it's fine.
No misfire codes, no stumbling while on throttle. No popping noises. I have no explanation for it either. Spark plugs have <3k miles on em.
      06-17-2011, 09:54 PM   #12
tibra1
No_Country
127
I have this too on cold start only..like u hear the engine mis here and there but like u as soon as the idle settles down..no issues..i am pretty sure this is normal
I think the OP has issues at idle even fully warmed up???
      06-17-2011, 09:57 PM   #13
acdHQK713K
acdHQK713K's Avatar
231
Drives: Car
Mine was a new phenomenon about a month ago. Doesn't bother me, just odd.
      06-17-2011, 10:02 PM   #14
tibra1
No_Country
127
Really I have had it since mile #1....i def dont like it and stare eagerly at the dash just waiting for a code to pop up..LOL
      06-17-2011, 10:06 PM   #15
acdHQK713K
acdHQK713K's Avatar
231
Drives: Car
This car likes to ruin my weekends with bullshit codes
      06-17-2011, 10:36 PM   #16
s2k_335i
This is it!!
s2k_335i's Avatar
No_Country
15
I been having Procede for a while now. I always have the code for misfire. I am not sure why your Procede does not have a code.
      06-17-2011, 10:38 PM   #17
tibra1
No_Country
127
So your sayin its normal to have misfires w Procede..>????
      06-18-2011, 12:25 PM   #18
Tzu
29
Drives: 335i
I had idle stumbling. I cleaned my valves, stumbles/misfires at idle are gone.
      06-18-2011, 12:36 PM   #19
s2k_335i
This is it!!
s2k_335i's Avatar
No_Country
15
You misinterpret my comment. I have Procede and I know when I have a misfire because my laptop tell me so....
      06-19-2011, 02:59 PM   #20
pzco
Drives: 2007 alpine white e92
my car stumbles about once every ten seconds or so at idle. not sure if misfire does it even after warm up.
