Car keeps going through injectors - thoughts?
06-17-2011, 08:19 AM | #1 |
73
Rep 1,388
07 335i - 60,900 miles (CPO, extended maintenance), have owned it since 30k miles
It has had (among other things) a set of plugs, 3 coils and EIGHT injectors in the 2 years I've owned it. The first time the injectors were replaced it was all 6, which was fine for a while (and this was the new part # injector...well before the recall happened). More recently, injectors were replaced on cylinders 5 and 6. Yesterday on the highway I got a misfire, checked the code, misfire cylinder 4. SES light stays lit after several cycles. Gas has always been 93 octane Sunoco, rarely anything else. All misfires have been experienced with NO TUNE, including the one yesterday. I know injectors go bad on this car...but eight of them (now possibly 9) in 30k miles? I feel like this shouldnt be happening this much. When I get the misfires it's generally highway speed, taller gears, with mid-rpm high load situations (e.g., in 4th, step on the gas at under 3k rpm, boost starts to build...hesitation...shake...SES light). Getting really fed up with it. Is it possible the BMW software is just that bad? When I've had the COBB installed I have had 0 issues. Any advice would be much appreciated.
E90 M3 Space/Fox/6MT
E92 335i BSM/Saddle/6MT - Sold |
06-17-2011, 08:46 AM | #2 |
76
Rep 1,883
I'm at 12 new injectors in 48k miles....
How you describe the misfires occurring is exactly how it starts for me when one (or many) are going bad. It usually will get easier and easier and start misfiring in the shorter gears as they get worse.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
Last edited by GeorgiaTech335coupe; 06-17-2011 at 08:46 AM.. Reason: remembered I had just replaced another |
06-17-2011, 08:49 AM | #3 |
49
Rep 238
12 new injectors in 20k miles, here :-)
And 6 coils, 4 HPFPs, deep cleaning of valves, new valve cover/gasket, plugs, ..... My symptom was rough idleing/lurching at low RPMs.
'07 E90 335i Jet Black // Navi // Logic 7 // Premium Pkg // BMW Performance Springs, Shocks, Struts // M3 Front Sway // JB4 Tune // BMS Drop-In Air Filter // Blacklines // M3 Spoiler Lip
06-17-2011, 08:52 AM | #4 | |
73
Rep 1,388
Still concerning though that, even though you've had 12 in 48k miles, if I end up having 9-12 in 30k, that's still 18000 miles sooner than yours gave out.
06-17-2011, 08:56 AM | #6 | |
73
Rep 1,388
My idle is often rough as well. I can feel it shaking in my butt lol. Feels like a piece of garbage.
06-17-2011, 08:58 AM | #7 |
73
Rep 1,388
My friend just ordered a 2011 328 msport (E90). First thing I thought was damn, that's so awesome he wont have to go to the dealer every 2 months for engine lights.
Pretty sad actually.
06-17-2011, 09:04 AM | #8 | |
292
Rep 2,898
Neil |
06-17-2011, 09:25 AM | #9 |
5453
Rep 8,815
I wouldn't think so since the injectors are constantly firing into the cylinder after the valves.
I am wondering if running a bottle of Techron gas treatment would help you guys assuming its not misfires due to carbon build up in the valves. I know i felt my idle started to have a small stumble after 10K miles and after pouring in a bottle of techron (same as the bmw stuff) the stumble went away completely.
06-17-2011, 09:32 AM | #10 | |
292
Rep 2,898
Neil Last edited by MDORPHN; 06-17-2011 at 09:50 AM.. |
06-17-2011, 09:52 AM | #12 |
73
Rep 1,388
I wonder if it is possible for a misfire to be caused by carbon buildup in the valves and, if so, whether there's any way to tell if that's the problem instead of an injector. If all the code says is "misfire cylinder 4," that isn't super helpful in getting to the root of the real problem, especially if new injectors make the problem go away for a little while regardless of a bigger underlying problem.
Anyway, even if it's not carbon buildup I think there must be something else going on...injectors shouldnt be going bad with this frequency on decent gas.
06-17-2011, 10:12 AM | #13 |
102
Rep 2,760
My car has 28K miles too and been through a set of injectors too. Nothing unusual about that in these cars. Its a Sep 07 Build 335i. In addition to that have had 3 HPFPs, 2 new solenoids, a set of Turbos. It wasn't boosting and I was in rattle hell for a while. They went through all the usual replacements found wastegates weren't seating right. New ones went in it still wouldn't hold boost. Discovered the solenoids were bad. BMW decided to replace everything and all is good again. My CCC, IDrive, Most bus, amplifier and Some module all replaced too. Seriously the car is now better than it was when new. It runs much smoother and no crapolla rattling like a bunch of coins in a can.
I am just out of warranty now, and wondering if I should dump it when I get to around 50K miles. Honestly I feel owning one is a blast, but a bad investment all the same, because I can't see the issues ever ending. I had an E46 M3 I sold with barely 9K on it and went to a E46 330ci because that M3 was just endless problems and I got fed up. I had motoring bliss for a while in the 330ci. Only issue was two bad steptronics. First one at 90 miles, and the replacement one at 112K and I had to pay out of pocket for a new one. I swore it was the last BMW for me, but then came the 335i and one drive in it, it was just too much to resist. Crossed my fingures hoped for the best, but it too turned out to be a stealership frequent flier. Love it though, and I got a RAV4 for a reliable vehicle. It has 33K, and never a hiccup, not one. Only oil change and thats it. Now the BMW.... So much for the ultimate driving machine, or is it Joy BMW
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
06-17-2011, 12:30 PM | #14 |
814
Rep 3,953
Carbon build up on the valves can give you misfires due to blocked are flow and mimic a bad plug or injector. Just talk to the Audi guys about misfires and carbon.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
06-17-2011, 01:29 PM | #15 | |
21
Rep 178
Driving style = 90% calm 10% aggressive |
06-28-2011, 02:26 PM | #16 |
73
Rep 1,388
Update: dealer replaced 3 more injectors - cyls 4, 5 and 6 today. Makes a total of 11 injectors replaced since July 2 of 2009.
Maybe the new ones are better? lol.
06-28-2011, 02:50 PM | #17 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
14 injectors 30k miles.
06-28-2011, 02:52 PM | #18 |
73
Rep 1,388
I think you're currently winning. Or losing, depending on how we look at it
06-28-2011, 02:54 PM | #19 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
believe me man, those injectors are big PITA, I JUST DON'T KNOW why BMW didn't find a solution yet.
06-28-2011, 02:56 PM | #20 | |
73
Rep 1,388
guess only time will tell on that one. he said 'i suspect youll be fine after this replacement' but im very skeptical of that...
06-28-2011, 02:57 PM | #21 |
127
Rep 6,773
tehcron will keep the injectors clean..n BMW recommends using it. I have used a bottle of techron or BG44k every 5Kmiles and knock wood 20K and no problems except one HPFP..of which i was on the very first part #
06-28-2011, 02:58 PM | #22 | |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
