The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Rough idle after valve cleaning
      06-16-2011, 06:39 PM   #1
longliven54
longliven54's Avatar
14
Drives: 2007 335i e90 auto
I justgot done cleaning my valves with seafoam. As expected white smoke came out after starting the car.. How long should the car idle Nd burn off any seafoAm and return to normL idle???
It's been 5 mins of rough idle And half engine lights are jn and very rough idle...any clue anyone??
JB4 G5 / VRSF IC / STETT CAI / GREDDY / custom exhaust / iRotora cross drilled rotots / snow stage 3 meth / 19" iForged senekas / upgraded speakers n CF woofer box / M3 bits/ DINAN camber plates/ KONI/ megan racing toe arm/ supreme power lowering perch
      06-16-2011, 06:41 PM   #2
cn555ic
cn555ic's Avatar
441
Drives: 335i
Don't you have to rev the engine a little bit after the engine warms up!
      06-16-2011, 06:49 PM   #3
longliven54
14
I tried to give gas, but that seems to have no effect .....unless I put it in reverse or drive...
      06-16-2011, 07:13 PM   #4
longliven54
14
ThAnks
It took a lil longer than expected,, almost 20 mins, and it's working fine now..engine seems to resposonding a tad faster now.
      06-16-2011, 07:24 PM   #5
Transport3r
Transport3r's Avatar
86
Drives: 2011 N55 E90
Afraid that's just a placebo effect there.
It has been thoroughly documented that seafoam doesn't do anything besides smoke..
Glad she's running fine again though!
Josh-
      06-16-2011, 07:38 PM   #6
longliven54
14
Valves appear to be less coated with all that carbon junk. I scrubbed it with toothbrush, rifle cleaner, and with a copper/Zinc brush. Maybe all the cleaning cAme from me cleaning with the brushes...but I am happy with the results... Not going to mess with doing it again tho..I consider putting this assembly together as being first timers luck.
      06-16-2011, 07:46 PM   #7
Transport3r
86
Sorry, my bad, I assumed you just ran seafoam through the vacuum line!
Great job on the cleaning then, it should definitely be noticeable now!
Josh-
      06-16-2011, 09:51 PM   #8
Rotorocious
Rotorocious's Avatar
103
Drives: 335xi
Good work!
      06-16-2011, 10:08 PM   #9
frozenfire
frozenfire's Avatar
11
Drives: E92 335i SG
wait what? if you cleaned them by hand why was there smoke? I think you did something wrong... I cleaned mine with loads of seafoam and carb cleaner... but i did not get any smoke at all... nor was i expecting to see any, it doesn't make sense why you would get smoke since the seafoam doesnt ever get burned...
      06-16-2011, 10:10 PM   #10
Rotorocious
103
Drives: 335xi
I think some just leaked down into the cylinder
      06-16-2011, 10:13 PM   #11
frozenfire
frozenfire's Avatar
11
Drives: E92 335i SG
oh... i was wondering what would happen, if that happened (guess i finally know). I was real carefull to make sure the valve I was working on was completly shut before pooring any large quantity of seafoam in there.
glad to hear your car is working fine OP, it was also my first DIY (other than oil changes) for this car.
