Want to try foam canon, what do I need?
06-16-2011, 02:29 PM | #1 |
64
Rep 1,715
I was looking into purchasing a pressure washer, preferably electric and at the same time I want to get into using a foam canon. What exactly would I need? I know people talk a lot of smack about the Karcher pressure washers they sell at target but can an electric pressure washer work in conjunction with a foam canon (something like this http://www.autogeek.net/foam-cannon-...FRJ1gwodE1-O8Q) . I am aware of the "gilmore" type of guns and i'm trying to stay away from those. If someone could enlighten me I'd really appreciate it. Thanks in advance!
Bryan
Click here to join the >>>>https://www.facebook.com/groups/socal535f10crew/
06-16-2011, 02:58 PM | #2 | |
12
Rep 668
06-16-2011, 06:34 PM | #3 |
64
Rep 1,715
Thanks for that info that helped out a lot! The greenworks P.W. has some good reviews as well. This is definitely something I would look into. So from that thread this guy achieved this:
from using that $15 foam blaster along with that greenworks P.W.? Anyone know what the pro's use?
06-17-2011, 12:48 AM | #4 |
12
Rep 668
I have no idea what kind of PW he is using but I think it might be a commercial gas powered unit from one of his comments. I have a 1700PSI 1.4GPM PowerStroke PW from Costco and it gives me similar results but the foam runs off the car some. I was supposed to wash tonight but never did. I'll try to get some pics of it this weekend when I do wash.
My combo isn't the best foam I have seen but I think it's more the PW then the Foam Cannon. But who know, I could be wrong. When I was looking it was between the Lowe's PW and the Costco unit. Both had the same specs, I liked the Lowe's one better BUT the Costco one was cheaper plus I got the Costco return policy so I got the Costco unit. |
06-17-2011, 02:39 AM | #5 |
64
Rep 1,715
which costco unit did u get? Was it the 1700psi powerstroke?
06-17-2011, 10:59 AM | #6 |
56
Rep 1,232
One thing to take from JC's post is the shampoo. They all foam differently and if you're using an foam lance it's really dependent on the shampoo. I have a cheap PW (1500 psi max) and the Home Depot lance, when I use CG Maxi Suds the foam just clings and stays on the car tons of foam, If i use DG 901(great cheap shampoo) not so much. I leave the PW on max when I use it and I only use the foam lance/PW when the car is really dirty otherwsie I do a 2BM wash as it's easier to get set up and going, plus I like to wash the cars early in the morning so I don't want to annoy the neighbors too much more than I already do.
06-17-2011, 01:50 PM | #7 |
12
Rep 668
Yeah, I have the PowerStroke 1700PSI 1.4GPM PW from Costco.
Not sure if you follow Bensbargains but I just noticed the Lowe's unit on sale for $119 after coupon with free in store pickup (or $79 shipped). The coupon code it "CLEANGREEN" or check out the Bensbargains here. EDIT: Scratch that.... it looks like the coupon is now expired. Last edited by mr_milo; 06-17-2011 at 05:31 PM.. |
06-21-2011, 06:49 PM | #8 |
64
Rep 1,715
Thanks for all your help guys! I picked up the greenworks washer from Lowes along with that greenearth g foam blaster. It works great! The PW is strong enough, so strong it actually ripped a small piece of my skin from my arm (I was point blank)lol. So far im loving it but looks like I need a better more frothier soap. I'm currently using this: http://www.chemicalguys.com/Premium_..._p/cws_301.htm
the soap seems to stay on for a few minutes but im looking for something more frothier. Any suggestions?
06-21-2011, 08:29 PM | #9 | |
658
Rep 10,587
06-21-2011, 10:06 PM | #10 |
64
Rep 1,715
thanks snizz. I'll be picking that up tomorrow, CG is literally 5 minutes away from where I live LOL... btw here's a vid I shot today using my new pressure washer on my race car..
06-22-2011, 03:39 AM | #12 |
64
Rep 1,715
this was my first time trying it so pretty much filled the entire soap container with my CG citrus wash and the for the g foam blaster I turned it all the way on. What would you recommend?
06-22-2011, 04:00 AM | #13 |
11
Rep 770
A pressure washer's psi rating isn't the whole story. Although it's the pressure that loosens dirt, it's the volume of water flow that washes the loose dirt away. And the amount of foam isn't necessarily the key to getting the paint surfaces clean, it's the constant flow of lubrication that the foam contains, which provides a barrier between the soil and the paint surface, this is also true of a wash concentrate and your mitt.
Gallon per minute (GPM) water flow rate, not its pressure is what affects the aerated solution (foam), which is created via a venturi, the higher the velocity of the water through the lance, the greater the venturi effect, which creates the aerated solution. So flow rate, venturi valve setting will all affect the resultant foam output The most important functions of a foam cannon/gun is a pre-soak to help remove the dirt and grime, it also provides increased lubricity during the wash phase. The more aeration, the longer it clings to the paint and thus has more dwell time to enable the surfactants to work on surface dirt / grime. |
06-22-2011, 09:19 AM | #14 | |
81
Rep 2,046
06-22-2011, 10:53 AM | #15 |
56
Rep 1,232
Any of the CG soaps witn Maxi Suds should foam well. Do use the correct dilution level to prevent comprimising your lsp and as TOWGT said the thing that controls the foaming is way more depenedent on GPM than PSI. I have almost the same setup and the foam is adequate but not what you'll see from more expensive Pressure washers. I believe the ideal GPM is some where in the 2.5 GPM figure, could be wrong just trying to remember what I've read, and the lower end Lowes/HD etc PW are in the 1.4 -1.8 range. Works for the intent and price as I did not want to drop 300-500 on something I don't use that often. Does your lance have a fixed nozzle or an interchangeable nozzle? Sometimes fiddling with that will help the foaming. Mines a cheapy and fixed but it works satisfactorily for me.
06-22-2011, 01:28 PM | #16 | |
12
Rep 668
Did you have the hose turn on fully? I found that has effect too. So far for the OTS shampoos I found that Turtle wax ICE worked well even a little better than the Meguiars but I liked the wax effect and beading of the Meguiars better. P.S. I forgot to get a video last weekend but I'll try to remember this weekend. Sorry |
06-23-2011, 06:36 PM | #17 | ||
64
Rep 1,715
http://www.lowes.com/pd_336396-53393...d|1&facetInfo=
got it from Lowes Quote:
I'm using the g foam blaster ($15) from home depot. Funny that chemical guys sells this for $50+ Quote:
06-25-2011, 09:00 PM | #18 |
93
Rep 1,794
I bought and tried out the Greenworks foam gun today. I used 100% EagleOne car wash solution. Overall, it worked very well. It foamed very nicely (similar to the pic posted above). My only complaint is that it goes through the solution very quickly. I plan on diluting it next time, but I am thinking it won't foam as well. Anyone else notice this?
06-26-2011, 03:44 AM | #19 | |
64
Rep 1,715
06-27-2011, 12:25 PM | #21 |
64
Rep 1,715
just saw this from the CG facebook page. Looks like their new honeydew snowfoam. I'll stop by this week and buy a small bottle of it. Hopefully mine will come lout like this attached pic
08-03-2011, 02:36 PM | #22 |
37
Rep 187
Did it? Part of the problem I think is that the G Clean foamer isn't that good.
