Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Tuning Question
      06-16-2011, 06:38 AM   #1
Tuner1984
1 Stock M
Tuner1984's Avatar
76
Drives: Something Slow
2003 E46 M3  [0.00]
Tuning Question
Just out of curiosity due to the fact many of us tune and upgrade our cars to get the most power out of them, but does anybody know the max power the stock transmission, clutch, and axles can hold before having to upgrade them?
Veteran USMC/Iraqi Freedom
Current: E46 M3
Retired: 2009 E90 AW M3
Retired: 2007 E90 AW 335i.
      06-16-2011, 06:42 AM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
it will hold fine till you start pushing over 18-19 psi with meth. depends also how you use the car and how old it is .
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      06-16-2011, 06:53 AM   #3
Tuner1984
1 Stock M
Tuner1984's Avatar
76
2003 E46 M3  [0.00]
2007 E90 335i with roughly 55300 miles on it. Right now I'm running 15lbs. Car isn't tracked or a daily driver. I know I want to add more bolt ons and as a get closer and eventually over the 400 whp mark I just want to make sure I don't have to upgrade parts that require upgrading with more power. I think by the end of summer i'll be around 16.5lbs
Current: E46 M3
      06-16-2011, 07:19 AM   #4
s2k_335i
This is it!!
s2k_335i's Avatar
No_Country
15
Drives: FBO 335i without meth
35k of tuning without any major issue yet. I been running 16 psi.
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang.
      06-16-2011, 01:43 PM   #5
Syndicategt
Syndicategt's Avatar
153
Drives: 335i
ACT Clutch + DSS Half Shafts and you are good. If you are on stock turbos, you will be pressed to max out your drivetrain. If you drag your car often and use line locks + DR's you may have some issues
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
