Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Engine Hesitation @ 70MPH - 2007 E92 330D
      06-16-2011, 06:23 AM   #1
Smoothound
Drives: E92 330D SE
Hi All,
I have searched and can't find the answer.
I've noticed my car has a really strange hesitancy/lurching when at 70MPH in 6th (manual box). The best way to replicate it is as follows
1) Drive at 65MPH
2) Set cruise control
3) Gradually increase cruise control in 1MPH increments
4) At 70MPH there will be a lurch
I've sent it back to the dealer and they said they couldn't replicate the problem. It's pretty annoying as when you're cruising at 70MPH you get the lurching whenever the cruise control has to compensate for a hill. The only way to live with it is to cruise at 65 or 75.
It also does it on manual throttle and in other gears, this is just the easiest way to replicate the behaviour.
Has anyone else ever experienced this?
Does anyone with a 2007 330D fancy trying the above to see if the same happens?
Thank you!
      06-16-2011, 06:34 AM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
you are better off asking on the UK regional forum . More Diesel there.
Originally Posted by Smoothound View Post
Hi All,
1) Drive at 65MPH
Thank you!
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      06-16-2011, 06:59 AM   #3
Smoothound
Drives: E92 330D SE
OK, will do, thanks.
      06-16-2011, 08:06 AM   #4
dyezak
General of the Armies
dyezak's Avatar
156
Drives: X5M
You said this happens in other gears? So it's not MPH specific... Is it RPM specific?
      06-20-2011, 04:04 AM   #5
Smoothound
Drives: E92 330D SE
Yes, seems to be RPM specific. Seem to have an answer on the other thread
http://www.e90post.com/forums/showth...=1#post9852955
EGR valve apparently
