Buying a Procede v5 need help...
06-16-2011, 01:50 AM | #1 |
21
Rep 203
Ok so before I get the usual bashing that goes with posts like these, let me make it clear. I HAVE searched but what I found still didn't clear some things up.
1. If I buy the Procede enthusiast version does this mean I can NOT control things like traction assist, initial boost, WG, etc.? 2. If the answer to the above question is NO then that obviously mean I can not access the Vishnu Command center correct? 3. Does the Procede Tuner Version require VIN unlock code if I am buying used? 4. Lastly, does the Procede Tuner Version require a laptop to adjust settings or can it ALL be done from the command center? (I have a mac) Thanks. And please no Jb lovers. Don't try to convert me. lol |
06-16-2011, 02:24 AM | #2 |
184
Rep 2,320
1. you can control
3. if its locked then u need unlock it 4. all procede needs laptop to do most options (only if u have cruise stalk button then its easier) but updating maps and firmw u will need laptop anyway check this http://www.e90post.com/forums/showthread.php?t=464460 and procede website http://www.procedetuning.com/BMW/n54/n54.html
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
06-16-2011, 02:44 AM | #3 | |
21
Rep 203
06-16-2011, 03:34 AM | #4 | |
161
Rep 7,377
They are working on the new autotuning logic right now, no idea though when they will release it.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
06-16-2011, 11:09 AM | #5 | |
153
Rep 3,730
I was using the 5-10 beta maps for the last month, they are amazing maps if you want to use the DIC maps. If you have to have autotuning, use the 12-17 final release maps which I am currently using now.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
06-22-2011, 07:36 PM | #6 |
21
Rep 203
Do I need to have the Procede installed to update firmware/maps and unlock VIN or can I hook it up directly to a PC. Reason I'm asking is because I have a Mac and I'll probably have to do the install at a friends house if that's the case.
Thanks. |
06-22-2011, 07:53 PM | #7 |
76
Rep 1,883
Procede needs power to operate. So you would have to power it from a 12V source.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
06-26-2011, 03:33 AM | #8 |
21
Rep 203
Just got my Procede via UPS this week
Can not find a definete answer for my install questions: 1. I purchased a pre-owned V5 that's vin locked. Do I install then use the unlock code, then update firmware then maps? Could someone please give me the steps in order? It has the 101 firmware not the latest 106. 2. Do I really need to unhook the battery terminal for install? Has anyone NOT done this with any luck? 3. When uploading/updating the Procede do I need to have the doors and windows closed? Sorry for the noob questions. I am just so excited |
06-26-2011, 03:47 AM | #9 |
184
Rep 2,320
101 is for 12-17 maps, if you want try other maps you need upload that firmw that is in a same folder as the maps
06-26-2011, 07:38 AM | #10 |
135
Rep 1,999
Drives: 2007 E92 335i; 2015 X5 50i
IFLO:
1) You need to pull your maps back to V4. I have a Procede module that was upgraded to V5 before sold. When I tried to install it, Procede wouldn't work until I downgraded to V4. It'll cost you $150+shipping to send it back to get it unlocked and reloaded with latest firmware. As to 2 and 3... Just unhook it in the back to be safe. I just took it out without disconnecting it and I'm kinda regreting it. I don't know if there'll be an issue. 3... just don't lock your keys in the car when you unhook the battery and you'll be fine :-p |
06-26-2011, 11:36 AM | #11 |
76
Rep 1,883
2 and 3 depend on each other.
You don't need to disconnect the battery, but make sure the doors are shut and the windows locked so that the ecu goes into sleep mode. You only need to do this when you disconnect the car's power to connect the procede (little green box - if we are talking about n54, have not experience on n55). Windows can be down. Disconnecting the battery is more of a failsafe against creating some codes for disconnecting the power when the car isn't sleeping, although it only takes about 1 minute to disconnect the battery.
06-28-2011, 04:22 AM | #13 | |
21
Rep 203
I watched a JB3 install video and I am just going to let my ECU go into sleep mode by waiting 10 mins. Have to lock the doors and leave the hood open while waiting. Thanks everyone for helping. Can't wait! |
06-28-2011, 06:30 AM | #14 | |
Rep 68
Drives: passively aggressive.
Location: probably in a hotel thousands of miles away from home.
