BEWARE?? AMS FMIC Problem
06-15-2011, 11:12 AM | #1 |
42
Rep 993
Weather got hot last week and turned on the A/C. 15 min later no cold air and still sweating balls. no problem, figure it's just a warranty fix. Dealership calls me and tells me my FMIC piping has been rubbing against the A/C lines and burned a hole right through it? 989+tax to fix (obviously wont fix it @ dealership), but wtf? Is this an install problem? I dont see how else you can install it differently...anybody see anything similar?
06-15-2011, 11:20 AM | #2 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Shiit. Take it to a welder and have them put a small weld on the hole of your AC line. Then see if you can adjust your intercooler pipes.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
06-15-2011, 12:05 PM | #3 |
3398
Rep 6,589
Drives: BMW
yikes, man that is unfortunate.
06-15-2011, 12:16 PM | #4 |
Vishnu Powered
68
Rep 2,205
Is that from the top of the engine bay?
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3 |
06-15-2011, 12:19 PM | #6 |
292
Rep 2,898
06-15-2011, 12:20 PM | #7 |
153
Rep 3,730
Appears to be right next to the DV at the top, I see his are capped off for a BOV.
+1 Worm clamp was definately rubbing.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
06-15-2011, 12:36 PM | #9 |
23
Rep 303
06-15-2011, 12:38 PM | #10 |
369
Rep 8,693
Drives: 06 330i
common problem in G35's.
surprised to see it here! |
06-15-2011, 12:44 PM | #12 |
154
Rep 4,528
Drives: M2 CS
^that
another option would be if you know any place that does a/c work, have them make you another line and reroute it somewhere safe |
06-15-2011, 12:55 PM | #13 | |
Roll Tide
591
Rep 2,345
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
06-15-2011, 01:00 PM | #15 |
290
Rep 28,154
just replace the line, recharge the ac, and make sure the screw clamping edge of the clamp is opposite the line, it could be the angle of the picture, but it looks like there is a few mm of space between the tube and the ac hose
06-15-2011, 01:02 PM | #16 |
This is it!!
15
Rep 672
I had the AMS for about 6 months and I do not see any issue. Like people mentioned here, maybe the clamp was rubbing against the pipe for a long period of time to produce the damaged?
How long you had it installed?
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang. |
06-15-2011, 01:04 PM | #17 |
Aficionado of All Things Vroom
171
Rep 1,213
Shit. Had an issue during a long drive last week with little/no cold air as well, though i've got the ETS fmic. wonder if it's a similar issue/installation related......
Current: 2020 F97 X3M Competition
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi |
06-15-2011, 01:57 PM | #19 |
42
Rep 993
You may be right, have not taken a good look at the car myself, this is a pic my SA snapped for me at the dealership and car is still there.
I think at this point instead of replacing the line my other mechanic is going to weld it for me and then reinforce it with aluminum + wrap. He will pressure test the system afterwards. This may be a better alternative to prevent smth like this happening again...unless anyone sees anything negative with it? Welding is a stronger/better alternative, i've heard not alot of shops will do it for you because it takes longer and they make less. Let this be a heads up to any of you guys out there to ensure there's no rubbing. Also, when he recharges it he plans to use redtek, anyone have any experience/heard of it? |
06-15-2011, 02:54 PM | #22 | |
290
Rep 28,154
hey op, get a new tube/hose for the ac, don't chance welding it, its not worth the labor down the road if it decides to leak slowly and you need a new hose and recharge |
