Dyno'd Cobb Stage 1 in 102F heat... 334hp/394ft.lbs (video added)
06-14-2011, 08:36 PM | #1 |
General of the Armies
156
Rep 656
So before Stage 2 comes out, and then the Access Tuner software follows and I have a custom tune for my car, I thought a baseline was in order. Today DEFINITELY wasn't the best day to run a car on a dyno. At 4-5pm in Plano today temps ranged from 98-102deg F, and in the dyno room, it was on the high end . Combine that with my auto 335i that saps more power than a 6sp and you can definitely do better than what you will see here.
Car strapped down to the dyno, hooking up the boost gauge, the ignition pickup and the wideband 02 sensor: We calibrated the dyno first, then ran three runs. The first run the tires spun when peak torque was hit around 2800rpm. The first run had to be thrown out because that caused an artificial torque dip/spike in the chart. The next two runs were as smooth as can be and when overlay-ed over each other it's so close it's uncanny. Here is the last two runs displayed at the same time. Notice how close they are, even in 102deg F heat. The ETS FMIC is not allowing any heat soak : I am uploading 1080p video of the whole session now to YouTube. When it's up I'll link to it here so you guys can see. The video is boring however, uneventful and shows almost 400ft/lb of torque going into the rollers in the most unspectacular fashion. Last edited by dyezak; 06-14-2011 at 10:04 PM.. |
06-14-2011, 09:04 PM | #5 |
Team Zissou
3065
Rep 10,197
Did you ever run the car at stock boost there? With full bolt ons on stock turbos in much cooler weather (on a stock tune) I made 256awhp / 289awtq
That is a very high reading mustang dyno. Last edited by jpsimon; 06-14-2011 at 09:14 PM.. |
06-14-2011, 09:15 PM | #6 | |
156
Rep 656
Stock 335i: My EVO: Based on this stock pull on this dyno *your* mustang run was very high reading |
06-14-2011, 09:23 PM | #7 |
Team Zissou
3065
Rep 10,197
My "baseline" was fully modded (catless + fmic.. Etc), in stock mode. So subtract another 15-20 for a real stock XI.
Anyways, if your car is really picking up 120wtq in 102 degrees.. that's a lot more than the typical norm! Not bad! |
06-14-2011, 11:02 PM | #9 |
469
Rep 4,392
I am just amazed with Cobb's stage 1 from car to car with different mods. I just cant wait to test out Cobb with Dinan stage 3 mods.
Just ordered my Dinan IC and OC, will be installed next week. Last edited by BQTuning; 06-14-2011 at 11:08 PM.. |
06-15-2011, 02:22 AM | #12 |
475
Rep 13,583
Drives: JB E92 335i
The COBB AccessPORT Stage 1 tune definitely holds up to it's promise. Thanks for posting up your dyno results and sharing them with the community. We are an authorized COBB dealer for BMW so don't hesitate to drop me a PM if you guys have any questions at all!
06-15-2011, 06:13 AM | #13 |
1 Stock M
76
Rep 1,650
Drives: Something Slow
Great numbers for the weather being so hot!! I need to dnyo mine to see what I make. Only mods are Cobb 93 Stage 1 v 201, BMS DCI, Helix FMIC, and DVs. My friend dynoed his car SAE corrected with only Cobb Stage 1 and no boltons at 320 whp and 360 wheel torque.
Veteran USMC/Iraqi Freedom
Current: E46 M3 Retired: 2009 E90 AW M3 Retired: 2007 E90 AW 335i. |
06-15-2011, 07:17 AM | #14 | |
5453
Rep 8,815
Alan
06-15-2011, 07:28 AM | #15 |
156
Rep 656
06-15-2011, 07:55 AM | #16 |
28
Rep 300
Great numbers there, especially in this heat! We're expecting more triple digit heat later today the 15th. That's the same day your dyno numbers are dated. Note to Plano Cobb - you might want to update your system....it's running in the future!
06-15-2011, 08:03 AM | #17 |
156
Rep 656
Another thing to look at...check out that AFR. Rock solid across the entire RPM range. Just for compairison I pulled a Procede auto-tuned car ran on the same dyno. This was after six tuning runs:
That is not very good... |
06-15-2011, 08:09 AM | #18 |
156
Rep 656
Just FYI for everyone... I just bought a Procede so I can test it back to back with the Cobb AP on my car. I'll take it to the track and back to the Dyno...
06-15-2011, 12:02 PM | #20 |
3441
Rep 79,211
Thats some good numbers considering the heat,xi, and mustang dyno. Shoulda switched to stock mode for a baseline just for the hell of it though.
06-15-2011, 12:49 PM | #21 |
156
Rep 656
Kevin told me he would "crack the whip" on the guys down in Austin to get us Stage 2 and ATR. He said he would also ask to see what kind of mods Stage 2 would require. He will be down there on Friday...I'll call him on Monday for you.
06-15-2011, 12:50 PM | #22 |
156
Rep 656
