Help with CEL
06-14-2011, 07:27 AM | #1 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Help with CEL
Yesterday I went grocery shopping and when I started the car, my P3 gauge showed me I had a stored fault code. There was no engine light on the dash, so I drove off and decided to check it out after I came back from shopping.
I hooked up my BT and this is what was stored: 2A17: 2A17 DMTL diagnosis module tank leakage, system failure Error will cause a warning light Error is currently present Test conditions have been completed Timeout I've never seen this error before on my car. Is this possibly due to the gas cap not being tight enough? I always make sure it clicks 3 times when I put fuel in my car so I am bit concerned that it could be something else. Thanks for your time in advance.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
06-14-2011, 08:00 AM | #2 |
General of the Armies
156
Rep 656
Nobody freaking searches? Jesus, just plug the code into Google and the first thing that pops up is a post here on e90post.com stating that code is indicitive of your low pressure pump going out:
http://www.e90post.com/forums/showthread.php?t=388812 |
06-14-2011, 08:07 AM | #3 | |
93
Rep 1,794
06-14-2011, 01:23 PM | #4 | |
1121
Rep 5,396
1. Bad low pressure fuel pump 2. Possibly a problem with the fuel filler neck.
06-15-2011, 09:52 AM | #6 |
1121
Rep 5,396
Hmm. That seems to be possibility number 3. I guess I'll monitor and see if comes back. If it does, I am taking it to the dealer as my warranty will be running out soon.
06-15-2011, 10:09 AM | #7 |
441
Rep 18,331
I get that code sometimes too when I fill the car up with gas and sometimes it takes forver to fill...When this happens occasionally i get this code...I clear it and then it doesnt appear for a while...Have the car 4 years and it happened twice so far and each time it was a issue filling up the car with gas...Took forever to fill 11 gallons of gas!! lol
