JB4 6/4 Beta including MaxCool, AFR/EGT in dash, revised stealth gauges, and more...
06-13-2011, 11:21 AM | #1 | |
Joint Chiefs of Staff
4918
Rep 115,980
Hey guys,
BMS just posted the JB4 6/4 firmware and interface on their site for your beta testing pleasures. Early feedback on the new features has been very positive. In addition to adding MaxCool (just in time for summer!) they've also expanded the in dash gauge options. You can now select boost, timing, iat, water temp, EGT, AFR, and meth independently for fuel and/or oil. The new stealth mode changes are great too. Your in dash gauges will show fuel and oil temperature until going over 50% throttle at which point they will show the remapped gauges. After 15 seconds of no heavy throttle they snap back to stock operation. Very cool. Quote:
06-13-2011, 12:14 PM | #2 |
273
Rep 5,876
Mike, can you explain this feature a bit:
8) Changed unused "FpSafety" user adjustable to "FpMapping" adjustable now used for fine tuning fuel pressure. A value of 0 disables fuel pressure mapping. A value of 90 matches the previous setting and is the new default. What happens if FP is set to zero and you up boost? Why even bother with fuel pressure when the system is closed loop and will auto-adjust based on front widebands? What does 90 really mean in terms of units? Is that a multiplier or how does it work? |
06-13-2011, 01:15 PM | #3 |
Got Boost?
Rep 234
Anyone else have experience with running fans at speed. I remember on previous cars with manual switches on the fan you had to shut off over like 35 mph because it actually hindered airflow. Stock fans turn off for speed on every car i have checked....
Any thoughts or info on this as it pertains to the Max Cool feature?
- - My Car Domain - -
2010 BMW 135i AT, AW, ///M Sport JB4|BMS DCI|MS 3" cattless DPs|Golf Tee|33% Tint|///M Pedals |
06-13-2011, 02:31 PM | #4 | |
4918
Rep 115,980
Mike |
06-13-2011, 02:32 PM | #5 | |
4918
Rep 115,980
Mike |
06-13-2011, 04:02 PM | #6 | |
13
Rep 202
I have had no issues with the new firmware, even in the alpha stages. So update your firmware and start feeling what FPMapping can do for your car. |
06-13-2011, 04:35 PM | #7 |
142
Rep 2,661
i love that MaxCool
06-13-2011, 04:43 PM | #8 |
Got Boost?
Rep 234
Found out...on at all speeds...haven't gotten enough highway testing done yet so it may have a speed shutoff in the future. But for now it just shuts off based on temp and if over 40% throttle.
06-13-2011, 05:30 PM | #9 |
Rep 332
Drives: F30 340i Xdrive
Does the engine need to be running when updating firmware?
06-13-2011, 05:33 PM | #10 |
13
Rep 202
06-13-2011, 05:35 PM | #11 |
87
Rep 2,854
06-13-2011, 05:39 PM | #12 |
13
Rep 202
There was no default previously. The value was set at 0 which is why Terry said the previously unused FPSafety will now be called FPMapping and the default value is 90 meaning it's active while a value of 0 means it's the stock mapping.
06-13-2011, 05:41 PM | #13 | |
87
Rep 2,854
they don't seem to delve into it much over @ n54tech |
06-13-2011, 08:49 PM | #16 |
13
Rep 202
Same maps, nothing has changed. Map 6 has been there forever, nothing new, but I think Terry added meth integration to it too so maybe that's what you mean or maybe your thinking map 3, the progressive meth map. The only other things that are relatively new, other than whats in the list, are the CPS and Fuel settings but that's if you have the CPS module or know what your doing when messing with fuel.
06-14-2011, 10:15 AM | #18 |
4918
Rep 115,980
06-14-2011, 10:58 AM | #20 | |
184
Rep 2,841
When I had my turbo's replaced after yr 1 of ownership they also replaced my water pump because there were some metal shavings in the housing. It looks like BMW is running that water pump overtime so having the fan kick in sooner sounds like a good idea. But the fan is pretty loud at full blast......is that what 100% duty cycle is ? |
06-15-2011, 07:50 PM | #21 |
12
Rep 97
Terry,
Would you recommend running max cool all the time even for daily driving. Temps here in Mississippi are in the mid 90s and my 1/07 production is without an oil cooler. It seems like I have around 10-15 deg drop in oil temps with max cool on.
2007 335i
Mods: JB4, BMS DCI Intake, HPF FMIC, Forged DVs, ceramic Tint, Black Emblems, 93 Octane |
